Pegasus2 R6 doesn't mount automaticly under macos 10.14.4 beta6
  • 354 Views
  • Last Post 21 March 2019
Christoph Straller posted this 19 March 2019
Pegasus2 R6 doesn't mount under macos 10.14.4 beta6 ---- the only HDD what is mounting is the one i unse for Time Mashine --- the rest i have to mount over the disk utility, but if i mount them i can’t turn off my Mac — have to shut down the Pegasus manually before shut down the Mac —- no respond on the Pegasus side not even over the disk utility --- everything was ok until macos 10.14.4 beta4 --- does anyone have a idea to fix this problem ??? so that all my external HDD will mount automaticly again
bug i get always but this is even before the beta software is on --- when i open up the Pegasus2 utility there is a pop up ... that the network connection is on error !
thank you
Christoph
arunkumar b posted this 20 March 2019
Hi Christoph,
We need service report to investigate this issue further.Please open support case at https://support.promise.com/ and attach the report in the case.
Steps to save the service report :
1) Open Promise Utility.
Also attach the Mac system profiler along with service report, Click Apple Icon > About this Mac > More info > System Report > Choose 'File' & 'Save'
Arun
Christoph Straller posted this 20 March 2019
Hi Christoph,
Arun
Hi Arun,
thank you for your replay ... was trying to log on the support page but for some reason i can't
login ... first it says wrong password, then i tryed to create a new user login ... but as my email
already exist it will not work either
and second i can't even get to save a service report as the
Promise Utility can't get any connections to the HDD or the unit
i can see the HDD on my desktop, but if i try to open one of them
it just doesn't show any files or data on the HDD
can't remove the HDD or un-mount them ... only if i shut down the whole unit
manually ...
Christoph
arunkumar b posted this 21 March 2019
Hi Christoph,
Please contact support +1 (408) 228-1500 to assist you better
Arun
