Pegasus2 R6 doesn't mount automaticly under macos 10.14.4 beta6
  • 354 Views
  • Last Post 21 March 2019
Christoph Straller posted this 19 March 2019
Pegasus2 R6 doesn't mount under macos 10.14.4 beta6 ---- the only HDD what is mounting is the one i unse for Time Mashine --- the rest i have to mount over the disk utility, but if i mount them i can’t turn off my Mac — have to shut down the Pegasus manually before shut down the Mac —- no respond on the Pegasus side not even over the disk utility --- everything was ok until macos 10.14.4 beta4 --- does anyone have a idea to fix this problem ??? so that all my external HDD will mount automaticly again
bug i get always but this is even before the beta software is on --- when i open up the Pegasus2 utility there is a pop up ... that the network connection is on error !
thank you
Christoph
arunkumar b posted this 21 March 2019
Hi Christoph,
Please contact support +1 (408) 228-1500 to assist you better
Arun
Christoph Straller posted this 20 March 2019
Hi Christoph,
We need service report to investigate this issue further.Please open support case at https://support.promise.com/ and attach the report in the case.
Steps to save the service report :
1) Open Promise Utility.
Also attach the Mac system profiler along with service report, Click Apple Icon > About this Mac > More info > System Report > Choose 'File' & 'Save'
Arun
Hi Arun,
thank you for your replay ... was trying to log on the support page but for some reason i can't
login ... first it says wrong password, then i tryed to create a new user login ... but as my email
already exist it will not work either
and second i can't even get to save a service report as the
Promise Utility can't get any connections to the HDD or the unit
i can see the HDD on my desktop, but if i try to open one of them
it just doesn't show any files or data on the HDD
can't remove the HDD or un-mount them ... only if i shut down the whole unit
manually ...
Christoph
arunkumar b posted this 20 March 2019
Hi Christoph,
Arun
