Pegasus2 R4 - Drive ID 1 - OK, PFA
  • 885 Views
  • Last Post 20 September 2019
W. Kirk Lutz posted this 19 September 2019
Dashboard has Warnings on Physical Drive and Disk Array.
Physical Drive: "One or more physical drives are critical or rebuilding"
Disk Array: "OK, PFA"
When I click on Physical Drive from the dashboard: I have all green checkmarks under status but drive ID 1 has PFA under the checkmark.
When I click on Disk Array from the dashboard:
Status: OK, PFA
Capacity: 8 TB
Free Capacity: 0 Byte
Media Patrol: Enabled
When I do a Get Info from my Mac on the RAID it says Capacity 6TB and Available 2.6TB.
No idea what all this means or what I should do. I think the drive is rebuilding because I can hear it churning. Do I need to buy a new drive? If so, what specific drive should I buy? How do I get the new drive in without losing TBs of data?
W. Kirk Lutz posted this 20 September 2019
I updated to the latest utility and tried to "Save Service Report". This time, I get a spinning progress wheel, then the utility crashes. I am going to try restarting my Mac since part of the install was an extension that require security overrides that need a restart to run.
Just restarted and tried to get the report but the utility quits instead of generating a report.
Just saw there was an update to the Utility. I am installing it and trying again.
I followed your instructions, but when I hit "Save Service Report" nothing happens. Is it being saved somewhere on my Mac? Not in the downloads or documents folder.
Ranjith kumar posted this 20 September 2019
Hi Kirk,
In order to assist you on this, we need to analyse the subsystem report, please save and attach it to the web support case by logging at support.promise.com.
- Open promise utility
- Click on save service report button to save the subsystem report
Thank you,
