Pegasus2 R4 boots, then red light and shuts down
  • 654 Views
  • Last Post 17 April 2020
Ray Argall posted this 15 April 2020
I've just received a Pegasus2 R4, which was slightly damaged in transit. All the drives and drive casings seem okay, there is a crack in the top RHS but otherwise the main casing and contents seem okay no apparent damage. When I boot up the R4, it fires up, all the blue lights work, then power light goes amber, then red and it immediately shuts down, which I presume is a safety mechanism. This happens whether there are drives in the bays or not. I have a Pegasus2 R8 which is fabulous, and was adding to the chain. This is not a new item, hence posting to see if anyone knows of this behaviour and if it's a sign the R4 is completely dead or can be retreived?
Any leads would be greatly appreciated!
Thanks,
Ray
Ray Argall posted this 17 April 2020
Hi Raghuraman,
Thanks for the response. You're right! TB connections can be tricky, I tried the other port and it worked okay. I was then able to get the Promise Utility to recognise the unit, which it said was okay, however the unit was only recognising one of the four drives. I tried with another set of drives I know to be good and the unit still only recognised the drive in Bay one. So I was able to get the unit to power up with blue light when no drives were in. I have an older R4 unti that has a problem where drive bay three is reading as a failed disk - after this happened with three different drives - always in bay three, I concluded it was the unit, hence looking for a replacement. The P2 R8 is performing very well. With this unit I will return to the seller as it was clearly damaged in transit.
Thanks,
Ray
Raghuraman Kannan posted this 17 April 2020
Hi Ray,
Pegasus 2 units will not stay ON if the Thunderbolt connections are not established. Please make sure that the Thunderbolt connections are proper and try with a new Thunderbolt cable.
