Pegasus2 M4 - Power Cut then all four drives dead
  • 263 Views
  • Last Post 20 August 2018
Dale Minter posted this 14 August 2018
We had a number of powercuts in a row and then the RAID failed. All four drive slots said something about every drive being "removed" and now "dead". No physical drives are showing up in the utility nor command line.
The drives are x4 Samsung 850 SSDs in a RAID5 and have been working perfectly for over a year without issues. I cant believe all four died at once?
Troubleshooting Steps:
- Ran latest utility update to: 4.02.0000.12
- Physically ejected each drive sled and pushed back in
- Destroyed logical drive
- Destroyed disk array
- Command line promiseutil / phydrv responds with "No physical drive is in the enclosure"
Where too now? I have backup of data, just really want physical drives to be recognised so I can rebuild.
Venkatachalam Settu posted this 14 August 2018
Hi Dale,
It looks like this issue needs to be analyzed with the help of subsystem report of the unit to find out the exact issue.You can call technical support at 408-228-1500 or reach out through support case at  https://support.promise.com/.
Dale Minter posted this 20 August 2018
Follows is the subsystem report. Any ideas?
Promise Utility
Version: 4.02.0000.12 Build Date: Apr 20, 2018
Copyright 2017-2018 Promise Technology, Inc. All rights reserved.
Alias:
Vendor: Promise Technology,Inc.        Model: Pegasus2 M4
PartNo: F29DS4722000000                SerialNo: M93L14409600313
Rev: A3                                WWN: 2000-0001-5558-3fea
PDSN: N/A
CtrlId: 1
Alias:
OperationalStatus: OK                  PowerOnTime: 45 hours 4 minutes
LUNAffinity: N/A                       LunmappingMethod: WWN Based
CacheUsagePercentage: 0%               DirtyCachePercentage: 0%
Vendor: PROMISE                        Model: Pegasus2 M4
HWRev: A3                              WWN: 2000-0001-5558-3fea
CmdProtocol: SCSI-3
MemType: DDR SDRAM                     MemSize: 512MB
FlashType: Flash Memory                FlashSize: 8MB
NVRAMType: FRAM                        NVRAMSize: 128KB
BootLoaderVersion: 5.04.0000.61        BootLoaderBuildDate: Dec 26, 2016
FirmwareVersion: 5.04.0000.61          FirmwareBuildDate: Dec 26, 2016
SoftwareVersion: 5.04.0000.61          SoftwareBuildDate: Dec 26, 2016
BIOSVersion: 5.04.0000.61              BIOSBuildDate: Dec 26, 2016
SingleImageVersion: 5.04.0000.61       SingleImageBuildDate: Dec 26, 2016
CtrlCPLDVersion: 6.08
DiskArrayPresent: 0                    OverallRAIDStatus: OK
LogDrvPresent: 0                       LogDrvOnline: 0
LogDrvOffline: 0                       LogDrvCritical: 0
PhyDrvPresent: 0                       PhyDrvOnline: 0
PhyDrvOffline: 0                       PhyDrvPFA: 0
GlobalSparePresent: 0                  DedicatedSparePresent: 0
RevertibleGlobalSparePresent: 0        RevertibleDedicatedSparePresent: 0
RevertibleGlobalSpareUsed: 0           RevertibleDedicatedSpareUsed: 0
WriteThroughMode: No                   MaxSectorSize: 4KB
PreferredCacheLineSize: 64 KB          CacheLineSize: 64 KB
Coercion: Enabled                      CoercionMethod: GBTruncate
SMART: Disabled                        SMARTPollingInterval: 10 minutes
MigrationStorage: DDF                  CacheFlushInterval: 3 second(s)
PollInterval: 15 second(s)             AdaptiveWBCache: Disabled
ForcedReadAhead: Enabled
PowerSavingLevel: 0                    SpindownType: All drives
IdleTimeToParkRwHeads: Never           IdleTimeToLowerRotationSpeed: Never
IdleTimeToSpinDown: Never
SGPIOBackPlane: Default/Generic (0)    SASReadyLED: Off
SpinUpDelay: 0 millisecond             PowerManagement: Enable
SecurityAdminPassword: N/A
PciFuncAddr: N/A                       PciLinkSpeed: N/A
PciLinkWidth: N/A
Enclosure Setting:
EnclosureId: 1
EnclWarningTempThreshold: 54C/129F     EnclCriticalTempThreshold: 59C/138F
CtrlWarningTempThreshold: 64C/147F     CtrlCriticalTempThreshold: 69C/156F
Enclosure Info and Status:
EnclosureId: 1
EnclosureType: Pegasus2 M4
SEPFwVersion: 1.00
MaxNumOfControllers: 1                 MaxNumOfPhyDrvSlots: 4
MaxNumOfFans: 1                        MaxNumOfBlowers: 0
MaxNumOfTempSensors: 2                 MaxNumOfPSUs: 1
MaxNumOfBatteries: 0                   MaxNumOfVoltageSensors: 3
PSU       Status
1         Powered On and Functional
Fan Location        FanStatus             HealthyThreshold  CurrentFanSpeed
1   Backplane       Functional            > 1000 RPM        2400 RPM
TemperatureSensor   Location       HealthThreshold   CurrentTemp    Status
1                   Controller     < 64C/147F        43C/109F       normal
2                   Backplane      < 54C/129F        37C/98F        normal
VoltageSensor  Type    HealthyThreshold         CurrentVoltage  Status
1              3.3V    +/- 5% (3.13 - 3.46) V   3.2V            Operational
2              5.0V    +/- 5% (4.75 - 5.25) V   5.1V            Operational
3              12.0V   +/- 5% (11.4 - 12.6) V   12.1V           Operational
Enabled   Status
Yes       Silent
PdId Model        Type      Capacity  Location      OpStatus  ConfigStatus
No physical drive in the enclosure
DaId Alias     OpStatus      CfgCapacity FreeCapacity   MaxContiguousCapacity
No configured disk array in the subsystem
All Spare Info
Begin Hex Dump in Byte
0000-000f: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0010-001f: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0020-002f: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0030-003f: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
End Hex Dump in Byte
LdId Alias       OpStatus      Capacity  Stripe RAID    CachePolicy     SYNCed
No configured logical drive in the subsystem
0000-000f: 00 33 04 82 00 00 00 00 00 00 00 00 00 00 00 00
Controller Statistics
ControllerId: 1
DataTransferred: 20.57GB
ReadDataTransferred: 19.15GB           WriteDataTransferred: 1.42GB
Errors: 4                              NonRWErrors: 0
ReadErrors: 4                          WriteErrors: 0
IORequest: 390,040                     NonRWRequest: 1,122
ReadIORequest: 364,322                 WriteIORequest: 24,596
StatsStartTime: Aug 13, 2018 23:45:32
StatsCollectionTime: Aug 15, 2018 20:49:37
Physical Drive Statistics
Physical drive and its statistics not found
Logical drive Statistics
Logical drive and its statistics not found
Id  OpStatus  PdId CfgCapacity Revertible Type      DedicatedToArray
No configured spare drive in the subsystem
BGA Summary
NumberOfRebuild: 0                     NumberOfMigration: 0
NumberOfPDM: 0                         NumberOfTransition: 0
NumberOfSync: 0                        NumberOfInit: 0
NumberOfRC: 0                          NumberOfMP: 0
NumberOfLunC: 0
LastMPStart: Not Started               LastMPStop: Not Stopped
BGA Settings
AutoRebuild: Enabled                   MediaPatrol: Enabled
AutoRebuildToDeadDisk: Disabled
RebuildRate: Medium                    MigrationRate: Low
PDMRate: Medium                        TransitionRate: Medium
SyncRate: Low                          InitRate: Medium
RCRate: Medium
ReAssignedBlock: 1024                  ErrorBlock: 1024
BGA Progress
SeqNo: 0                               Device: Ctrl 1
EventId: 0x0004004A                    Severity: Warning
TimeStamp: Aug 14, 2018 11:45:13       DefaultId: 0x0004004A
SpecData: 000000000000000000 0000000000000000 0000000000000000 00000000000000
Description: Last shutdown is abnormal
SeqNo: 1                               Device: Ctrl 1
EventId: 0x00040005                    Severity: Info
TimeStamp: Aug 14, 2018 11:45:20       DefaultId: 0x00040005
Description: The system is started
SeqNo: 2                               Device: SEP 1
EventId: 0x00060002                    Severity: Info
TimeStamp: Aug 14, 2018 11:45:27       DefaultId: 0x00060002
Description: SEP is found
SeqNo: 3                               Device: Ctrl 1
EventId: 0x00040006                    Severity: Info
TimeStamp: Aug 14, 2018 12:26:18       DefaultId: 0x00040006
SpecData: 160000000000000000 0000000000000000 0000000000000000 00000000000000
Description: The system is stopped
SeqNo: 4                               Device: PD 4
EventId: 0x000D001A                    Severity: Major
TimeStamp: Aug 14, 2018 12:26:25       DefaultId: 0x000D001A
SpecData: 000000000800000000 0000000000000000 0000000000000000 00000000000000
Description: Physical Disk is marked as DEAD due to removal
SeqNo: 5                               Device: LD 0
EventId: 0x00090004                    Severity: Major
TimeStamp: Aug 14, 2018 12:26:25       DefaultId: 0x00090004
SpecData: 000000000000000000 0000000000000000 0000000000000022 310001550F8957
Description: Logical drive has been set to critical
SeqNo: 6                               Device: PD 3
SeqNo: 7                               Device: LD 0
EventId: 0x00090003                    Severity: Major
TimeStamp: Aug 14, 2018 12:26:25       DefaultId: 0x00090003
Description: Logical drive has been placed offline. Possible Data Loss
SeqNo: 8                               Device: PD 1
SeqNo: 9                               Device: PD 2
SeqNo: 10                              Device: PD 4
EventId: 0x000D000B                    Severity: Warning
TimeStamp: Aug 14, 2018 12:26:25       DefaultId: 0x000D000B
Description: Physical Disk has been removed
SeqNo: 11                              Device: PD 3
TimeStamp: Aug 14, 2018 12:26:26       DefaultId: 0x000D000B
SeqNo: 12                              Device: PD 1
SeqNo: 13                              Device: PD 2
SeqNo: 14                              Device: LD 0
EventId: 0x00090001                    Severity: Info
TimeStamp: Aug 14, 2018 22:46:10       DefaultId: 0x00090001
Description: Logical drive has been deleted
SeqNo: 15                              Device: DA 0
EventId: 0x00130001                    Severity: Info
TimeStamp: Aug 14, 2018 22:46:32       DefaultId: 0x00130001
SpecData: 000000000000000000 0000000000000000 00000000000000EB A2060000000000
Description: Disk array has been deleted
SeqNo: 16                              Device: Ctrl 1
EventId: 0x00040007                    Severity: Info
TimeStamp: Aug 14, 2018 23:38:53       DefaultId: 0x00040007
SpecData: 3833EA800000000001 000000060000B9AC ACEB80249C8080E4 07A082E8F2BA80
Description: The controller parameter(s) are changed by user
SeqNo: 17                              Device: BAT 1
EventId: 0x00010012                    Severity: Info
TimeStamp: Aug 14, 2018 23:38:53       DefaultId: 0x00010012
Description: The write policy of writeback logical drive switched from writethr
u to writeback
SeqNo: 18                              Device: Ctrl 1
TimeStamp: Aug 14, 2018 23:38:54       DefaultId: 0x00040007
SpecData: 00000000145AAB8024 77F2802477F28061 0000000600000000 000000ECF7EC80
SeqNo: 19                              Device: Ctrl 1
SeqNo: 20                              Device: Subsys
EventId: 0x0011000A                    Severity: Info
TimeStamp: Aug 14, 2018 23:38:56       DefaultId: 0x0011000A
Description: Subsystem parameter(s) are changed by user
SeqNo: 262                             Device: Ctrl 1
TimeStamp: Jul 3, 2018 03:05:38        DefaultId: 0x00040005
SeqNo: 263                             Device: Ctrl 1
TimeStamp: Aug 14, 2018 07:45:39       DefaultId: 0x0004004A
SeqNo: 264                             Device: Ctrl 1
TimeStamp: Aug 14, 2018 07:45:46       DefaultId: 0x00040005
SeqNo: 265                             Device: Ctrl 1
TimeStamp: Aug 14, 2018 08:45:25       DefaultId: 0x00040006
SpecData: 020000000000000000 0000000000000000 0000000000000000 00000000000000
SeqNo: 266                             Device: Ctrl 1
TimeStamp: Aug 14, 2018 08:45:31       DefaultId: 0x00040005
SeqNo: 267                             Device: Ctrl 1
SeqNo: 268                             Device: Ctrl 1
SeqNo: 269                             Device: Ctrl 1
SeqNo: 270                             Device: PD 4
SeqNo: 271                             Device: LD 0
SeqNo: 272                             Device: PD 3
SeqNo: 273                             Device: LD 0
SeqNo: 274                             Device: PD 1
SeqNo: 275                             Device: PD 2
SeqNo: 276                             Device: PD 4
SeqNo: 277                             Device: PD 3
SeqNo: 278                             Device: PD 1
SeqNo: 279                             Device: PD 2
SeqNo: 280                             Device: LD 0
SeqNo: 281                             Device: DA 0
SeqNo: 282                             Device: BAT 1
u to writeback
OS Name: Darwin 15.6.0 x86_64
Host Name: xxxxx
Network Name: lo0
IP Address: 127.0.0.1
Host driver version: 6.2.9
