Pegasus R6 Two drives failure,Help me Please
  • 722 Views
  • Last Post 21 October 2019
王海滨 王 posted this 20 October 2019
First of all, I am a user from China. My English is not good, I am very sorry.
I bought her on the first day of the Pegasus R6 at the Apple Store, and later purchased the Pegasus2 R8, I am a loyal user.
I've been running a Pegasus R6 12 TB RAID 5 array with no troubles for years and now I am having a big issue.
My sixth hard drive showed dead three months ago, and then I stopped the R6 because it was difficult to buy the same hard drive. Recently, because I needed to read the data in the array, I enabled the array again. After three days of working, the fifth hard disk suddenly showed dead, and now I can't access R6.
I don't know if this problem can be solved very well. I understand that the problem lies with me. I am too careless. The data in the hard disk array is very important to me. I feel very nervous. I hope to get your help, thank you.
Below is my problem report.
I am sorry, I can't upload a text file, I will always display an error, I can only copy it in the following post.
wangfenbindePro:~ TiMAX$ promiseutil
Promise Utility
Version: 4.00.0000.09 Build Date: Jul 17, 2017
Type  #    Model         Alias                         WWN                 Seq
hba   1  * Pegasus R6                                  2000-0001-5530-a0c5  1
cliib> subsys -v
Alias:
Vendor: Promise Technology,Inc.        Model: Pegasus R6
PartNo: F29DS6722000000                SerialNo: M74H11812500269
Rev: A2                                WWN: 2000-0001-5530-a0c5
PDSN: N/A
cliib> enclosure -v
Enclosure Setting:
EnclosureId: 1
EnclWarningTempThreshold: 51C/123F     EnclCriticalTempThreshold: 56C/132F
CtrlWarningTempThreshold: 64C/147F     CtrlCriticalTempThreshold: 69C/156F
Enclosure Info and Status:
EnclosureId: 1
EnclosureType: Pegasus R6
SEPFwVersion: 1.00
MaxNumOfControllers: 1                 MaxNumOfPhyDrvSlots: 6
MaxNumOfFans: 1                        MaxNumOfBlowers: 0
MaxNumOfTempSensors: 2                 MaxNumOfPSUs: 1
MaxNumOfBatteries: 0                   MaxNumOfVoltageSensors: 3
PSU       Status
1         Powered On and Functional
Fan Location        FanStatus             HealthyThreshold  CurrentFanSpeed
1   Backplane       Functional            > 500 RPM         1100 RPM
TemperatureSensor   Location       HealthThreshold   CurrentTemp    Status
1                   Controller     < 64C/147F        51C/123F       normal
2                   Backplane      < 51C/123F        44C/111F       normal
VoltageSensor  Type    HealthyThreshold         CurrentVoltage  Status
1              3.3V    +/- 5% (3.13 - 3.46) V   3.2V            Operational
2              5.0V    +/- 5% (4.75 - 5.25) V   4.9V            Operational
3              12.0V   +/- 8% (11.04 - 12.96) V 12.0V           Operational
cliib> ctrl -v
CtrlId: 1
Alias:
OperationalStatus: OK                  PowerOnTime: 46 minutes
LUNAffinity: N/A                       LunmappingMethod: WWN Based
CacheUsagePercentage: 0%               DirtyCachePercentage: 0%
Vendor: PROMISE                        Model: Pegasus R6
HWRev: A2                              WWN: 2000-0001-5530-a0c5
CmdProtocol: SCSI-3
MemType: DDR SDRAM                     MemSize: 512MB
FlashType: Flash Memory                FlashSize: 8MB
NVRAMType: FRAM                        NVRAMSize: 32KB
BootLoaderVersion: 5.02.0000.98        BootLoaderBuildDate: Jun 20, 2013
FirmwareVersion: 5.02.0000.98          FirmwareBuildDate: Jun 20, 2013
SoftwareVersion: 5.02.0000.98          SoftwareBuildDate: Jun 20, 2013
BIOSVersion: 5.02.0000.98              BIOSBuildDate: Jun 20, 2013
SingleImageVersion: 5.02.0000.98       SingleImageBuildDate: Jun 20, 2013
CtrlCPLDVersion: 0.08
DiskArrayPresent: 1                    OverallRAIDStatus: Offline
LogDrvPresent: 1                       LogDrvOnline: 0
LogDrvOffline: 1                       LogDrvCritical: 0
PhyDrvPresent: 6                       PhyDrvOnline: 4
PhyDrvOffline: 2                       PhyDrvPFA: 0
GlobalSparePresent: 0                  DedicatedSparePresent: 0
RevertibleGlobalSparePresent: 0        RevertibleDedicatedSparePresent: 0
RevertibleGlobalSpareUsed: 0           RevertibleDedicatedSpareUsed: 0
WriteThroughMode: No                   MaxSectorSize: 4KB
PreferredCacheLineSize: 64 KB          CacheLineSize: 64 KB
Coercion: Enabled                      CoercionMethod: GBTruncate
SMART: Enabled                         SMARTPollingInterval: 10 minutes
MigrationStorage: DDF                  CacheFlushInterval: 3 second(s)
PollInterval: 15 second(s)             AdaptiveWBCache: Disabled
ForcedReadAhead: Disabled
PowerSavingLevel: 1                    SpindownType: N/A
IdleTimeToParkRwHeads: Never           IdleTimeToLowerRotationSpeed: Never
IdleTimeToSpinDown: Never
SGPIOBackPlane: Default/Generic (0)    SASReadyLED: Off
SpinUpDelay: 0 millisecond             PowerManagement: Enable
SecurityAdminPassword: N/A
PciFuncAddr: N/A                       PciLinkSpeed: N/A
PciLinkWidth: N/A
cliib> phydrv -v
PdId: 1
Alias:
PhysicalCapacity: 2TB                  ConfigurableCapacity: 2TB
UsedCapacity: 2TB                      LogicalBlockSize: 512Bytes
ConfigStatus: Array0 No.0              Location: Encl1 Slot1
ModelNo: Hitachi HUA72302
SerialNo: MK0271YGK3HZ7A               FirmwareVersion: MK7OAA10
DriveInterface: SATA 3Gb/s             Protocol: ATA/ATAPI-8
WriteCacheSupport: Yes                 WriteCache: Enabled
RLACacheSupport: Yes                   RLACache: Enabled
SMARTFeatureSetSupport: Yes
SMARTSelfTestSetSupport: Yes           SMARTErrorLoggingSupport: Yes
CmdQueuingSupport: NCQ                 CmdQueuing: Enabled
CmdQueueDepth: 32                      MediumErrorThreshold: 64
Errors: 0                              NonRWErrors: 0
ReadErrors: 0                          WriteErrors: 0
PowerSavingStatus: Full Power          TemperaturePollingInterval: 30 minutes
DriveTemperature: 26C/78F              ReferenceDriveTemperature: N/A
Flags: N/A                             LastUnconfiguredFragement: N/A
PhysicalSectorSize: 0Byte
PdId: 2
Alias:
ConfigStatus: Array0 No.1              Location: Encl1 Slot2
ModelNo: Hitachi HDS72302
SerialNo: MN5220F32168SK               FirmwareVersion: MN6OA5C0
DriveTemperature: 25C/77F              ReferenceDriveTemperature: N/A
PdId: 3
Alias:
ConfigStatus: Array0 No.2              Location: Encl1 Slot3
SerialNo: MN1220F324BJ3D               FirmwareVersion: MN6OA5C0
PdId: 4
Alias:
ConfigStatus: Array0 No.3              Location: Encl1 Slot4
SerialNo: MN1220F324BLAD               FirmwareVersion: MN6OA5C0
PdId: 5
OperationalStatus: Dead
Alias:
ConfigStatus: Array0 No.4              Location: Encl1 Slot5
SerialNo: MN5220F322GWSK               FirmwareVersion: MN6OA5C0
PdId: 6
Alias:
ConfigStatus: Array0 No.5              Location: Encl1 Slot6
ModelNo: TOSHIBA DT01ACA2
SerialNo: 16GTP65TS                    FirmwareVersion: MX4OABB0
DriveTemperature: N/A                  ReferenceDriveTemperature: N/A
cliib> array -v
DaId: 0
OperationalStatus: Degraded
Alias:
PhysicalCapacity: 12TB                 ConfigurableCapacity: 12TB
FreeCapacity: 0Byte                    MaxContiguousCapacity: 0Byte
AvailableRAIDLevels: 0 5 6 10 50 1E
PDM: Enabled                           MediaPatrol: Enabled
NumberOfPhysicalDrives: 6              NumberOfLogicalDrives: 1
NumberOfDedicatedSpares: 0
UserSetPowerSavingLevel: 1             CurrentPowerSavingLevel: 0
PowerManagement: Enabled
Physical Drives in the Array:
0     1    2TB         401.41KB     OK
1     2    2TB         401.41KB     OK
2     3    2TB         401.41KB     OK
3     4    2TB         401.41KB     OK
4     5    2TB         401.41KB     Dead
5     6    2TB         401.41KB     Dead
Logical Drives in the Array:
LdId Alias          RAIDLevel Capacity  OpStatus
0                   RAID5     10TB      Offline
Id  OpStatus  PdId CfgCapacity Revertible Type      DedicatedToArray
cliib> logdrv -v
LdId: 0
ArrayId: 0                             SYNCed: Yes
OperationalStatus: Offline
Alias:                                 TRIMSupport: Support TRIM
SerialNo: 00000000000000000000000077691489BDE649B9
WWN: 2228-0001-5545-eb7d               PreferredCtrlId: N/A
RAIDLevel: RAID5                       StripeSize: 128KB
Capacity: 10TB                         PhysicalCapacity: 12TB
ReadPolicy: ReadAhead                  WritePolicy: WriteBack
CurrentWritePolicy: WriteBack
NumOfUsedPD: 6                         NumOfAxles: 1
SectorSize: 512Bytes                   RAID5&6Algorithm: right asymmetric (4)
TolerableNumOfDeadDrivesPerAxle: 1     ParityPace: N/A
CodecScheme: N/A
cliib> checktable -l 0
Ld Id: 0
Read Check Table
#         Starting Logical Block Address     Count
0         8118964640                         1
1         4294967296                         0
2         0                                  0
No write check table entry available
No inconsistent block table entry available
cliib> event
Seq   Device          Severity TimeStamp             Description
0     Ctrl 1          Info     Oct 20, 2019 10:15:38 The system is started
1     SEP 1           Info     Oct 20, 2019 10:15:38 SEP is found
2     LD 0            Major    Oct 20, 2019 10:15:38 Logical drive has been
                                                     placed offline. Possible
                                                     Data Loss
3     PD 6            Major    Oct 20, 2019 10:31:23 Physical Disk is marked
                                                     as DEAD due to removal
4     PD 6            Warning  Oct 20, 2019 10:31:23 Physical Disk has been
                                                     removed
5     PD 6            Warning  Oct 20, 2019 10:33:10 A configured dead
                                                     physical disk has been
                                                     inserted
6     PD 6            Info     Oct 20, 2019 10:33:10 Physical Disk has been
                                                     inserted
7     PD 6            Major    Oct 20, 2019 10:39:53 Physical Disk is marked
8     PD 6            Warning  Oct 20, 2019 10:39:53 Physical Disk has been
                                                     removed
9     PD 6            Warning  Oct 20, 2019 10:41:17 A configured dead
                                                     inserted
10    PD 6            Info     Oct 20, 2019 10:41:17 Physical Disk has been
                                                     inserted
cliib> event -l nvram
4123  PD 6            Warning  Oct 16, 2019 09:24:16 Physical Disk has been
                                                     removed
4124  PD 6            Major    Oct 16, 2019 09:25:48 Physical Disk is marked
4125  PD 6            Warning  Oct 16, 2019 09:25:48 Physical Disk has been
                                                     removed
4126  PD 6            Major    Oct 16, 2019 09:28:20 Physical Disk is marked
4127  PD 6            Warning  Oct 16, 2019 09:28:20 Physical Disk has been
                                                     removed
4128  PD 6            Major    Oct 16, 2019 09:47:29 Physical Disk is marked
4129  PD 6            Warning  Oct 16, 2019 09:47:29 Physical Disk has been
                                                     removed
4130  PD 6            Major    Oct 16, 2019 09:50:47 Physical Disk is marked
4131  PD 6            Warning  Oct 16, 2019 09:50:48 Physical Disk has been
                                                     removed
4132  PD 6            Major    Oct 16, 2019 09:54:48 Physical Disk is marked
4133  PD 6            Warning  Oct 16, 2019 09:54:48 Physical Disk has been
                                                     removed
4134  Ctrl 1          Info     Oct 16, 2019 19:06:37 The system is stopped
4135  Ctrl 1          Info     Oct 18, 2019 05:21:17 The system is started
4136  LD 0            Major    Oct 18, 2019 05:21:17 Logical drive has been
                                                     set to critical
4137  PD 6            Major    Oct 18, 2019 05:24:25 Physical Disk is marked
4138  PD 6            Warning  Oct 18, 2019 05:24:25 Physical Disk has been
                                                     removed
4139  Ctrl 1          Info     Oct 18, 2019 05:29:00 The system is stopped
4140  Ctrl 1          Info     Oct 18, 2019 15:15:11 The system is started
4141  LD 0            Major    Oct 18, 2019 15:15:11 Logical drive has been
                                                     set to critical
4142  PD 6            Major    Oct 18, 2019 15:16:58 Physical Disk is marked
4143  PD 6            Warning  Oct 18, 2019 15:16:58 Physical Disk has been
                                                     removed
4144  PD 6            Major    Oct 18, 2019 15:17:25 Physical Disk is marked
4145  PD 6            Warning  Oct 18, 2019 15:17:25 Physical Disk has been
                                                     removed
4146  PD 5            Major    Oct 18, 2019 15:27:30 Physical Disk is marked
4147  LD 0            Major    Oct 18, 2019 15:27:30 Logical drive has been
                                                     Data Loss
4148  PD 5            Warning  Oct 18, 2019 15:27:30 Physical Disk has been
                                                     removed
4149  PD 6            Major    Oct 18, 2019 15:27:39 Physical Disk is marked
4150  PD 6            Warning  Oct 18, 2019 15:27:39 Physical Disk has been
                                                     removed
4151  Ctrl 1          Info     Oct 18, 2019 15:32:06 The system is stopped
4152  Ctrl 1          Info     Oct 18, 2019 16:04:13 The system is started
4153  LD 0            Major    Oct 18, 2019 16:04:13 Logical drive has been
                                                     Data Loss
4154  Ctrl 1          Info     Oct 18, 2019 16:05:50 The system is stopped
4155  Ctrl 1          Info     Oct 18, 2019 16:06:50 The system is started
4156  LD 0            Major    Oct 18, 2019 16:06:50 Logical drive has been
                                                     Data Loss
4157  Ctrl 1          Info     Oct 18, 2019 16:07:51 The system is stopped
4158  Ctrl 1          Info     Oct 20, 2019 09:16:59 The system is started
4159  PD 1            Warning  Oct 20, 2019 10:01:59 Previously configured
                                                     disk is no longer found
4160  PD 2            Warning  Oct 20, 2019 10:01:59 Previously configured
4161  PD 3            Warning  Oct 20, 2019 10:01:59 Previously configured
4162  PD 4            Warning  Oct 20, 2019 10:01:59 Previously configured
4163  DA 0            Warning  Oct 20, 2019 10:01:59 The array is incomplete.
                                                     One or more physical
                                                     drives are missing.
4164  Ctrl 1          Info     Oct 20, 2019 10:02:11 The system is stopped
4165  Ctrl 1          Info     Oct 20, 2019 10:06:59 The system is started
4166  LD 0            Major    Oct 20, 2019 10:06:59 Logical drive has been
                                                     Data Loss
4167  PD 6            Major    Oct 20, 2019 10:07:32 Physical Disk is marked
4168  PD 6            Warning  Oct 20, 2019 10:07:32 Physical Disk has been
                                                     removed
4169  PD 6            Major    Oct 20, 2019 10:08:23 Physical Disk is marked
4170  PD 6            Warning  Oct 20, 2019 10:08:23 Physical Disk has been
                                                     removed
4171  PD 6            Major    Oct 20, 2019 10:08:46 Physical Disk is marked
4172  PD 6            Warning  Oct 20, 2019 10:08:46 Physical Disk has been
                                                     removed
4173  PD 6            Major    Oct 20, 2019 10:10:36 Physical Disk is marked
4174  PD 6            Warning  Oct 20, 2019 10:10:36 Physical Disk has been
                                                     removed
4175  PD 6            Major    Oct 20, 2019 10:10:59 Physical Disk is marked
4176  PD 6            Warning  Oct 20, 2019 10:10:59 Physical Disk has been
                                                     removed
4177  PD 6            Major    Oct 20, 2019 10:14:07 Physical Disk is marked
4178  PD 6            Warning  Oct 20, 2019 10:14:07 Physical Disk has been
                                                     removed
4179  Ctrl 1          Info     Oct 20, 2019 10:15:04 The system is stopped
4180  Ctrl 1          Info     Oct 20, 2019 10:15:38 The system is started
4181  LD 0            Major    Oct 20, 2019 10:15:38 Logical drive has been
                                                     Data Loss
4182  PD 6            Major    Oct 20, 2019 10:31:23 Physical Disk is marked
4183  PD 6            Warning  Oct 20, 2019 10:31:23 Physical Disk has been
                                                     removed
4184  PD 6            Major    Oct 20, 2019 10:39:53 Physical Disk is marked
4185  PD 6            Warning  Oct 20, 2019 10:39:53 Physical Disk has been
                                                     removed
cliib>
Wendy Wei posted this 21 October 2019
Please call our local support at:
021-32140395-164
Wendy
王海滨 王 posted this 21 October 2019
你好
请致电我们的本地支持:
021-32140395-164
谢谢。
温迪
 Thank you !
