wangfenbindePro:~ TiMAX$ promiseutil
Promise Utility
Version: 4.00.0000.09 Build Date: Jul 17, 2017
Type # Model Alias WWN Seq
hba 1 * Pegasus R6 2000-0001-5530-a0c5 1
cliib> subsys -v
Alias:
Vendor: Promise Technology,Inc. Model: Pegasus R6
PartNo: F29DS6722000000 SerialNo: M74H11812500269
Rev: A2 WWN: 2000-0001-5530-a0c5
PDSN: N/A
cliib> enclosure -v
Enclosure Setting:
EnclosureId: 1
EnclWarningTempThreshold: 51C/123F EnclCriticalTempThreshold: 56C/132F
CtrlWarningTempThreshold: 64C/147F CtrlCriticalTempThreshold: 69C/156F
Enclosure Info and Status:
EnclosureId: 1
EnclosureType: Pegasus R6
SEPFwVersion: 1.00
MaxNumOfControllers: 1 MaxNumOfPhyDrvSlots: 6
MaxNumOfFans: 1 MaxNumOfBlowers: 0
MaxNumOfTempSensors: 2 MaxNumOfPSUs: 1
MaxNumOfBatteries: 0 MaxNumOfVoltageSensors: 3
PSU Status
1 Powered On and Functional
Fan Location FanStatus HealthyThreshold CurrentFanSpeed
1 Backplane Functional > 500 RPM 1100 RPM
TemperatureSensor Location HealthThreshold CurrentTemp Status
1 Controller < 64C/147F 51C/123F normal
2 Backplane < 51C/123F 44C/111F normal
VoltageSensor Type HealthyThreshold CurrentVoltage Status
1 3.3V +/- 5% (3.13 - 3.46) V 3.2V Operational
2 5.0V +/- 5% (4.75 - 5.25) V 4.9V Operational
3 12.0V +/- 8% (11.04 - 12.96) V 12.0V Operational
cliib> ctrl -v
CtrlId: 1
Alias:
OperationalStatus: OK PowerOnTime: 46 minutes
LUNAffinity: N/A LunmappingMethod: WWN Based
CacheUsagePercentage: 0% DirtyCachePercentage: 0%
Vendor: PROMISE Model: Pegasus R6
HWRev: A2 WWN: 2000-0001-5530-a0c5
CmdProtocol: SCSI-3
MemType: DDR SDRAM MemSize: 512MB
FlashType: Flash Memory FlashSize: 8MB
NVRAMType: FRAM NVRAMSize: 32KB
BootLoaderVersion: 5.02.0000.98 BootLoaderBuildDate: Jun 20, 2013
FirmwareVersion: 5.02.0000.98 FirmwareBuildDate: Jun 20, 2013
SoftwareVersion: 5.02.0000.98 SoftwareBuildDate: Jun 20, 2013
BIOSVersion: 5.02.0000.98 BIOSBuildDate: Jun 20, 2013
SingleImageVersion: 5.02.0000.98 SingleImageBuildDate: Jun 20, 2013
CtrlCPLDVersion: 0.08
DiskArrayPresent: 1 OverallRAIDStatus: Offline
LogDrvPresent: 1 LogDrvOnline: 0
LogDrvOffline: 1 LogDrvCritical: 0
PhyDrvPresent: 6 PhyDrvOnline: 4
PhyDrvOffline: 2 PhyDrvPFA: 0
GlobalSparePresent: 0 DedicatedSparePresent: 0
RevertibleGlobalSparePresent: 0 RevertibleDedicatedSparePresent: 0
RevertibleGlobalSpareUsed: 0 RevertibleDedicatedSpareUsed: 0
WriteThroughMode: No MaxSectorSize: 4KB
PreferredCacheLineSize: 64 KB CacheLineSize: 64 KB
Coercion: Enabled CoercionMethod: GBTruncate
SMART: Enabled SMARTPollingInterval: 10 minutes
MigrationStorage: DDF CacheFlushInterval: 3 second(s)
PollInterval: 15 second(s) AdaptiveWBCache: Disabled
ForcedReadAhead: Disabled
PowerSavingLevel: 1 SpindownType: N/A
IdleTimeToParkRwHeads: Never IdleTimeToLowerRotationSpeed: Never
IdleTimeToSpinDown: Never
SGPIOBackPlane: Default/Generic (0) SASReadyLED: Off
SpinUpDelay: 0 millisecond PowerManagement: Enable
SecurityAdminPassword: N/A
PciFuncAddr: N/A PciLinkSpeed: N/A
PciLinkWidth: N/A
cliib> phydrv -v
PdId: 1
Alias:
PhysicalCapacity: 2TB ConfigurableCapacity: 2TB
UsedCapacity: 2TB LogicalBlockSize: 512Bytes
ConfigStatus: Array0 No.0 Location: Encl1 Slot1
ModelNo: Hitachi HUA72302
SerialNo: MK0271YGK3HZ7A FirmwareVersion: MK7OAA10
DriveInterface: SATA 3Gb/s Protocol: ATA/ATAPI-8
WriteCacheSupport: Yes WriteCache: Enabled
RLACacheSupport: Yes RLACache: Enabled
SMARTFeatureSetSupport: Yes
SMARTSelfTestSetSupport: Yes SMARTErrorLoggingSupport: Yes
CmdQueuingSupport: NCQ CmdQueuing: Enabled
CmdQueueDepth: 32 MediumErrorThreshold: 64
Errors: 0 NonRWErrors: 0
ReadErrors: 0 WriteErrors: 0
PowerSavingStatus: Full Power TemperaturePollingInterval: 30 minutes
DriveTemperature: 26C/78F ReferenceDriveTemperature: N/A
Flags: N/A LastUnconfiguredFragement: N/A
PhysicalSectorSize: 0Byte
PdId: 2
Alias:
ConfigStatus: Array0 No.1 Location: Encl1 Slot2
ModelNo: Hitachi HDS72302
SerialNo: MN5220F32168SK FirmwareVersion: MN6OA5C0
DriveTemperature: 25C/77F ReferenceDriveTemperature: N/A
PdId: 3
Alias:
ConfigStatus: Array0 No.2 Location: Encl1 Slot3
SerialNo: MN1220F324BJ3D FirmwareVersion: MN6OA5C0
PdId: 4
Alias:
ConfigStatus: Array0 No.3 Location: Encl1 Slot4
SerialNo: MN1220F324BLAD FirmwareVersion: MN6OA5C0
PdId: 5
OperationalStatus: Dead
Alias:
ConfigStatus: Array0 No.4 Location: Encl1 Slot5
SerialNo: MN5220F322GWSK FirmwareVersion: MN6OA5C0
PdId: 6
Alias:
ConfigStatus: Array0 No.5 Location: Encl1 Slot6
ModelNo: TOSHIBA DT01ACA2
SerialNo: 16GTP65TS FirmwareVersion: MX4OABB0
DriveTemperature: N/A ReferenceDriveTemperature: N/A
cliib> array -v
DaId: 0
OperationalStatus: Degraded
Alias:
PhysicalCapacity: 12TB ConfigurableCapacity: 12TB
FreeCapacity: 0Byte MaxContiguousCapacity: 0Byte
AvailableRAIDLevels: 0 5 6 10 50 1E
PDM: Enabled MediaPatrol: Enabled
NumberOfPhysicalDrives: 6 NumberOfLogicalDrives: 1
NumberOfDedicatedSpares: 0
UserSetPowerSavingLevel: 1 CurrentPowerSavingLevel: 0
PowerManagement: Enabled
Physical Drives in the Array:
0 1 2TB 401.41KB OK
1 2 2TB 401.41KB OK
2 3 2TB 401.41KB OK
3 4 2TB 401.41KB OK
4 5 2TB 401.41KB Dead
5 6 2TB 401.41KB Dead
Logical Drives in the Array:
LdId Alias RAIDLevel Capacity OpStatus
0 RAID5 10TB Offline
Id OpStatus PdId CfgCapacity Revertible Type DedicatedToArray
cliib> logdrv -v
LdId: 0
ArrayId: 0 SYNCed: Yes
OperationalStatus: Offline
Alias: TRIMSupport: Support TRIM
SerialNo: 00000000000000000000000077691489BDE649B9
WWN: 2228-0001-5545-eb7d PreferredCtrlId: N/A
RAIDLevel: RAID5 StripeSize: 128KB
Capacity: 10TB PhysicalCapacity: 12TB
ReadPolicy: ReadAhead WritePolicy: WriteBack
CurrentWritePolicy: WriteBack
NumOfUsedPD: 6 NumOfAxles: 1
SectorSize: 512Bytes RAID5&6Algorithm: right asymmetric (4)
TolerableNumOfDeadDrivesPerAxle: 1 ParityPace: N/A
CodecScheme: N/A
cliib> checktable -l 0
Ld Id: 0
Read Check Table
# Starting Logical Block Address Count
0 8118964640 1
1 4294967296 0
2 0 0
No write check table entry available
No inconsistent block table entry available
cliib> event
Seq Device Severity TimeStamp Description
0 Ctrl 1 Info Oct 20, 2019 10:15:38 The system is started
1 SEP 1 Info Oct 20, 2019 10:15:38 SEP is found
2 LD 0 Major Oct 20, 2019 10:15:38 Logical drive has been
placed offline. Possible
Data Loss
3 PD 6 Major Oct 20, 2019 10:31:23 Physical Disk is marked
as DEAD due to removal
4 PD 6 Warning Oct 20, 2019 10:31:23 Physical Disk has been
removed
5 PD 6 Warning Oct 20, 2019 10:33:10 A configured dead
physical disk has been
inserted
6 PD 6 Info Oct 20, 2019 10:33:10 Physical Disk has been
inserted
7 PD 6 Major Oct 20, 2019 10:39:53 Physical Disk is marked
8 PD 6 Warning Oct 20, 2019 10:39:53 Physical Disk has been
removed
9 PD 6 Warning Oct 20, 2019 10:41:17 A configured dead
inserted
10 PD 6 Info Oct 20, 2019 10:41:17 Physical Disk has been
inserted
cliib> event -l nvram
4123 PD 6 Warning Oct 16, 2019 09:24:16 Physical Disk has been
removed
4124 PD 6 Major Oct 16, 2019 09:25:48 Physical Disk is marked
4125 PD 6 Warning Oct 16, 2019 09:25:48 Physical Disk has been
removed
4126 PD 6 Major Oct 16, 2019 09:28:20 Physical Disk is marked
4127 PD 6 Warning Oct 16, 2019 09:28:20 Physical Disk has been
removed
4128 PD 6 Major Oct 16, 2019 09:47:29 Physical Disk is marked
4129 PD 6 Warning Oct 16, 2019 09:47:29 Physical Disk has been
removed
4130 PD 6 Major Oct 16, 2019 09:50:47 Physical Disk is marked
4131 PD 6 Warning Oct 16, 2019 09:50:48 Physical Disk has been
removed
4132 PD 6 Major Oct 16, 2019 09:54:48 Physical Disk is marked
4133 PD 6 Warning Oct 16, 2019 09:54:48 Physical Disk has been
removed
4134 Ctrl 1 Info Oct 16, 2019 19:06:37 The system is stopped
4135 Ctrl 1 Info Oct 18, 2019 05:21:17 The system is started
4136 LD 0 Major Oct 18, 2019 05:21:17 Logical drive has been
set to critical
4137 PD 6 Major Oct 18, 2019 05:24:25 Physical Disk is marked
4138 PD 6 Warning Oct 18, 2019 05:24:25 Physical Disk has been
removed
4139 Ctrl 1 Info Oct 18, 2019 05:29:00 The system is stopped
4140 Ctrl 1 Info Oct 18, 2019 15:15:11 The system is started
4141 LD 0 Major Oct 18, 2019 15:15:11 Logical drive has been
set to critical
4142 PD 6 Major Oct 18, 2019 15:16:58 Physical Disk is marked
4143 PD 6 Warning Oct 18, 2019 15:16:58 Physical Disk has been
removed
4144 PD 6 Major Oct 18, 2019 15:17:25 Physical Disk is marked
4145 PD 6 Warning Oct 18, 2019 15:17:25 Physical Disk has been
removed
4146 PD 5 Major Oct 18, 2019 15:27:30 Physical Disk is marked
4147 LD 0 Major Oct 18, 2019 15:27:30 Logical drive has been
Data Loss
4148 PD 5 Warning Oct 18, 2019 15:27:30 Physical Disk has been
removed
4149 PD 6 Major Oct 18, 2019 15:27:39 Physical Disk is marked
4150 PD 6 Warning Oct 18, 2019 15:27:39 Physical Disk has been
removed
4151 Ctrl 1 Info Oct 18, 2019 15:32:06 The system is stopped
4152 Ctrl 1 Info Oct 18, 2019 16:04:13 The system is started
4153 LD 0 Major Oct 18, 2019 16:04:13 Logical drive has been
Data Loss
4154 Ctrl 1 Info Oct 18, 2019 16:05:50 The system is stopped
4155 Ctrl 1 Info Oct 18, 2019 16:06:50 The system is started
4156 LD 0 Major Oct 18, 2019 16:06:50 Logical drive has been
Data Loss
4157 Ctrl 1 Info Oct 18, 2019 16:07:51 The system is stopped
4158 Ctrl 1 Info Oct 20, 2019 09:16:59 The system is started
4159 PD 1 Warning Oct 20, 2019 10:01:59 Previously configured
disk is no longer found
4160 PD 2 Warning Oct 20, 2019 10:01:59 Previously configured
4161 PD 3 Warning Oct 20, 2019 10:01:59 Previously configured
4162 PD 4 Warning Oct 20, 2019 10:01:59 Previously configured
4163 DA 0 Warning Oct 20, 2019 10:01:59 The array is incomplete.
One or more physical
drives are missing.
4164 Ctrl 1 Info Oct 20, 2019 10:02:11 The system is stopped
4165 Ctrl 1 Info Oct 20, 2019 10:06:59 The system is started
4166 LD 0 Major Oct 20, 2019 10:06:59 Logical drive has been
Data Loss
4167 PD 6 Major Oct 20, 2019 10:07:32 Physical Disk is marked
4168 PD 6 Warning Oct 20, 2019 10:07:32 Physical Disk has been
removed
4169 PD 6 Major Oct 20, 2019 10:08:23 Physical Disk is marked
4170 PD 6 Warning Oct 20, 2019 10:08:23 Physical Disk has been
removed
4171 PD 6 Major Oct 20, 2019 10:08:46 Physical Disk is marked
4172 PD 6 Warning Oct 20, 2019 10:08:46 Physical Disk has been
removed
4173 PD 6 Major Oct 20, 2019 10:10:36 Physical Disk is marked
4174 PD 6 Warning Oct 20, 2019 10:10:36 Physical Disk has been
removed
4175 PD 6 Major Oct 20, 2019 10:10:59 Physical Disk is marked
4176 PD 6 Warning Oct 20, 2019 10:10:59 Physical Disk has been
removed
4177 PD 6 Major Oct 20, 2019 10:14:07 Physical Disk is marked
4178 PD 6 Warning Oct 20, 2019 10:14:07 Physical Disk has been
removed
4179 Ctrl 1 Info Oct 20, 2019 10:15:04 The system is stopped
4180 Ctrl 1 Info Oct 20, 2019 10:15:38 The system is started
4181 LD 0 Major Oct 20, 2019 10:15:38 Logical drive has been
Data Loss
4182 PD 6 Major Oct 20, 2019 10:31:23 Physical Disk is marked
4183 PD 6 Warning Oct 20, 2019 10:31:23 Physical Disk has been
removed
4184 PD 6 Major Oct 20, 2019 10:39:53 Physical Disk is marked
4185 PD 6 Warning Oct 20, 2019 10:39:53 Physical Disk has been
removed
cliib>
