Pegasus R6 Drive Replacement - "Rebuild" Grayed out
  • 764 Views
  • Last Post 12 December 2017
Howard McCabe posted this 12 December 2017
I have an R6 configured Raid 5.
One drive reported as "Stale"
Replaced the Drive.
Unlocked the Utility
Chose "Unconfigured" for the new drive and "Saved"
Unfortunately "Rebuild" is grayed out.
What do I do next?   Living on the edge with one drive down.
thank you!!!!!
Howard
Pradeep Chidambaranath posted this 12 December 2017
Hi Howard,
Please make sure to unlock the utility to start the rebuilding process. Click the padlock on the left bottom corner of the screen and type your system password to unlock the utility.
If you still have any issues, please go to https://support.promise.com to create a support ticket with the latest subsystem report for further investigation.
- Open Promise Utility.
Yes I unlocked the utility.   Do I need to format the disk with Apple "Disk Utility"?
