Pegasus R6 Controller nearing healthy threshold , any way to ramp up fans manually?
  • 92 Views
  • Last Post 02 January 2024
James Lee posted this 02 December 2023
Pegasus R6 Controller nearing healthy threshold , any way to ramp up fans manually? Healthy and Current Temps are 1 degree away. Similar for backplane
R P posted this 04 December 2023
Hi James,
If the enviornment itself is not too hot, a common problem with older computer and storage devices is dust. It can block airflow and prevent proper cooling. If this is the problem it is easily fixed with a can of compressed air.
James Lee posted this 24 December 2023
Hi R P ,
It is actually a new old stock unit so there is no dust build up. In the first few weeks it used to ramp its fans really nosily up to 2400RPM and now i can barely beg it to reach 1500.. Anyways to force it to ramp it to higher speeds?
R P posted this 02 January 2024
Hi James,
There was an issue years ago with the fans ramping up, this was fixed in firmware. Please check your firmware and update it if necessary. This is the latest firmware for the Pegasus1.
If the Pegasus is not running hot, there is no reason to ramp the fans up.
