Pegasus3 R4 on Big Sur
  • 1.3K Views
  • Last Post 14 December 2020
Marcus Adriansson posted this 05 September 2020
Hello!
First: I am aware that I have installed beta software and I will have to blame myself for getting a beta experience from that :)
But with that said... I installed the latest macOS Big Sur developer beta version (20A5364e) yesterday (since I am a developer of apps) and my Promise R4 wont mount anymore. Its present in system information (see screenshot) but not in disc utilities. Anyone else have this problem and is there a solution? I re-installed drivers and the "Promise utility-app" but no luck.
Thank you! :)
Best,
Marcus
R P posted this 14 December 2020
Hi Ian,
The drivers and utility are backwards compatible, please use the latest driver and utility from the Pegasus32 downloads.
Ian Eisenberg posted this 12 December 2020
I have tried with the current driver (from 2010) but can not get it to mount. Is there another driver I am missing?
william keene posted this 24 November 2020
I Installed the GM-version of Big Sur on my Mac Pro and the Pegasus2 R4 disks mounted just fine. However The Promise Utility.app (version 4.04.0000.42) does not work. Does anyone else have this issue and if so, is their a fix?
Did you install the mac driver? The utility app is working fine for me on Big Sur.
William
Marcus Adriansson posted this 20 November 2020
I have no issues with version 4.04.0000.40. Now I'm afraid to upgrade ;)
Harry Towner posted this 20 November 2020
Marcus Adriansson posted this 13 November 2020
A short follow up on this is that I installed the official version of Big Sur yesterday and now my promise-drive is mounting fine without any script when I start up.
So, anyone that still have problems, I recommend installing the GM-version of Big Sur now :)
Eduardo Araquel posted this 10 September 2020
Unfortunately I get the following error when I run this line in Terminal...
Executing: /usr/bin/kmutil load -p /System/Library/Extensions/PromiseSTEX.kext
Error: Error Domain=KMErrorDomain Code=1 "Error occurred while building cache:
1: One or more binaries has an error which prevented linking.  See other errors.
2: Could not use 'com.promise.r2p.icon' because: Cannot find symbol for metaclass pointed to by '__ZN13Pegasus2R2USB10superClassE'.  Expected symbol '__ZN28IOSCSIPeripheralDeviceType0010gMetaClassE' to be defined in another kext
com.promise.r2p.icon specific:
1: Cannot find symbol for metaclass pointed to by '__ZN13Pegasus2R2USB10superClassE'.  Expected symbol '__ZN28IOSCSIPeripheralDeviceType0010gMetaClassE' to be defined in another kext
" UserInfo={NSLocalizedDescription=Error occurred while building cache:
Looks like it doesn't like the com.promise.r2p.icon extension that is installed on my system.
Marcus Adriansson posted this 10 September 2020
Download and install the latest driver (PromiseSTEX) which wil be gone after you reboot Mac. So, in Terminal, execute this;
sudo kextload /System/Library/Extensions/PromiseSTEX.kext
Everytime you reboot Mac, you shoud do this. So, I have made small application by Automator and put it in login items. This is the same situation as that NAS fails to mount up through SMB.
Smart man! Worked nicely :) Thank you!
Best,
Marcus
Katsu Takenaka posted this 10 September 2020
Marcus Adriansson posted this 09 September 2020
I downloaded the last R_MacDrv_V6.2.9 driver from the support page and after the installer finished the drive mounted. At this point I force Quit the installer as restarting reverts to the missing volume behaviour.
While it is mounted the Promise Utility also works as expected.
I attempted this but after the install completes and I force quit the installer, the drives do not mount. Is there some other trick I'm missing here?
Ed
Hey Ed! No other "tricks" required, I ran the installer and when it was done I just force quit it instead of restarting my mac. Seems to be working for most ppl.
Best,
Marcus
Pieter Pretorius posted this 09 September 2020
I cannot find this driver on the support page. Is a link possible?
Edit: I found the driver, did what you said, and it worked!!!!!!!!!!
Pieter.
Eduardo Araquel posted this 08 September 2020
Ed
Robert Bousfield posted this 05 September 2020
Well look at that, it worked :) Thank you Rob!
Glad it helped :) Yes, hope this is fixed by Apple in the next release. I did file a Feedback Ticket to make them aware.
Excited to see if it will get fixed in future versions of macOS or if Promise will release a driver update.
Same behaviour here with a Pegasus2 R4 unit. It was working in previous beta versions so something has changed in the last release.
Rob
  • Marcus Adriansson
