Just purchased a Pegasus3 R4 and it won't mount on my iMac 2017 27" desktop. Is there anything I need to do other than connect with the thunderbollt 3 connector?
Pegasus R3 won't mount
- 875 Views
- Last Post 29 July 2017
Ben Kupfer
posted this
29 July 2017
Pradeep Chidambaranath
posted this
29 July 2017
Hi Ben,
Please install the Pegasus3 drivers for MAC for the volume to be mounted. Kindly go to the link below to download the drivers.
https://www.promise.com/DownloadFile.aspx?DownloadFileUID=4535
Also, please make sure to use the compatible thunderbolt3 to thunderbolt2 adapters. Kindly go to the link below to download the compatibility list.
https://www.promise.com/DownloadFile.aspx?DownloadFileUID=4534
Ben Kupfer
posted this
29 July 2017
Thanks. As soon as I posted this I realized I hadn't installed drivers. The Quick Start booklet that comes with the RAID doesn't mention this... probably should.
posted this
29 July 2017
Hi Ben,
Thank you for the update.
