Pegasus R3-4 on 2013 mac with Thunderbolt 2-3 adapter Voltage Temperature Issue
  • 893 Views
  • Last Post 27 January 2017
F S posted this 26 January 2017
I am running a brand new Pegasus R3-4 on a rather old (late 2013 ) imac with the apple thunderbolt 2-3 adapter  with a Pegus 2 M4 daisy chained after the R3-4 (also with an apple adpter thunderbolt 2-3)
No specific issue in operating except that I get
Temperature 1 critical
Temperature 2 : normal
Voltage 1 : ok
Voltage 2 : ok
Voltage 3 : critical
immediately upon powering up while the status description for the enclosure remains on " loading " and never loads.
The Pegasus 2 M4 daisy chained after the R3-4 is all ok with no diagnostic issues.
Any help appreciated, although the issue does not seem to affect usage ( but you never know...) and there is no warm area detectable by touch on the R3-4 which sits by itself in a well ventilated and air conditionned room. ( and it is winter in Hong Kong )
F S posted this 27 January 2017
Thank you for your prompt feedback.
I have contacted support. Please feel free to delete post .
Dinesh Kannusamy posted this 26 January 2017
Please contact promise Tech support for further assitance or you can also create a web support case in support.promise.com
http://www.promise.com/ContactUS/APAC
Thanks..
