Pegasus 32r4 makes an annoying electronic sound.
  • 24 Views
  • Last Post 12 August 2020
Jim Fairchild posted this 10 August 2020
My Pegasus 32r4 makes an annoying electronic sound. I can't find in the manual what is the purpose for the sound nor how to turn it off.
Can anyone explain how to disable the sound? (I have a 2019 iMac computer if that helps.)
Thanks, Jim
Ranjith kumar posted this 12 August 2020
Hi Jim,
To turn off the beep sound:
-Click Dashboard icon, then click controller link.
-Click Device menu, Choose Component list
-Mouse Over and click the buzzer, then click Setting button.
-Uncheck the enable Buzzer box to disable the buzzer.
-Click Save button.
If you see any abnormal status on the Promise utility, kindly get the subsystem report
and create a web support case at support.promise.com to help you.
