Pegasus 3 R8 PC Speed Test - Slow
  • 1.2K Views
  • Last Post 06 November 2017
Mike Quigley posted this 07 July 2017
Hi all,
I just got the Pegasus 3 R8 32tb (PC edition). It's connected to a thunderbolt 3 port. I have a beast f a machine running i76950x, 128gb ram, geforce gtx 1080ti 11gb,
I have the RAID set to RAID0.
I've been running some tests with Blackmagic Speed test and I'm only getting at best 380mbp/s. I was expecting to see something around the 700 mbp/s mark...anyone???
Dinesh Kannusamy posted this 07 July 2017
Hi Mike,
In order to assist you further on this we need to analyze the subsystem report and the Black Magic speed test screenshots. Please create a web support ticket in suppport.promise.com by registering the product with the unit serial number(Located at the back of the chassis)and attach the files.
- Open promise utility
Below is the Promise KB link to know more on how to attach files to the web support case:
Dinesh.K
Promise Tech Support
Clement Batifoulier posted this 21 August 2017
Hi Mike i am curious to know if you use a PCI Thunderbolt card to connect to your Pegasus ? Or the MB model you are using ?
Cheers
Cory Johnn posted this 02 November 2017
I have been having the same issuses with my Pegasus R8 48TB RAID5. I have it plugged into the ASUS TB3 Card and am not getting fast speeds at all, struggling to get through FULL res 8K RED footage. As where another editor I know says hes chewing through the footage on almost an identical setup.
CPU Specs:
Motherboard - X99A-ii
TB3 Card - ASUS ThunderboltEX 3 PCI-E x4 Card
GPU - GTX 1080Ti
SSD - Samsung 960 PRO M.2 PCIe SSD 1TB
Memory - Corsair Vengance LPX D4 64GB
CPU - i7 6800K 3.4GHz 15mb
Here is my BMD Speed Test results (It cuts the numbers off for some reason, but it's reading 340 Write and 317 Read):
Any and all help would be appreciated!
Thanks,
Cory
Also, here is my subsystem report:
https://drive.google.com/open?id=0B-LFC4vNinm6QVdEUFpSa1F5N1U
Hope this helps!
Thanks,
Cory
Yu Qin posted this 06 November 2017
Hey Cory,
There's a more updated firmware version than the current one you're using. If you wanna give it a go, it's free at the download centre.
