Pegasus 2 R8 All drives showing up dead/offline after unmounting them for dust removal
  • 405 Views
  • Last Post 08 December 2018
Joao Paulo Jacobsen posted this 08 December 2018
My name is JP, this morning I removed all my eight Seagate Barracuda 3000GB drives to spray some air on them in order to remove dust. They were all working perfectly before I did this.
After I mounted them all back in the Pegasus R8 and restarted the R8 they are all showing up with a red light. On the utility (already updated to the latest version) system status they all show up as Dead/Offline. On the physical drive list they show up as Dead :/ - All my photos are in them, over 10 years of work. I am very worried.
It seems to me that I probably skipped a step after mounting back in and turning the R8 back on.
Is there any steps I should follow to solve this challenge?
Ranjith kumar posted this 08 December 2018
Hi JP,
We need subsystem report to find the exact issue in your Pegasus R8. Could you visit support.promise.com and create a web support case for this issue.In that case id kindly attach the subsystem report, please follow below steps to get report.
- Open promise utility
Note: If you are unable reply to this web support case, it could be a issue with the pop up blocker on your browser.
Please disable the pop up blocker and try to click on the case ID to open.
Ranjith
Thanks for the super fast response. For some reason the promiso forum tells me that the .html that I export out of Promise Utility is "file extension format not allowed".
As an alternative I uploaded the subsystem information html file to my dropbox. Here is the link: https://www.dropbox.com/s/rq5g7qt2sihtpi2/subsysteminfo.html?dl=0
Please let me know how to proceed.
Much appreciated,
JP
Hi JP,
I have verified the report, found that all drives are dead due to removal and also found that this unit is running older firmware which
need to be update incrementally. Since all drives are dead, there will be possibility of data loss, but we can try with forcing online on drives.
Could you let me know your registered email  id at support.promise.com to create web support case and help you on this issue or create a support case from your end.
Ranjith
This is weird since I removed them with the hard drive turned off. I believe that you will be able to fix taking these steps you suggested.
I just registered my e-mail as joaopaulojacobsen@mac.com.
Please let me know what the next steps are.
Thankfully,
JP
Hi JP,
Kindly refer this case id-20181208121040S at support.promise.com and click web support, then view existing case and update the needed details on same case id.
Ranjith
Fantastic. I was able to access the web support and send a message through there.
I will be on hold for future instructions.
Ranjith kumar just gave me the best customer support I've ever got. For real, trough promise Teamviewer platform he helped me all the way and my Promise 2 R8 is back again with all files intact. If you got to this thread with the same problem I had I wish you are lucky as I was to get Ranjith to help you out. Thanks, Promise for the awesome customer support!
