Pegasus 2 R6 - USING 6TB 7200RPM HARD DRIVES
  • 813 Views
  • Last Post 24 January 2019
Carlos Ruiz posted this 11 January 2019
Hi
I have a Pegasus 2 R6  with 12TB and I need to more space for editing 4k video.
At the moment it's impossible for me to buy a bigger raid
The oficial spec says that you can only use up to 4TB hardrives on this sytem
Has anyone used, tested using 6TB on the Pegasus 2 R6?
Can any one recommend any disks for this system?
Thanks very much
Carlos
arunkumar b posted this 12 January 2019
Hi Carlos,
Thank you for contacting Promise.
You can use drives as per the compatibility list.Make sure to backup your data first from the Pegasus drive ,replace all the hard drives with new drives then recreate new RAID
Here is the link for Pegasus2 compatibility list
https://promise.com/DownloadFile.aspx?DownloadFileUID=6049
Arun
Carlos Ruiz posted this 13 January 2019
Thanks very much Arun
Please could you confirm whether from the list you sent me I can in fact installed on my PegasusR6 any of the disks that appera on that list whther 4TB, 6TB, 8TB or 10TB
I ask because on the list  it says shipped with  - I wonder if I can only installed on my R6 the disks that appear on the list as shipped with R6 or I can installed any of the disk on that list?
Also please can you tell if any to installed any driver. We are owrking wiht a Mac Pro 2013
Thanks very much
Carlos
arunkumar b posted this 14 January 2019
Hi Carlos,
Yes,you could use any of the drives available in the comaptibility list.Before upgrade your hard drives,make sure to backup your data first from the Pegasus drive ,replace all the hard drives with new drives then recreate new RAID
Arun
Carlos Ruiz posted this 24 January 2019
Hi Arun
Sorry to bother you again wiht this subject:
I analyse the disc list yo sent me
The toshibas disks seem to have the better reviews
I am interested in getting 10TB (or at lest 8TB) disks for I will need a lot of space to work
The only 10TB disk on the list is the seagate ironwolf which does not seem to have such good reviews as the toshibas
I am using the raid for video editing
Please could you tell me which one would you recommend?
Kind Regards
Carlos
