Pegasus 2 not showing up. Amber power light on
  • 1.3K Views
  • Last Post 01 November 2016
PG Tech posted this 24 October 2016
Rebooted apple server because people couldn't get on. The Pegasus 2 RAID doesn't show up on the desktop. The light is amber. OS X is El Capitan. Latest firmware and software on the promise utility.
Pegasus 2 won't shut down when I hole the amber button down (after I've shut off the connecting computer).
Changed the thunderbolt cable to a new one.
Should I hard shut down the Pegasus by pulling the plug?
In a hurry of course.
Raghuraman Kannan posted this 25 October 2016
In order to find the exact problem , please follow the below steps and send us the service report
- Shutdown the pegasus ( If the power button doesnot work, then Unplugging the power is the only option)
- Open Promise Utility
- Click on save service report button to save the subsystem report and attach it .
We will check the report and let you know if there are any issues.
For Immediate assistance , you can always open an case at support.promsie.com or you can call us at 408-228-1500 .
PG Tech posted this 31 October 2016
I'm trying to send the report but when I do, it says something like "extension not allowed." So I copied the html file to a txt file and got the same message. What to do?
Raghuraman Kannan posted this 01 November 2016
Please visit support.promise.com and register yourself as an user. Once done , kindly register your product and open an web case. You will be able to attach the saved report to the webcase.
Once that is submitted , we will review it and reply to the case.
