Pegasus 2 / after update to Mac OS Monterey 12.01 volume not writable
  • 531 Views
  • Last Post 23 December 2021
Gregor Bresser posted this 06 December 2021
  • Mac Pro
  • after update to 12.0.1 Monterey (from Big Sur)
  • Utitliy App 4.06.0000.01 (C02) (i updated
  • Pagasus ist Mounted but it´s impossible to write on the volume.
  • Mac warned - damaged Volume…
  • mac OS cant repair the Volume… even not with the disc repair program
  • Utitlty Program works and finds the Promise Pegasus
Any idea?
R P posted this 23 December 2021
Hi Gregor,
You seem to have a drive problem. First PD4 was forced offline, there was only one bad block...
SeqNo: 32459                           Device: PD 4
EventId: 0x000D001D                    Severity: Major
TimeStamp: Dec 2, 2021 11:20:40        DefaultId: 0x000D001D
SpecData: 000000000000000000 0000012020202020 2020202020203734 37573057554B53
Description: Physical Disk is marked as DEAD due to forced offline state
Then a rebuild was started, but hours into the rebuild PD1 is failing for a lot of bad blocks.
SeqNo: 32472                           Device: DA 0
EventId: 0x000F0000                    Severity: Info
TimeStamp: Dec 5, 2021 15:35:55        DefaultId: 0x000F0000
SpecData: 000000000300000003 0000000000000000 0000000000000000 00000000000000
Description: Rebuild is started
SeqNo: 32473                           Device: PD 1
EventId: 0x000D000F                    Severity: Minor
TimeStamp: Dec 5, 2021 19:03:29        DefaultId: 0x000D000F
SpecData: 8ABBBE680000000000 0000012020202020 2020202020203734 3756535A4B4B53
Description: Bad sector is found on physical disk
All the events from 32473 to 32936 are bad block errors on PD1.
It looks like the rebuild did complete.
SMART says that PD1 is OK, but it logged this many errors on PD1..
Error 464 occurred at disk power-on lifetime: 29942 hours (1247 days + 14 hours)
There are also lots of reallocated sector events, some pending.
  5 Reallocated_Sector_Ct
    0x0033  100   100   005    Pre-fail  Always     -            20
196 Reallocated_Event_Count
    0x0032  100   100   000    Old_age   Always     -            68
197 Current_Pending_Sector
    0x0022  100   100   000    Old_age   Always     -            40
It's hard to say what happened here, but it looks like a double fault on a RAID5, two disks failed, but only 1 disk went offline and a rebuild was done from the other bad disk.
I don't see anything that can be done with these disks as they are. But if you still have the old PD4 and macOS could not write to the volume, I have an idea that might work. This assumes that PD4 is OK. Please note that this is not guranteed to work, use at your own risk.
1. Power down the storage.
2. Replace PD4 with the original PD4.
3. Unseat PD1, just pull it slightly out.
4. Power on the Pegasus.
5. You will have to force PD4 online since it was marked dead. You can do this from the CLI with...
phydrive -a online -p 4
5. If the array does not come online check the array panel in promise utility. You might see that the array needs to be accepted, if you accept it you should have an array that's online but critical and a volume that macOS can mount.
6. At this point I'd back up all critical data if you don't have it backed up already. PD4 may go offline again.
7. If everything seems OK you can try and replace rebuild PD1. But you can't use the PD4 disk as is since it thinks it's already part of the array.
The other solution is a data recovery company.
One last note, SMART says that the other disks are OK, no hidden problems show up.
Gregor Bresser posted this 07 December 2021
I added the service report to the analysis
SYSTEM SERVICE REPORT
[About]
[Subsys info]
[Controller Info]
[Enclosure Info]
[Buzzer Info]
[Phydrv Info]
[SMART Info]
[BBM Info]
[Phydrv Verbose Info]
[Disk Array Info]
[Disk Array Verbose Info]
[Disk Array Dump Info]
[Logdrv Info]
[Logdrv Verbose Info]
[Logdrv Dump Info]
[Error Table Info]
[Statistic Info]
[Spare Info]
[Spare Verbose Info]
[Spare Dump Info]
[BGA Info]
[Runtime Event Info]
[NVRAM Event Info]
[Host Info]
[HBA Driver Info]
[About]
Promise Utility
Version: 4.06.0000.01 Build Date: Aug 4, 2021
Copyright 2020-2021 Promise Technology, Inc. All rights reserved.
top
[Subsys info]
Alias:
Vendor: Promise Technology,Inc.        Model: Pegasus2 R6
PartNo: F29DS6722000000                SerialNo: N/A
Rev: B3                                WWN: 2000-0001-5558-ff46
CBSN: M92L14715800006                  Interface: Thunderbolt
top
[Controller Info]
CtrlId: 1
Alias:
OperationalStatus: OK                  PowerOnTime: 12 minutes
LUNAffinity: N/A                       LunmappingMethod: WWN Based
CacheUsagePercentage: 0%               DirtyCachePercentage: 0%
Vendor: PROMISE                        Model: Pegasus2 R6
HWRev: B3                              WWN: 2000-0001-5558-ff46
CmdProtocol: SCSI-3                    CBSN: M92L14715800006
MemType: DDR2 SDRAM                    MemSize: 512MB
FlashType: Flash Memory                FlashSize: 8MB
NVRAMType: FRAM                        NVRAMSize: 128KB
BootLoaderVersion: 5.04.0000.64        BootLoaderBuildDate: Dec 5, 2019
FirmwareVersion: 5.04.0000.64          FirmwareBuildDate: Dec 5, 2019
SoftwareVersion: 5.04.0000.64          SoftwareBuildDate: Dec 5, 2019
BIOSVersion: 5.04.0000.64              BIOSBuildDate: Dec 5, 2019
SingleImageVersion: 5.04.0000.64       SingleImageBuildDate: Dec 5, 2019
CtrlCPLDVersion: 6.08
DiskArrayPresent: 1                    OverallRAIDStatus: OK
LogDrvPresent: 1                       LogDrvOnline: 1
LogDrvOffline: 0                       LogDrvCritical: 0
PhyDrvPresent: 6                       PhyDrvOnline: 6
PhyDrvOffline: 0                       PhyDrvPFA: 0
GlobalSparePresent: 0                  DedicatedSparePresent: 0
RevertibleGlobalSparePresent: 0        RevertibleDedicatedSparePresent: 0
RevertibleGlobalSpareUsed: 0           RevertibleDedicatedSpareUsed: 0
WriteThroughMode: No                   MaxSectorSize: 4KB
PreferredCacheLineSize: 64 KB          CacheLineSize: 64 KB
Coercion: Enabled                      CoercionMethod: GBTruncate
SMART: Disabled                        SMARTPollingInterval: 10 minutes
MigrationStorage: DDF                  CacheFlushInterval: 3 second(s)
PollInterval: 15 second(s)             AdaptiveWBCache: Disabled
ForcedReadAhead: Enabled
PowerSavingLevel: 0                    SpindownType: All drives
IdleTimeToParkRwHeads: Never           IdleTimeToLowerRotationSpeed: Never
IdleTimeToSpinDown: Never
SGPIOBackPlane: Default/Generic (0)    SASReadyLED: Off
SpinUpDelay: 0 millisecond             PowerManagement: Enable
SecurityAdminPassword: N/A
PciFuncAddr: N/A                       PciLinkSpeed: N/A
PciLinkWidth: N/A
top
[Enclosure Info]
Enclosure Setting:
EnclosureId: 1
EnclWarningTempThreshold: 54C/129F     EnclCriticalTempThreshold: 59C/138F
CtrlWarningTempThreshold: 64C/147F     CtrlCriticalTempThreshold: 69C/156F
Enclosure Info and Status:
EnclosureId: 1
EnclosureType: Pegasus2 R6
SEPFwVersion: 1.00
MaxNumOfControllers: 1                 MaxNumOfPhyDrvSlots: 6
MaxNumOfFans: 1                        MaxNumOfBlowers: 0
MaxNumOfTempSensors: 2                 MaxNumOfPSUs: 1
MaxNumOfBatteries: 0                   MaxNumOfVoltageSensors: 3
PSU       Status
1         Powered On and Functional
Fan Location        FanStatus             HealthyThreshold  CurrentFanSpeed
1   Backplane       Functional            > 500 RPM         1100 RPM
TemperatureSensor   Location       HealthThreshold   CurrentTemp    Status
1                   Controller     < 64C/147F        51C/123F       normal
2                   Enclosure      < 54C/129F        45C/113F       normal
VoltageSensor  Type    HealthyThreshold         CurrentVoltage  Status
1              3.3V    +/- 5% (3.13 - 3.46) V   3.3V            Operational
2              5.0V    +/- 5% (4.75 - 5.25) V   5.1V            Operational
3              12.0V   +/- 8% (11.04 - 12.96) V 12.1V           Operational
top
[Buzzer Info]
Enabled   Status
No        Silent
top
[Phydrv Info]
PdId Model        Type      Capacity  Location      OpStatus  ConfigStatus
1    TOSHIBA DT01 SATA HDD  2TB       Encl1 Slot1   OK        Array0 No.0
2    TOSHIBA DT01 SATA HDD  2TB       Encl1 Slot2   OK        Array0 No.1
3    TOSHIBA DT01 SATA HDD  2TB       Encl1 Slot3   OK        Array0 No.2
4    TOSHIBA DT01 SATA HDD  2TB       Encl1 Slot4   OK        Array0 No.3
5    TOSHIBA DT01 SATA HDD  2TB       Encl1 Slot5   OK        Array0 No.4
6    TOSHIBA DT01 SATA HDD  2TB       Encl1 Slot6   OK        Array0 No.5
top
[SMART Info]
PdId: 1
Model Number: TOSHIBA DT01ACA2
Drive Type: SATA
SMART Status: Enable
SMART Health Status: OK
SCT Status Version:                  3
SCT Version (vendor specific):       256 (0x0100)
SCT Support Level:                   1
Device State:                        SMART Off-line Data Collection executing in background (4)
Current Temperature:                    37 Celsius
Power Cycle Min/Max Temperature:     37/38 Celsius
Lifetime    Min/Max Temperature:     20/50 Celsius
Under/Over Temperature Limit Count:   0/0
Self-test execution status:      (   0) The previous self-test routine
                    completed without error or no self-test
                    has ever been run.
Error logging capability:        (0x01) Error logging supported.
Short self-test routine
recommended polling time:    (   1) minutes.
Extended self-test routine
recommended polling time:    ( 241) minutes.
SCT capabilities:          (0x003d) SCT Status supported.
                    SCT Feature Control supported.
                    SCT Data Table supported.
SMART Self-test log structure revision number: 1
No self-tests have been logged.  [To run self-tests, use: smartctl -t]
SMART Error Log Version: 1
ATA Error Count: 464 (device log contains only the most recent five errors)
    CR = Command Register [HEX]
    FR = Features Register [HEX]
    SC = Sector Count Register [HEX]
    SN = Sector Number Register [HEX]
    CL = Cylinder Low Register [HEX]
    CH = Cylinder High Register [HEX]
    DH = Device/Head Register [HEX]
    DC = Device Command Register [HEX]
    ER = Error register [HEX]
    ST = Status register [HEX]
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
  When the command that caused the error occurred,
  the device was active or idle.
  After command completion occurred, registers were:
  ER ST SC SN CL CH DH
  40 51 01 87 5a bc 0a  Error: UNC 1 sectors at LBA = 0x0abc5a87 = 180116103
  Commands leading to the command that caused the error were:
  CR FR SC SN CL CH DH DC   Powered_Up_Time  Command/Feature_Name
  25 00 01 87 5a bc 40 00      04:11:48.101  READ DMA EXT
  35 00 10 bb 98 de 40 00      04:11:48.059  WRITE DMA EXT
  35 00 10 a2 2c e0 40 00      04:11:48.059  WRITE DMA EXT
  25 00 01 86 5a bc 40 00      04:11:47.835  READ DMA EXT
  35 00 01 86 5a bc 40 00      04:11:47.726  WRITE DMA EXT
Error 463 occurred at disk power-on lifetime: 29942 hours (1247 days + 14 hours)
  40 51 01 86 5a bc 0a  Error: UNC 1 sectors at LBA = 0x0abc5a86 = 180116102
  25 00 01 86 5a bc 40 00      04:11:46.724  READ DMA EXT
  35 00 10 bb 98 de 40 00      04:11:46.682  WRITE DMA EXT
  35 00 10 a2 2c e0 40 00      04:11:46.681  WRITE DMA EXT
  25 00 01 85 5a bc 40 00      04:11:46.457  READ DMA EXT
  35 00 01 85 5a bc 40 00      04:11:46.348  WRITE DMA EXT
Error 462 occurred at disk power-on lifetime: 29942 hours (1247 days + 14 hours)
  40 51 01 85 5a bc 0a  Error: UNC 1 sectors at LBA = 0x0abc5a85 = 180116101
  25 00 01 85 5a bc 40 00      04:11:45.346  READ DMA EXT
  35 00 10 bb 98 de 40 00      04:11:45.304  WRITE DMA EXT
  35 00 10 a2 2c e0 40 00      04:11:45.303  WRITE DMA EXT
  25 00 01 84 5a bc 40 00      04:11:45.079  READ DMA EXT
  35 00 01 84 5a bc 40 00      04:11:44.970  WRITE DMA EXT
Error 461 occurred at disk power-on lifetime: 29942 hours (1247 days + 14 hours)
  40 51 01 84 5a bc 0a  Error: UNC 1 sectors at LBA = 0x0abc5a84 = 180116100
  25 00 01 84 5a bc 40 00      04:11:43.968  READ DMA EXT
  35 00 10 bb 98 de 40 00      04:11:43.926  WRITE DMA EXT
  35 00 10 a2 2c e0 40 00      04:11:43.926  WRITE DMA EXT
  25 00 01 83 5a bc 40 00      04:11:43.694  READ DMA EXT
  35 00 01 83 5a bc 40 00      04:11:43.585  WRITE DMA EXT
Error 460 occurred at disk power-on lifetime: 29942 hours (1247 days + 14 hours)
  40 51 01 83 5a bc 0a  Error: UNC 1 sectors at LBA = 0x0abc5a83 = 180116099
  25 00 01 83 5a bc 40 00      04:11:42.582  READ DMA EXT
  35 00 10 bb 98 de 40 00      04:11:42.540  WRITE DMA EXT
  35 00 10 a2 2c e0 40 00      04:11:42.540  WRITE DMA EXT
  25 00 01 82 5a bc 40 00      04:11:42.315  READ DMA EXT
  35 00 01 82 5a bc 40 00      04:11:42.206  WRITE DMA EXT
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME
    FLAG    VALUE WORST THRESH TYPE      UPDATED    WHEN_FAILED  RAW_VALUE
  1 Raw_Read_Error_Rate
    0x000b  100   100   016    Pre-fail  Always     -            0
  2 Throughput_Performance
    0x0005  140   140   054    Pre-fail  Offline    -            68
  3 Spin_Up_Time
    0x0007  253   253   024    Pre-fail  Always     -            115 (Average 180)
  4 Start_Stop_Count
    0x0012  096   096   000    Old_age   Always     -            16243
  7 Seek_Error_Rate
    0x000b  100   100   067    Pre-fail  Always     -            0
  8 Seek_Time_Performance
    0x0005  124   124   020    Pre-fail  Offline    -            33
  9 Power_On_Hours
    0x0012  096   096   000    Old_age   Always     -            29953
 10 Spin_Retry_Count
    0x0013  100   100   060    Pre-fail  Always     -            0
 12 Power_Cycle_Count
    0x0032  096   096   000    Old_age   Always     -            16243
192 Power-Off_Retract_Count
    0x0032  087   087   000    Old_age   Always     -            16365
193 Load_Cycle_Count
    0x0012  087   087   000    Old_age   Always     -            16365
194 Temperature_Celsius
    0x0002  162   162   000    Old_age   Always     -            37 (Lifetime Min/Max 20/50)
198 Offline_Uncorrectable
    0x0008  100   100   000    Old_age   Offline    -            0
199 UDMA_CRC_Error_Count
    0x000a  200   200   000    Old_age   Always     -            0
PdId: 2
Drive Type: SATA
Current Temperature:                    36 Celsius
Power Cycle Min/Max Temperature:     36/37 Celsius
Lifetime    Min/Max Temperature:     18/48 Celsius
                    has ever been run.
No Errors Logged
ID# ATTRIBUTE_NAME
    0x0005  139   139   054    Pre-fail  Offline    -            71
  3 Spin_Up_Time
    0x0007  253   253   024    Pre-fail  Always     -            203 (Average 91)
  4 Start_Stop_Count
    0x0012  096   096   000    Old_age   Always     -            16245
    0x0033  100   100   005    Pre-fail  Always     -            0
  7 Seek_Error_Rate
  9 Power_On_Hours
    0x0012  096   096   000    Old_age   Always     -            29979
 10 Spin_Retry_Count
    0x0032  096   096   000    Old_age   Always     -            16245
    0x0032  087   087   000    Old_age   Always     -            16369
    0x0012  087   087   000    Old_age   Always     -            16369
    0x0002  166   166   000    Old_age   Always     -            36 (Lifetime Min/Max 18/48)
    0x0032  100   100   000    Old_age   Always     -            0
    0x0022  100   100   000    Old_age   Always     -            0
PdId: 3
Drive Type: SATA
Power Cycle Min/Max Temperature:     35/36 Celsius
Lifetime    Min/Max Temperature:     18/46 Celsius
                    has ever been run.
recommended polling time:    ( 233) minutes.
No Errors Logged
ID# ATTRIBUTE_NAME
    0x0005  140   140   054    Pre-fail  Offline    -            67
  3 Spin_Up_Time
    0x0007  253   253   024    Pre-fail  Always     -            206 (Average 92)
  4 Start_Stop_Count
  7 Seek_Error_Rate
  9 Power_On_Hours
    0x0012  096   096   000    Old_age   Always     -            30023
 10 Spin_Retry_Count
    0x0032  087   087   000    Old_age   Always     -            16373
    0x0012  087   087   000    Old_age   Always     -            16373
    0x0002  166   166   000    Old_age   Always     -            36 (Lifetime Min/Max 18/46)
PdId: 4
Drive Type: SATA
Lifetime    Min/Max Temperature:     21/39 Celsius
                    has ever been run.
recommended polling time:    ( 251) minutes.
No Errors Logged
ID# ATTRIBUTE_NAME
  3 Spin_Up_Time
    0x0007  253   253   024    Pre-fail  Always     -            118 (Average 134)
  4 Start_Stop_Count
    0x0012  100   100   000    Old_age   Always     -            17
  7 Seek_Error_Rate
  9 Power_On_Hours
    0x0012  100   100   000    Old_age   Always     -            15
 10 Spin_Retry_Count
    0x0032  100   100   000    Old_age   Always     -            17
    0x0002  166   166   000    Old_age   Always     -            36 (Lifetime Min/Max 21/39)
PdId: 5
Drive Type: SATA
Power Cycle Min/Max Temperature:     36/36 Celsius
Lifetime    Min/Max Temperature:     20/46 Celsius
                    has ever been run.
recommended polling time:    ( 246) minutes.
No Errors Logged
ID# ATTRIBUTE_NAME
  3 Spin_Up_Time
    0x0007  142   142   024    Pre-fail  Always     -            257 (Average 278)
  4 Start_Stop_Count
    0x0012  096   096   000    Old_age   Always     -            16242
  7 Seek_Error_Rate
  9 Power_On_Hours
    0x0012  096   096   000    Old_age   Always     -            30046
 10 Spin_Retry_Count
    0x0032  096   096   000    Old_age   Always     -            16242
    0x0032  087   087   000    Old_age   Always     -            16364
    0x0012  087   087   000    Old_age   Always     -            16364
    0x0002  166   166   000    Old_age   Always     -            36 (Lifetime Min/Max 20/46)
PdId: 6
Drive Type: SATA
Lifetime    Min/Max Temperature:     19/46 Celsius
                    has ever been run.
recommended polling time:    ( 235) minutes.
No Errors Logged
ID# ATTRIBUTE_NAME
    0x0005  139   139   054    Pre-fail  Offline    -            70
  3 Spin_Up_Time
    0x0007  143   143   024    Pre-fail  Always     -            254 (Average 275)
  4 Start_Stop_Count
  7 Seek_Error_Rate
  9 Power_On_Hours
    0x0012  096   096   000    Old_age   Always     -            30028
 10 Spin_Retry_Count
    0x0032  087   087   000    Old_age   Always     -            16366
    0x0012  087   087   000    Old_age   Always     -            16366
    0x0002  166   166   000    Old_age   Always     -            36 (Lifetime Min/Max 19/46)
top
[BBM Info]
Physical Drive Id: 1
Total Defect Blocks: 0
Physical Drive Id: 2
Physical Drive Id: 3
Physical Drive Id: 4
Physical Drive Id: 5
Physical Drive Id: 6
top
PdId: 1
Alias:
PhysicalCapacity: 2TB                  ConfigurableCapacity: 2TB
UsedCapacity: 2TB                      LogicalBlockSize: 512Bytes
ConfigStatus: Array0 No.0              Location: Encl1 Slot1
ModelNo: TOSHIBA DT01ACA2
SerialNo: 747VSZKKS                    FirmwareVersion: MX4OABB0
DriveInterface: SATA 6Gb/s             Protocol: ATA/ATAPI-8
WriteCacheSupport: Yes                 WriteCache: Enabled
RLACacheSupport: Yes                   RLACache: Enabled
SMARTFeatureSetSupport: Yes
SMARTSelfTestSetSupport: Yes           SMARTErrorLoggingSupport: Yes
CmdQueuingSupport: NCQ                 CmdQueuing: Enabled
CmdQueueDepth: 32                      MediumErrorThreshold: 64
Errors: 0                              NonRWErrors: 0
ReadErrors: 0                          WriteErrors: 0
PowerSavingStatus: Full Power          TemperaturePollingInterval: 3 minutes
DriveTemperature: 37C/98F              ReferenceDriveTemperature: N/A
Flags: N/A                             LastUnconfiguredFragement: N/A
PhysicalSectorSize: 0Byte
PdId: 2
Alias:
ConfigStatus: Array0 No.1              Location: Encl1 Slot2
SerialNo: 747W37SKS                    FirmwareVersion: MX4OABB0
DriveTemperature: 36C/96F              ReferenceDriveTemperature: N/A
PdId: 3
Alias:
ConfigStatus: Array0 No.2              Location: Encl1 Slot3
SerialNo: 747W043KS                    FirmwareVersion: MX4OABB0
PdId: 4
Alias:
ConfigStatus: Array0 No.3              Location: Encl1 Slot4
SerialNo: Z0ESGHYAS                    FirmwareVersion: MX4OABB0
PdId: 5
Alias:
ConfigStatus: Array0 No.4              Location: Encl1 Slot5
SerialNo: 747W1H0KS                    FirmwareVersion: MX4OABB0
PdId: 6
Alias:
ConfigStatus: Array0 No.5              Location: Encl1 Slot6
SerialNo: 747W1JJKS                    FirmwareVersion: MX4OABB0
top
[Disk Array Info]
DaId Alias     OpStatus      CfgCapacity FreeCapacity   MaxContiguousCapacity
0              OK            12TB        0Byte          0Byte
top
DaId: 0
Alias:
PhysicalCapacity: 12TB                 ConfigurableCapacity: 12TB
FreeCapacity: 0Byte                    MaxContiguousCapacity: 0Byte
AvailableRAIDLevels: 0 5 6 10 50 1E
PDM: Enabled                           MediaPatrol: Enabled
NumberOfPhysicalDrives: 6              NumberOfLogicalDrives: 1
NumberOfDedicatedSpares: 0
UserSetPowerSavingLevel: 0             CurrentPowerSavingLevel: 0
PowerManagement: Enabled
Physical Drives in the Array:
0     1    2TB         2.76MB       OK
1     2    2TB         2.76MB       OK
2     3    2TB         2.76MB       OK
3     4    2TB         2.76MB       OK
4     5    2TB         2.76MB       OK
5     6    2TB         2.76MB       OK
Logical Drives in the Array:
LdId Alias          RAIDLevel Capacity  OpStatus
0                   RAID5     10TB      OK
Id  OpStatus  PdId CfgCapacity Revertible Type      DedicatedToArray
top
All Spare Info
Begin Hex Dump in Byte
0000-000f: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0010-001f: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0020-002f: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0030-003f: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
End Hex Dump in Byte
DaId: 0
Alias:
0     1    2TB         2.76MB       OK
1     2    2TB         2.76MB       OK
2     3    2TB         2.76MB       OK
3     4    2TB         2.76MB       OK
4     5    2TB         2.76MB       OK
5     6    2TB         2.76MB       OK
0                   RAID5     10TB      OK
0020-002f: 00 04 00 00 00 04 00 00 00 00 00 00 00 00 00 00
0040-004f: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0050-005f: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0060-006f: 00 00 01 00 06 00 00 00 01 00 00 00 10 00 05 00
0070-007f: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0080-008f: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0090-009f: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00a0-00af: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00b0-00bf: 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00
00c0-00cf: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00d0-00df: 01 00 60 01 af 88 e0 e8 00 00 00 00 10 a5 d4 e8
00e0-00ef: 00 00 00 00 20 20 20 20 20 20 20 20 20 20 20 37
00f0-00ff: 34 37 56 53 5a 4b 4b 53 00 00 00 00 00 00 00 00
0100-010f: 00 00 00 00 01 00 01 00 00 00 00 00 00 00 00 00
0110-011f: 01 00 00 00 01 00 00 00 00 00 00 00 01 00 60 01
0120-012f: af 88 e0 e8 00 00 00 00 10 a5 d4 e8 00 00 00 00
0130-013f: 20 20 20 20 20 20 20 20 20 20 20 37 34 37 57 33
0140-014f: 37 53 4b 53 00 00 00 00 00 00 00 00 00 00 00 00
0150-015f: 02 00 01 00 00 00 00 00 00 00 00 00 02 00 00 00
0160-016f: 02 00 00 00 00 00 00 00 01 00 60 01 af 88 e0 e8
0170-017f: 00 00 00 00 10 a5 d4 e8 00 00 00 00 20 20 20 20
0180-018f: 20 20 20 20 20 20 20 37 34 37 57 30 34 33 4b 53
0190-019f: 00 00 00 00 00 00 00 00 00 00 00 00 03 00 01 00
01a0-01af: 00 00 00 00 00 00 00 00 03 00 00 00 03 00 00 00
01b0-01bf: 00 00 00 00 01 00 60 01 af 88 e0 e8 00 00 00 00
01c0-01cf: 10 a5 d4 e8 00 00 00 00 20 20 20 20 20 20 20 20
01d0-01df: 20 20 20 5a 30 45 53 47 48 59 41 53 00 00 00 00
01e0-01ef: 00 00 00 00 00 00 00 00 04 00 01 00 00 00 00 00
01f0-01ff: 00 00 00 00 04 00 00 00 04 00 00 00 00 00 00 00
0200-020f: 01 00 60 01 af 88 e0 e8 00 00 00 00 10 a5 d4 e8
0210-021f: 00 00 00 00 20 20 20 20 20 20 20 20 20 20 20 37
0220-022f: 34 37 57 31 48 30 4b 53 00 00 00 00 00 00 00 00
0230-023f: 00 00 00 00 05 00 01 00 00 00 00 00 00 00 00 00
0240-024f: 05 00 00 00 05 00 00 00 00 00 00 00 01 00 60 01
0250-025f: af 88 e0 e8 00 00 00 00 10 a5 d4 e8 00 00 00 00
0260-026f: 20 20 20 20 20 20 20 20 20 20 20 37 34 37 57 31
0270-027f: 4a 4a 4b 53 00 00 00 00 00 00 00 00 00 00 00 00
0280-028f: 00 00 00 00 00 00 00 00 00 00 00 00 05 00 04 00
0290-029f: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
02a0-02af: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
02b0-02bf: 00 08 00 00 00 d0 26 8c 04 00 00 00 01 00 04 01
02c0-02cf: 03 00 00 00 01 00 00 00 06 00 00 00 22 c3 00 01
02d0-02df: 55 19 39 66 00 00 00 00 00 00 00 00 00 00 00 00
02e0-02ef: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
02f0-02ff: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0300-030f: 00 00 00 00 00 00 00 00 00 00 06 00 00 00 04 01
0310-031f: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0320-032f: 00 00 00 00 00 00 00 00 00 00 00 00 00 90 d4 e8
0330-033f: 00 00 00 00 00 00 00 00 00 00 00 00 01 00 60 01
0340-034f: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0350-035f: 01 00 00 00 00 00 00 00 00 00 00 00 00 90 d4 e8
0360-036f: 00 00 00 00 01 00 00 00 01 00 00 00 01 00 60 01
0370-037f: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0380-038f: 02 00 00 00 00 00 00 00 00 00 00 00 00 90 d4 e8
0390-039f: 00 00 00 00 02 00 00 00 02 00 00 00 01 00 60 01
03a0-03af: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
03b0-03bf: 03 00 00 00 00 00 00 00 00 00 00 00 00 90 d4 e8
03c0-03cf: 00 00 00 00 03 00 00 00 03 00 00 00 01 00 60 01
03d0-03df: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
03e0-03ef: 04 00 00 00 00 00 00 00 00 00 00 00 00 90 d4 e8
03f0-03ff: 00 00 00 00 04 00 00 00 04 00 00 00 01 00 60 01
0400-040f: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0410-041f: 05 00 00 00 00 00 00 00 00 00 00 00 00 90 d4 e8
0420-042f: 00 00 00 00 05 00 00 00 05 00 00 00 01 00 60 01
0430-043f: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
top
[Logdrv Info]
LdId Alias       OpStatus      Capacity  Stripe RAID    CachePolicy     SYNCed
0                OK            10TB      1MB    RAID5   RAhead/WBack    Yes
top
LdId: 0
ArrayId: 0                             SYNCed: Yes
Alias:                                 TRIMSupport: Not Support TRIM
SerialNo: 0000000000000000000000001A4D153B1A4D153B
WWN: 22c3-0001-5519-3966               PreferredCtrlId: N/A
RAIDLevel: RAID5                       StripeSize: 1MB
Capacity: 10TB                         PhysicalCapacity: 12TB
ReadPolicy: ReadAhead                  WritePolicy: WriteBack
CurrentWritePolicy: WriteBack
NumOfUsedPD: 6                         NumOfAxles: 1
SectorSize: 512Bytes                   RAID5&6Algorithm: right asymmetric (4)
TolerableNumOfDeadDrivesPerAxle: 1     ParityPace: N/A
CodecScheme: N/A
top
[Logdrv Dump Info]
LdId: 0
CodecScheme: N/A
0000-000f: 00 5c 1d 82 00 00 00 00 00 00 00 00 00 00 00 00
0020-002f: c8 00 00 00 c8 00 00 00 00 00 00 00 00 00 00 00
0040-004f: 00 00 05 00 01 00 04 01 13 00 00 00 00 d0 26 8c
0050-005f: 04 00 00 00 00 60 fb 74 05 00 00 00 00 00 00 00
0060-006f: 00 00 00 00 01 00 06 00 01 00 00 00 00 08 00 00
0070-007f: 00 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00
00a0-00af: 1a 4d 15 3b 1a 4d 15 3b 22 c3 00 01 55 19 39 66
00b0-00bf: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00c0-00cf: 00 00 00 00 00 00 00 00 ff ff ff 32 00 00 00 00
00d0-00df: 00 04 00 00 00 04 00 00 00 00 00 00 00 00 00 00
00e0-00ef: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00f0-00ff: 00 00 01 01 00 00 00 00 01 00 00 00 00 00 00 00
0100-0107: 00 00 00 00 00 00 00 00
top
[Error Table Info]
[Checktable Info]
top
[Statistic Info]
Controller Statistics
ControllerId: 1
DataTransferred: 2.14GB
ReadDataTransferred: 1.53GB            WriteDataTransferred: 620.27MB
IORequest: 66,128                      NonRWRequest: 241
ReadIORequest: 46,038                  WriteIORequest: 19,849
StatsStartTime: Dec 6, 2021 18:12:50
StatsCollectionTime: Dec 6, 2021 18:25:24
Physical Drive Statistics
PhyDrvId: 1
DataTransferred: 553.27MB
ReadDataTransferred: 299.34MB          WriteDataTransferred: 253.93MB
IORequest: 7,114                       NonRWRequest: 26
ReadIORequest: 3,024                   WriteIORequest: 4,064
PhyDrvId: 2
DataTransferred: 560.93MB
ReadDataTransferred: 303.57MB          WriteDataTransferred: 257.37MB
IORequest: 7,024                       NonRWRequest: 26
ReadIORequest: 2,782                   WriteIORequest: 4,216
PhyDrvId: 3
DataTransferred: 567.83MB
ReadDataTransferred: 313.72MB          WriteDataTransferred: 254.11MB
IORequest: 7,198                       NonRWRequest: 26
ReadIORequest: 3,072                   WriteIORequest: 4,100
PhyDrvId: 4
DataTransferred: 556.25MB
ReadDataTransferred: 300.25MB          WriteDataTransferred: 256MB
IORequest: 7,364                       NonRWRequest: 26
ReadIORequest: 3,178                   WriteIORequest: 4,160
PhyDrvId: 5
DataTransferred: 553.87MB
ReadDataTransferred: 298.01MB          WriteDataTransferred: 255.87MB
IORequest: 7,780                       NonRWRequest: 26
ReadIORequest: 3,304                   WriteIORequest: 4,450
PhyDrvId: 6
DataTransferred: 532.39MB
ReadDataTransferred: 278.79MB          WriteDataTransferred: 253.60MB
IORequest: 7,420                       NonRWRequest: 26
ReadIORequest: 2,632                   WriteIORequest: 4,762
Logical drive Statistics
LogDrvId: 0
top
[Spare Info]
No configured spare drive in the subsystem
top
top
[Spare Dump Info]
top
[BGA Info]
BGA Summary
NumberOfRebuild: 0                     NumberOfMigration: 0
NumberOfPDM: 0                         NumberOfTransition: 0
NumberOfSync: 0                        NumberOfInit: 0
NumberOfRC: 0                          NumberOfMP: 0
NumberOfLunC: 0
LastMPStart: Not Started               LastMPStop: Not Stopped
BGA Settings
AutoRebuild: Enabled                   MediaPatrol: Enabled
AutoRebuildToDeadDisk: Disabled
RebuildRate: Medium                    MigrationRate: Low
PDMRate: Medium                        TransitionRate: Medium
SyncRate: Low                          InitRate: Medium
RCRate: Medium
ReAssignedBlock: 1024                  ErrorBlock: 1024
BGA Progress
top
SeqNo: 0                               Device: Ctrl 1
EventId: 0x00040005                    Severity: Info
TimeStamp: Dec 6, 2021 19:12:50        DefaultId: 0x00040005
SpecData: 000000000000000000 0000000000000000 0000000000000000 00000000000000
Description: The system is started
SeqNo: 1                               Device: SEP 1
EventId: 0x00060002                    Severity: Info
TimeStamp: Dec 6, 2021 19:12:50        DefaultId: 0x00060002
Description: SEP is found
top
[NVRAM Event Info]
SeqNo: 32453                           Device: Ctrl 1
EventId: 0x00040006                    Severity: Info
TimeStamp: Dec 1, 2021 00:14:17        DefaultId: 0x00040006
Description: The system is stopped by unknown reason
SeqNo: 32454                           Device: Ctrl 1
TimeStamp: Dec 1, 2021 08:22:18        DefaultId: 0x00040005
SeqNo: 32455                           Device: Ctrl 1
TimeStamp: Dec 2, 2021 02:12:17        DefaultId: 0x00040006
SeqNo: 32456                           Device: Ctrl 1
TimeStamp: Dec 2, 2021 10:40:58        DefaultId: 0x00040005
SeqNo: 32457                           Device: PD 4
EventId: 0x000D0011                    Severity: Minor
TimeStamp: Dec 2, 2021 11:20:37        DefaultId: 0x000D0011
Description: Command times out on physical disk
SeqNo: 32458                           Device: PD 4
EventId: 0x000D0003                    Severity: Info
TimeStamp: Dec 2, 2021 11:20:39        DefaultId: 0x000D0003
Description: Physical Disk has been reset
SeqNo: 32460                           Device: LD 0
EventId: 0x00090004                    Severity: Major
TimeStamp: Dec 2, 2021 11:20:40        DefaultId: 0x00090004
SpecData: 000000000000000000 0000000000000000 0000000000000022 C3000155193966
Description: Logical drive has been set to critical
SeqNo: 32461                           Device: Ctrl 1
TimeStamp: Dec 3, 2021 00:44:02        DefaultId: 0x00040006
SeqNo: 32462                           Device: Ctrl 1
TimeStamp: Dec 3, 2021 11:16:05        DefaultId: 0x00040005
SeqNo: 32463                           Device: Ctrl 1
TimeStamp: Dec 4, 2021 01:00:14        DefaultId: 0x00040006
SeqNo: 32464                           Device: Ctrl 1
TimeStamp: Dec 4, 2021 14:43:25        DefaultId: 0x00040005
SeqNo: 32465                           Device: PD 4
TimeStamp: Dec 4, 2021 14:45:06        DefaultId: 0x000D000F
SpecData: 00000FB80000000000 0000012020202020 2020202020203734 37573057554B53
SeqNo: 32466                           Device: Ctrl 1
TimeStamp: Dec 5, 2021 15:02:30        DefaultId: 0x00040006
SeqNo: 32467                           Device: Ctrl 1
TimeStamp: Dec 5, 2021 15:11:42        DefaultId: 0x00040005
SeqNo: 32468                           Device: Ctrl 1
TimeStamp: Dec 5, 2021 15:11:42        DefaultId: 0x00040006
SeqNo: 32469                           Device: Ctrl 1
SeqNo: 32470                           Device: DA 0
EventId: 0x00130007                    Severity: Info
TimeStamp: Dec 5, 2021 15:21:51        DefaultId: 0x00130007
SpecData: 000000000000000000 0000000000000000 0000000000000083 34030001000000
Description: The incomplete array was accepted.
SeqNo: 32471                           Device: LD 0
TimeStamp: Dec 5, 2021 15:21:51        DefaultId: 0x00090004
SeqNo: 32474                           Device: PD 1
TimeStamp: Dec 5, 2021 19:03:35        DefaultId: 0x000D000F
SpecData: 8ABBBE690000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32475                           Device: PD 1
TimeStamp: Dec 5, 2021 19:03:36        DefaultId: 0x000D000F
SpecData: 8ABBBE6A0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32476                           Device: PD 1
TimeStamp: Dec 5, 2021 19:03:37        DefaultId: 0x000D000F
SpecData: 8ABBBE6B0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32477                           Device: PD 1
TimeStamp: Dec 5, 2021 19:03:39        DefaultId: 0x000D000F
SpecData: 8ABBBE6C0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32478                           Device: PD 1
TimeStamp: Dec 5, 2021 19:03:40        DefaultId: 0x000D000F
SpecData: 8ABBBE6D0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32479                           Device: PD 1
TimeStamp: Dec 5, 2021 19:03:41        DefaultId: 0x000D000F
SpecData: 8ABBBE6E0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32480                           Device: PD 1
TimeStamp: Dec 5, 2021 19:03:44        DefaultId: 0x000D000F
SpecData: 8ABBBE6F0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32481                           Device: PD 1
TimeStamp: Dec 5, 2021 19:03:48        DefaultId: 0x000D000F
SpecData: 8ABBBE700000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32482                           Device: PD 1
TimeStamp: Dec 5, 2021 19:03:52        DefaultId: 0x000D000F
SpecData: 8ABBBE710000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32483                           Device: PD 1
TimeStamp: Dec 5, 2021 19:03:54        DefaultId: 0x000D000F
SpecData: 8ABBBE720000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32484                           Device: PD 1
TimeStamp: Dec 5, 2021 19:03:55        DefaultId: 0x000D000F
SpecData: 8ABBBE730000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32485                           Device: PD 1
TimeStamp: Dec 5, 2021 19:03:56        DefaultId: 0x000D000F
SpecData: 8ABBBE740000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32486                           Device: PD 1
TimeStamp: Dec 5, 2021 19:03:58        DefaultId: 0x000D000F
SpecData: 8ABBBE750000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32487                           Device: PD 1
TimeStamp: Dec 5, 2021 19:03:59        DefaultId: 0x000D000F
SpecData: 8ABBBE760000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32488                           Device: PD 1
TimeStamp: Dec 5, 2021 19:04:00        DefaultId: 0x000D000F
SpecData: 8ABBBE770000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32489                           Device: PD 1
TimeStamp: Dec 5, 2021 19:04:11        DefaultId: 0x000D000F
SpecData: 8ABBBE900000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32490                           Device: PD 1
TimeStamp: Dec 5, 2021 19:04:17        DefaultId: 0x000D000F
SpecData: 8ABBBE910000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32491                           Device: PD 1
TimeStamp: Dec 5, 2021 19:04:18        DefaultId: 0x000D000F
SpecData: 8ABBBE920000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32492                           Device: PD 1
SpecData: 8ABBBE930000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32493                           Device: PD 1
TimeStamp: Dec 5, 2021 19:04:20        DefaultId: 0x000D000F
SpecData: 8ABBBE940000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32494                           Device: PD 1
TimeStamp: Dec 5, 2021 19:04:21        DefaultId: 0x000D000F
SpecData: 8ABBBE950000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32495                           Device: PD 1
TimeStamp: Dec 5, 2021 19:04:22        DefaultId: 0x000D000F
SpecData: 8ABBBE960000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32496                           Device: PD 1
TimeStamp: Dec 5, 2021 19:04:24        DefaultId: 0x000D000F
SpecData: 8ABBBE970000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32497                           Device: PD 1
TimeStamp: Dec 5, 2021 19:04:29        DefaultId: 0x000D000F
SpecData: 8ABBBE980000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32498                           Device: PD 1
TimeStamp: Dec 5, 2021 19:04:33        DefaultId: 0x000D000F
SpecData: 8ABBBE990000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32499                           Device: PD 1
TimeStamp: Dec 5, 2021 19:04:35        DefaultId: 0x000D000F
SpecData: 8ABBBE9A0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32500                           Device: PD 1
TimeStamp: Dec 5, 2021 19:04:36        DefaultId: 0x000D000F
SpecData: 8ABBBE9B0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32501                           Device: PD 1
TimeStamp: Dec 5, 2021 19:04:38        DefaultId: 0x000D000F
SpecData: 8ABBBE9C0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32502                           Device: PD 1
TimeStamp: Dec 5, 2021 19:04:40        DefaultId: 0x000D000F
SpecData: 8ABBBE9D0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32503                           Device: PD 1
TimeStamp: Dec 5, 2021 19:04:41        DefaultId: 0x000D000F
SpecData: 8ABBBE9E0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32504                           Device: PD 1
TimeStamp: Dec 5, 2021 19:04:42        DefaultId: 0x000D000F
SpecData: 8ABBBE9F0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32505                           Device: PD 1
TimeStamp: Dec 5, 2021 19:04:51        DefaultId: 0x000D000F
SpecData: 8ABBBFB80000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32506                           Device: PD 1
TimeStamp: Dec 5, 2021 19:04:55        DefaultId: 0x000D000F
SpecData: 8ABBBFB90000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32507                           Device: PD 1
TimeStamp: Dec 5, 2021 19:04:57        DefaultId: 0x000D000F
SpecData: 8ABBBFBA0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32508                           Device: PD 1
TimeStamp: Dec 5, 2021 19:04:58        DefaultId: 0x000D000F
SpecData: 8ABBBFBB0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32509                           Device: PD 1
TimeStamp: Dec 5, 2021 19:04:59        DefaultId: 0x000D000F
SpecData: 8ABBBFBC0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32510                           Device: PD 1
TimeStamp: Dec 5, 2021 19:05:01        DefaultId: 0x000D000F
SpecData: 8ABBBFBD0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32511                           Device: PD 1
TimeStamp: Dec 5, 2021 19:05:02        DefaultId: 0x000D000F
SpecData: 8ABBBFBE0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32512                           Device: PD 1
TimeStamp: Dec 5, 2021 19:05:03        DefaultId: 0x000D000F
SpecData: 8ABBBFBF0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32513                           Device: PD 1
TimeStamp: Dec 5, 2021 19:05:09        DefaultId: 0x000D000F
SpecData: 8ABBBFC00000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32514                           Device: PD 1
TimeStamp: Dec 5, 2021 19:05:14        DefaultId: 0x000D000F
SpecData: 8ABBBFC10000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32515                           Device: PD 1
TimeStamp: Dec 5, 2021 19:05:16        DefaultId: 0x000D000F
SpecData: 8ABBBFC20000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32516                           Device: PD 1
TimeStamp: Dec 5, 2021 19:05:17        DefaultId: 0x000D000F
SpecData: 8ABBBFC30000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32517                           Device: PD 1
TimeStamp: Dec 5, 2021 19:05:18        DefaultId: 0x000D000F
SpecData: 8ABBBFC40000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32518                           Device: PD 1
TimeStamp: Dec 5, 2021 19:05:19        DefaultId: 0x000D000F
SpecData: 8ABBBFC50000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32519                           Device: PD 1
TimeStamp: Dec 5, 2021 19:05:21        DefaultId: 0x000D000F
SpecData: 8ABBBFC60000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32520                           Device: PD 1
TimeStamp: Dec 5, 2021 19:05:22        DefaultId: 0x000D000F
SpecData: 8ABBBFC70000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32521                           Device: PD 1
TimeStamp: Dec 5, 2021 19:05:39        DefaultId: 0x000D000F
SpecData: 8ABBC8480000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32522                           Device: PD 1
TimeStamp: Dec 5, 2021 19:05:44        DefaultId: 0x000D000F
SpecData: 8ABBC8490000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32523                           Device: PD 1
TimeStamp: Dec 5, 2021 19:05:45        DefaultId: 0x000D000F
SpecData: 8ABBC84A0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32524                           Device: PD 1
TimeStamp: Dec 5, 2021 19:05:46        DefaultId: 0x000D000F
SpecData: 8ABBC84B0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32525                           Device: PD 1
TimeStamp: Dec 5, 2021 19:05:47        DefaultId: 0x000D000F
SpecData: 8ABBC84C0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32526                           Device: PD 1
TimeStamp: Dec 5, 2021 19:05:49        DefaultId: 0x000D000F
SpecData: 8ABBC84D0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32527                           Device: PD 1
TimeStamp: Dec 5, 2021 19:05:50        DefaultId: 0x000D000F
SpecData: 8ABBC84E0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32528                           Device: PD 1
TimeStamp: Dec 5, 2021 19:05:51        DefaultId: 0x000D000F
SpecData: 8ABBC84F0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32529                           Device: PD 1
TimeStamp: Dec 5, 2021 19:06:02        DefaultId: 0x000D000F
SpecData: 8ABBC8F80000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32530                           Device: PD 1
TimeStamp: Dec 5, 2021 19:06:07        DefaultId: 0x000D000F
SpecData: 8ABBC8F90000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32531                           Device: PD 1
TimeStamp: Dec 5, 2021 19:06:08        DefaultId: 0x000D000F
SpecData: 8ABBC8FA0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32532                           Device: PD 1
TimeStamp: Dec 5, 2021 19:06:09        DefaultId: 0x000D000F
SpecData: 8ABBC8FB0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32533                           Device: PD 1
TimeStamp: Dec 5, 2021 19:06:11        DefaultId: 0x000D000F
SpecData: 8ABBC8FC0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32534                           Device: PD 1
TimeStamp: Dec 5, 2021 19:06:12        DefaultId: 0x000D000F
SpecData: 8ABBC8FD0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32535                           Device: PD 1
TimeStamp: Dec 5, 2021 19:06:13        DefaultId: 0x000D000F
SpecData: 8ABBC8FE0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32536                           Device: PD 1
TimeStamp: Dec 5, 2021 19:06:15        DefaultId: 0x000D000F
SpecData: 8ABBC8FF0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32537                           Device: PD 1
TimeStamp: Dec 5, 2021 19:06:20        DefaultId: 0x000D000F
SpecData: 8ABBC9000000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32538                           Device: PD 1
TimeStamp: Dec 5, 2021 19:06:25        DefaultId: 0x000D000F
SpecData: 8ABBC9010000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32539                           Device: PD 1
TimeStamp: Dec 5, 2021 19:06:27        DefaultId: 0x000D000F
SpecData: 8ABBC9020000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32540                           Device: PD 1
TimeStamp: Dec 5, 2021 19:06:28        DefaultId: 0x000D000F
SpecData: 8ABBC9030000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32541                           Device: PD 1
TimeStamp: Dec 5, 2021 19:06:29        DefaultId: 0x000D000F
SpecData: 8ABBC9040000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32542                           Device: PD 1
TimeStamp: Dec 5, 2021 19:06:30        DefaultId: 0x000D000F
SpecData: 8ABBC9050000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32543                           Device: PD 1
TimeStamp: Dec 5, 2021 19:06:32        DefaultId: 0x000D000F
SpecData: 8ABBC9060000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32544                           Device: PD 1
TimeStamp: Dec 5, 2021 19:06:33        DefaultId: 0x000D000F
SpecData: 8ABBC9070000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32545                           Device: PD 1
TimeStamp: Dec 5, 2021 19:06:43        DefaultId: 0x000D000F
SpecData: 8ABBD2280000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32546                           Device: PD 1
TimeStamp: Dec 5, 2021 19:06:48        DefaultId: 0x000D000F
SpecData: 8ABBD2290000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32547                           Device: PD 1
TimeStamp: Dec 5, 2021 19:06:50        DefaultId: 0x000D000F
SpecData: 8ABBD22A0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32548                           Device: PD 1
TimeStamp: Dec 5, 2021 19:06:51        DefaultId: 0x000D000F
SpecData: 8ABBD22B0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32549                           Device: PD 1
TimeStamp: Dec 5, 2021 19:06:52        DefaultId: 0x000D000F
SpecData: 8ABBD22C0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32550                           Device: PD 1
TimeStamp: Dec 5, 2021 19:06:54        DefaultId: 0x000D000F
SpecData: 8ABBD22D0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32551                           Device: PD 1
TimeStamp: Dec 5, 2021 19:06:55        DefaultId: 0x000D000F
SpecData: 8ABBD22E0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32552                           Device: PD 1
TimeStamp: Dec 5, 2021 19:06:56        DefaultId: 0x000D000F
SpecData: 8ABBD22F0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32553                           Device: PD 1
TimeStamp: Dec 5, 2021 19:07:02        DefaultId: 0x000D000F
SpecData: 8ABBDC080000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32554                           Device: PD 1
TimeStamp: Dec 5, 2021 19:07:07        DefaultId: 0x000D000F
SpecData: 8ABBDC090000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32555                           Device: PD 1
TimeStamp: Dec 5, 2021 19:07:08        DefaultId: 0x000D000F
SpecData: 8ABBDC0A0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32556                           Device: PD 1
TimeStamp: Dec 5, 2021 19:07:10        DefaultId: 0x000D000F
SpecData: 8ABBDC0B0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32557                           Device: PD 1
TimeStamp: Dec 5, 2021 19:07:11        DefaultId: 0x000D000F
SpecData: 8ABBDC0C0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32558                           Device: PD 1
TimeStamp: Dec 5, 2021 19:07:12        DefaultId: 0x000D000F
SpecData: 8ABBDC0D0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32559                           Device: PD 1
TimeStamp: Dec 5, 2021 19:07:14        DefaultId: 0x000D000F
SpecData: 8ABBDC0E0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32560                           Device: PD 1
TimeStamp: Dec 5, 2021 19:07:15        DefaultId: 0x000D000F
SpecData: 8ABBDC0F0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32561                           Device: PD 1
TimeStamp: Dec 5, 2021 19:08:12        DefaultId: 0x000D000F
SpecData: 8ABBF0B80000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32562                           Device: PD 1
TimeStamp: Dec 5, 2021 19:08:17        DefaultId: 0x000D000F
SpecData: 8ABBF0B90000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32563                           Device: PD 1
TimeStamp: Dec 5, 2021 19:08:18        DefaultId: 0x000D000F
SpecData: 8ABBF0BA0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32564                           Device: PD 1
TimeStamp: Dec 5, 2021 19:08:20        DefaultId: 0x000D000F
SpecData: 8ABBF0BB0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32565                           Device: PD 1
TimeStamp: Dec 5, 2021 19:08:21        DefaultId: 0x000D000F
SpecData: 8ABBF0BC0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32566                           Device: PD 1
TimeStamp: Dec 5, 2021 19:08:22        DefaultId: 0x000D000F
SpecData: 8ABBF0BD0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32567                           Device: PD 1
TimeStamp: Dec 5, 2021 19:08:24        DefaultId: 0x000D000F
SpecData: 8ABBF0BE0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32568                           Device: PD 1
TimeStamp: Dec 5, 2021 19:08:25        DefaultId: 0x000D000F
SpecData: 8ABBF0BF0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32569                           Device: PD 1
TimeStamp: Dec 5, 2021 19:08:30        DefaultId: 0x000D000F
SpecData: 8ABBF0C00000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32570                           Device: PD 1
TimeStamp: Dec 5, 2021 19:08:35        DefaultId: 0x000D000F
SpecData: 8ABBF0C10000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32571                           Device: PD 1
TimeStamp: Dec 5, 2021 19:08:36        DefaultId: 0x000D000F
SpecData: 8ABBF0C20000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32572                           Device: PD 1
TimeStamp: Dec 5, 2021 19:08:38        DefaultId: 0x000D000F
SpecData: 8ABBF0C30000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32573                           Device: PD 1
TimeStamp: Dec 5, 2021 19:08:39        DefaultId: 0x000D000F
SpecData: 8ABBF0C40000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32574                           Device: PD 1
TimeStamp: Dec 5, 2021 19:08:41        DefaultId: 0x000D000F
SpecData: 8ABBF0C50000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32575                           Device: PD 1
TimeStamp: Dec 5, 2021 19:08:43        DefaultId: 0x000D000F
SpecData: 8ABBF0C60000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32576                           Device: PD 1
TimeStamp: Dec 5, 2021 19:08:44        DefaultId: 0x000D000F
SpecData: 8ABBF0C70000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32577                           Device: PD 1
TimeStamp: Dec 5, 2021 19:08:49        DefaultId: 0x000D000F
SpecData: 8ABBF0C80000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32578                           Device: PD 1
TimeStamp: Dec 5, 2021 19:08:54        DefaultId: 0x000D000F
SpecData: 8ABBF0C90000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32579                           Device: PD 1
TimeStamp: Dec 5, 2021 19:08:55        DefaultId: 0x000D000F
SpecData: 8ABBF0CA0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32580                           Device: PD 1
TimeStamp: Dec 5, 2021 19:08:56        DefaultId: 0x000D000F
SpecData: 8ABBF0CB0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32581                           Device: PD 1
TimeStamp: Dec 5, 2021 19:08:58        DefaultId: 0x000D000F
SpecData: 8ABBF0CC0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32582                           Device: PD 1
TimeStamp: Dec 5, 2021 19:08:59        DefaultId: 0x000D000F
SpecData: 8ABBF0CD0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32583                           Device: PD 1
TimeStamp: Dec 5, 2021 19:09:00        DefaultId: 0x000D000F
SpecData: 8ABBF0CE0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32584                           Device: PD 1
TimeStamp: Dec 5, 2021 19:09:02        DefaultId: 0x000D000F
SpecData: 8ABBF0CF0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32585                           Device: PD 1
TimeStamp: Dec 5, 2021 19:09:09        DefaultId: 0x000D000F
SpecData: 8ABBF0D80000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32586                           Device: PD 1
TimeStamp: Dec 5, 2021 19:09:14        DefaultId: 0x000D000F
SpecData: 8ABBF0D90000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32587                           Device: PD 1
TimeStamp: Dec 5, 2021 19:09:15        DefaultId: 0x000D000F
SpecData: 8ABBF0DA0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32588                           Device: PD 1
TimeStamp: Dec 5, 2021 19:09:16        DefaultId: 0x000D000F
SpecData: 8ABBF0DB0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32589                           Device: PD 1
TimeStamp: Dec 5, 2021 19:09:19        DefaultId: 0x000D000F
SpecData: 8ABBF0DC0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32590                           Device: PD 1
TimeStamp: Dec 5, 2021 19:09:20        DefaultId: 0x000D000F
SpecData: 8ABBF0DD0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32591                           Device: PD 1
TimeStamp: Dec 5, 2021 19:09:21        DefaultId: 0x000D000F
SpecData: 8ABBF0DE0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32592                           Device: PD 1
TimeStamp: Dec 5, 2021 19:09:23        DefaultId: 0x000D000F
SpecData: 8ABBF0DF0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32593                           Device: PD 1
TimeStamp: Dec 5, 2021 19:09:35        DefaultId: 0x000D000F
SpecData: 8ABBF0F80000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32594                           Device: PD 1
TimeStamp: Dec 5, 2021 19:09:40        DefaultId: 0x000D000F
SpecData: 8ABBF0F90000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32595                           Device: PD 1
TimeStamp: Dec 5, 2021 19:09:41        DefaultId: 0x000D000F
SpecData: 8ABBF0FA0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32596                           Device: PD 1
TimeStamp: Dec 5, 2021 19:09:43        DefaultId: 0x000D000F
SpecData: 8ABBF0FB0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32597                           Device: PD 1
TimeStamp: Dec 5, 2021 19:09:44        DefaultId: 0x000D000F
SpecData: 8ABBF0FC0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32598                           Device: PD 1
TimeStamp: Dec 5, 2021 19:09:45        DefaultId: 0x000D000F
SpecData: 8ABBF0FD0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32599                           Device: PD 1
TimeStamp: Dec 5, 2021 19:09:47        DefaultId: 0x000D000F
SpecData: 8ABBF0FE0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32600                           Device: PD 1
TimeStamp: Dec 5, 2021 19:09:48        DefaultId: 0x000D000F
SpecData: 8ABBF0FF0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32601                           Device: PD 1
TimeStamp: Dec 5, 2021 19:09:57        DefaultId: 0x000D000F
SpecData: 8ABBF1180000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32602                           Device: PD 1
TimeStamp: Dec 5, 2021 19:10:02        DefaultId: 0x000D000F
SpecData: 8ABBF1190000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32603                           Device: PD 1
TimeStamp: Dec 5, 2021 19:10:03        DefaultId: 0x000D000F
SpecData: 8ABBF11A0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32604                           Device: PD 1
TimeStamp: Dec 5, 2021 19:10:04        DefaultId: 0x000D000F
SpecData: 8ABBF11B0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32605                           Device: PD 1
TimeStamp: Dec 5, 2021 19:10:06        DefaultId: 0x000D000F
SpecData: 8ABBF11C0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32606                           Device: PD 1
TimeStamp: Dec 5, 2021 19:10:08        DefaultId: 0x000D000F
SpecData: 8ABBF11D0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32607                           Device: PD 1
TimeStamp: Dec 5, 2021 19:10:09        DefaultId: 0x000D000F
SpecData: 8ABBF11E0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32608                           Device: PD 1
TimeStamp: Dec 5, 2021 19:10:11        DefaultId: 0x000D000F
SpecData: 8ABBF11F0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32609                           Device: PD 1
TimeStamp: Dec 5, 2021 19:10:18        DefaultId: 0x000D000F
SpecData: 8ABBF1300000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32610                           Device: PD 1
TimeStamp: Dec 5, 2021 19:10:23        DefaultId: 0x000D000F
SpecData: 8ABBF1310000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32611                           Device: PD 1
TimeStamp: Dec 5, 2021 19:10:24        DefaultId: 0x000D000F
SpecData: 8ABBF1320000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32612                           Device: PD 1
TimeStamp: Dec 5, 2021 19:10:26        DefaultId: 0x000D000F
SpecData: 8ABBF1330000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32613                           Device: PD 1
TimeStamp: Dec 5, 2021 19:10:27        DefaultId: 0x000D000F
SpecData: 8ABBF1340000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32614                           Device: PD 1
TimeStamp: Dec 5, 2021 19:10:28        DefaultId: 0x000D000F
SpecData: 8ABBF1350000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32615                           Device: PD 1
TimeStamp: Dec 5, 2021 19:10:30        DefaultId: 0x000D000F
SpecData: 8ABBF1360000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32616                           Device: PD 1
TimeStamp: Dec 5, 2021 19:10:31        DefaultId: 0x000D000F
SpecData: 8ABBF1370000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32617                           Device: PD 1
TimeStamp: Dec 5, 2021 19:10:36        DefaultId: 0x000D000F
SpecData: 8ABBF1380000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32618                           Device: PD 1
TimeStamp: Dec 5, 2021 19:10:42        DefaultId: 0x000D000F
SpecData: 8ABBF1390000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32619                           Device: PD 1
TimeStamp: Dec 5, 2021 19:10:43        DefaultId: 0x000D000F
SpecData: 8ABBF13A0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32620                           Device: PD 1
TimeStamp: Dec 5, 2021 19:10:44        DefaultId: 0x000D000F
SpecData: 8ABBF13B0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32621                           Device: PD 1
TimeStamp: Dec 5, 2021 19:10:46        DefaultId: 0x000D000F
SpecData: 8ABBF13C0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32622                           Device: PD 1
TimeStamp: Dec 5, 2021 19:10:47        DefaultId: 0x000D000F
SpecData: 8ABBF13D0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32623                           Device: PD 1
TimeStamp: Dec 5, 2021 19:10:48        DefaultId: 0x000D000F
SpecData: 8ABBF13E0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32624                           Device: PD 1
TimeStamp: Dec 5, 2021 19:10:50        DefaultId: 0x000D000F
SpecData: 8ABBF13F0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32625                           Device: PD 1
TimeStamp: Dec 5, 2021 19:10:57        DefaultId: 0x000D000F
SpecData: 8ABBF1F80000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32626                           Device: PD 1
TimeStamp: Dec 5, 2021 19:11:01        DefaultId: 0x000D000F
SpecData: 8ABBF1F90000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32627                           Device: PD 1
TimeStamp: Dec 5, 2021 19:11:03        DefaultId: 0x000D000F
SpecData: 8ABBF1FA0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32628                           Device: PD 1
TimeStamp: Dec 5, 2021 19:11:04        DefaultId: 0x000D000F
SpecData: 8ABBF1FB0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32629                           Device: PD 1
TimeStamp: Dec 5, 2021 19:11:05        DefaultId: 0x000D000F
SpecData: 8ABBF1FC0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32630                           Device: PD 1
TimeStamp: Dec 5, 2021 19:11:09        DefaultId: 0x000D000F
SpecData: 8ABBF1FD0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32631                           Device: PD 1
TimeStamp: Dec 5, 2021 19:11:10        DefaultId: 0x000D000F
SpecData: 8ABBF1FE0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32632                           Device: PD 1
TimeStamp: Dec 5, 2021 19:11:11        DefaultId: 0x000D000F
SpecData: 8ABBF1FF0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32633                           Device: PD 1
TimeStamp: Dec 5, 2021 19:11:16        DefaultId: 0x000D000F
SpecData: 8ABBF2000000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32634                           Device: PD 1
TimeStamp: Dec 5, 2021 19:11:20        DefaultId: 0x000D000F
SpecData: 8ABBF2010000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32635                           Device: PD 1
TimeStamp: Dec 5, 2021 19:11:22        DefaultId: 0x000D000F
SpecData: 8ABBF2020000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32636                           Device: PD 1
TimeStamp: Dec 5, 2021 19:11:23        DefaultId: 0x000D000F
SpecData: 8ABBF2030000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32637                           Device: PD 1
TimeStamp: Dec 5, 2021 19:11:24        DefaultId: 0x000D000F
SpecData: 8ABBF2040000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32638                           Device: PD 1
TimeStamp: Dec 5, 2021 19:11:26        DefaultId: 0x000D000F
SpecData: 8ABBF2050000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32639                           Device: PD 1
TimeStamp: Dec 5, 2021 19:11:27        DefaultId: 0x000D000F
SpecData: 8ABBF2060000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32640                           Device: PD 1
TimeStamp: Dec 5, 2021 19:11:28        DefaultId: 0x000D000F
SpecData: 8ABBF2070000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32641                           Device: PD 1
TimeStamp: Dec 5, 2021 19:11:33        DefaultId: 0x000D000F
SpecData: 8ABBF2080000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32642                           Device: PD 1
TimeStamp: Dec 5, 2021 19:11:39        DefaultId: 0x000D000F
SpecData: 8ABBF2090000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32643                           Device: PD 1
TimeStamp: Dec 5, 2021 19:11:40        DefaultId: 0x000D000F
SpecData: 8ABBF20A0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32644                           Device: PD 1
TimeStamp: Dec 5, 2021 19:11:42        DefaultId: 0x000D000F
SpecData: 8ABBF20B0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32645                           Device: PD 1
TimeStamp: Dec 5, 2021 19:11:43        DefaultId: 0x000D000F
SpecData: 8ABBF20C0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32646                           Device: PD 1
TimeStamp: Dec 5, 2021 19:11:44        DefaultId: 0x000D000F
SpecData: 8ABBF20D0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32647                           Device: PD 1
TimeStamp: Dec 5, 2021 19:11:46        DefaultId: 0x000D000F
SpecData: 8ABBF20E0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32648                           Device: PD 1
TimeStamp: Dec 5, 2021 19:11:48        DefaultId: 0x000D000F
SpecData: 8ABBF20F0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32649                           Device: PD 1
TimeStamp: Dec 5, 2021 19:12:09        DefaultId: 0x000D000F
SpecData: 8ABBFB980000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32650                           Device: PD 1
TimeStamp: Dec 5, 2021 19:12:14        DefaultId: 0x000D000F
SpecData: 8ABBFB990000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32651                           Device: PD 1
TimeStamp: Dec 5, 2021 19:12:15        DefaultId: 0x000D000F
SpecData: 8ABBFB9A0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32652                           Device: PD 1
TimeStamp: Dec 5, 2021 19:12:17        DefaultId: 0x000D000F
SpecData: 8ABBFB9B0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32653                           Device: PD 1
TimeStamp: Dec 5, 2021 19:12:19        DefaultId: 0x000D000F
SpecData: 8ABBFB9C0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32654                           Device: PD 1
TimeStamp: Dec 5, 2021 19:12:20        DefaultId: 0x000D000F
SpecData: 8ABBFB9D0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32655                           Device: PD 1
TimeStamp: Dec 5, 2021 19:12:22        DefaultId: 0x000D000F
SpecData: 8ABBFB9E0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32656                           Device: PD 1
TimeStamp: Dec 5, 2021 19:12:23        DefaultId: 0x000D000F
SpecData: 8ABBFB9F0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32657                           Device: PD 1
TimeStamp: Dec 5, 2021 19:12:28        DefaultId: 0x000D000F
SpecData: 8ABBFBA80000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32658                           Device: PD 1
TimeStamp: Dec 5, 2021 19:12:33        DefaultId: 0x000D000F
SpecData: 8ABBFBA90000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32659                           Device: PD 1
TimeStamp: Dec 5, 2021 19:12:34        DefaultId: 0x000D000F
SpecData: 8ABBFBAA0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32660                           Device: PD 1
TimeStamp: Dec 5, 2021 19:12:35        DefaultId: 0x000D000F
SpecData: 8ABBFBAB0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32661                           Device: PD 1
TimeStamp: Dec 5, 2021 19:12:36        DefaultId: 0x000D000F
SpecData: 8ABBFBAC0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32662                           Device: PD 1
TimeStamp: Dec 5, 2021 19:12:38        DefaultId: 0x000D000F
SpecData: 8ABBFBAD0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32663                           Device: PD 1
TimeStamp: Dec 5, 2021 19:12:39        DefaultId: 0x000D000F
SpecData: 8ABBFBAE0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32664                           Device: PD 1
TimeStamp: Dec 5, 2021 19:12:40        DefaultId: 0x000D000F
SpecData: 8ABBFBAF0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32665                           Device: PD 1
TimeStamp: Dec 5, 2021 19:12:45        DefaultId: 0x000D000F
SpecData: 8ABBFBB00000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32666                           Device: PD 1
TimeStamp: Dec 5, 2021 19:12:50        DefaultId: 0x000D000F
SpecData: 8ABBFBB10000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32667                           Device: PD 1
TimeStamp: Dec 5, 2021 19:12:51        DefaultId: 0x000D000F
SpecData: 8ABBFBB20000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32668                           Device: PD 1
TimeStamp: Dec 5, 2021 19:12:53        DefaultId: 0x000D000F
SpecData: 8ABBFBB30000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32669                           Device: PD 1
TimeStamp: Dec 5, 2021 19:12:54        DefaultId: 0x000D000F
SpecData: 8ABBFBB40000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32670                           Device: PD 1
TimeStamp: Dec 5, 2021 19:12:55        DefaultId: 0x000D000F
SpecData: 8ABBFBB50000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32671                           Device: PD 1
TimeStamp: Dec 5, 2021 19:12:56        DefaultId: 0x000D000F
SpecData: 8ABBFBB60000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32672                           Device: PD 1
TimeStamp: Dec 5, 2021 19:12:58        DefaultId: 0x000D000F
SpecData: 8ABBFBB70000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32673                           Device: PD 1
TimeStamp: Dec 5, 2021 19:13:03        DefaultId: 0x000D000F
SpecData: 8ABBFBB80000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32674                           Device: PD 1
TimeStamp: Dec 5, 2021 19:13:08        DefaultId: 0x000D000F
SpecData: 8ABBFBB90000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32675                           Device: PD 1
TimeStamp: Dec 5, 2021 19:13:10        DefaultId: 0x000D000F
SpecData: 8ABBFBBA0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32676                           Device: PD 1
TimeStamp: Dec 5, 2021 19:13:11        DefaultId: 0x000D000F
SpecData: 8ABBFBBB0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32677                           Device: PD 1
TimeStamp: Dec 5, 2021 19:13:12        DefaultId: 0x000D000F
SpecData: 8ABBFBBC0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32678                           Device: PD 1
TimeStamp: Dec 5, 2021 19:13:14        DefaultId: 0x000D000F
SpecData: 8ABBFBBD0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32679                           Device: PD 1
TimeStamp: Dec 5, 2021 19:13:15        DefaultId: 0x000D000F
SpecData: 8ABBFBBE0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32680                           Device: PD 1
TimeStamp: Dec 5, 2021 19:13:16        DefaultId: 0x000D000F
SpecData: 8ABBFBBF0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32681                           Device: PD 1
TimeStamp: Dec 5, 2021 19:13:22        DefaultId: 0x000D000F
SpecData: 8ABBFBC00000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32682                           Device: PD 1
TimeStamp: Dec 5, 2021 19:13:27        DefaultId: 0x000D000F
SpecData: 8ABBFBC10000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32683                           Device: PD 1
TimeStamp: Dec 5, 2021 19:13:28        DefaultId: 0x000D000F
SpecData: 8ABBFBC20000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32684                           Device: PD 1
TimeStamp: Dec 5, 2021 19:13:29        DefaultId: 0x000D000F
SpecData: 8ABBFBC30000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32685                           Device: PD 1
TimeStamp: Dec 5, 2021 19:13:31        DefaultId: 0x000D000F
SpecData: 8ABBFBC40000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32686                           Device: PD 1
TimeStamp: Dec 5, 2021 19:13:32        DefaultId: 0x000D000F
SpecData: 8ABBFBC50000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32687                           Device: PD 1
EventId: 0x000D000F                    Severity: Minor
TimeStamp: Dec 5, 2021 19:13:33        DefaultId: 0x000D000F
SpecData: 8ABBFBC60000000000 0000012020202020 2020202020203734 3756535A4B4B53
Description: Bad sector is found on physical disk
SeqNo: 32688                           Device: PD 1
TimeStamp: Dec 5, 2021 19:13:35        DefaultId: 0x000D000F
SpecData: 8ABBFBC70000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32689                           Device: PD 1
TimeStamp: Dec 5, 2021 19:13:39        DefaultId: 0x000D000F
SpecData: 8ABBFBC80000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32690                           Device: PD 1
TimeStamp: Dec 5, 2021 19:13:44        DefaultId: 0x000D000F
SpecData: 8ABBFBC90000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32691                           Device: PD 1
TimeStamp: Dec 5, 2021 19:13:46        DefaultId: 0x000D000F
SpecData: 8ABBFBCA0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32692                           Device: PD 1
TimeStamp: Dec 5, 2021 19:13:47        DefaultId: 0x000D000F
SpecData: 8ABBFBCB0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32693                           Device: PD 1
TimeStamp: Dec 5, 2021 19:13:48        DefaultId: 0x000D000F
SpecData: 8ABBFBCC0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32694                           Device: PD 1
TimeStamp: Dec 5, 2021 19:13:49        DefaultId: 0x000D000F
SpecData: 8ABBFBCD0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32695                           Device: PD 1
TimeStamp: Dec 5, 2021 19:13:51        DefaultId: 0x000D000F
SpecData: 8ABBFBCE0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32696                           Device: PD 1
TimeStamp: Dec 5, 2021 19:13:52        DefaultId: 0x000D000F
SpecData: 8ABBFBCF0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32697                           Device: PD 1
TimeStamp: Dec 5, 2021 19:13:57        DefaultId: 0x000D000F
SpecData: 8ABBFBD00000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32698                           Device: PD 1
TimeStamp: Dec 5, 2021 19:14:02        DefaultId: 0x000D000F
SpecData: 8ABBFBD10000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32699                           Device: PD 1
TimeStamp: Dec 5, 2021 19:14:03        DefaultId: 0x000D000F
SpecData: 8ABBFBD20000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32700                           Device: PD 1
TimeStamp: Dec 5, 2021 19:14:04        DefaultId: 0x000D000F
SpecData: 8ABBFBD30000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32701                           Device: PD 1
TimeStamp: Dec 5, 2021 19:14:06        DefaultId: 0x000D000F
SpecData: 8ABBFBD40000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32702                           Device: PD 1
TimeStamp: Dec 5, 2021 19:14:08        DefaultId: 0x000D000F
SpecData: 8ABBFBD50000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32703                           Device: PD 1
TimeStamp: Dec 5, 2021 19:14:09        DefaultId: 0x000D000F
SpecData: 8ABBFBD60000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32704                           Device: PD 1
TimeStamp: Dec 5, 2021 19:14:11        DefaultId: 0x000D000F
SpecData: 8ABBFBD70000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32705                           Device: PD 1
TimeStamp: Dec 5, 2021 19:14:37        DefaultId: 0x000D000F
SpecData: 8ABC02880000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32706                           Device: PD 1
TimeStamp: Dec 5, 2021 19:14:42        DefaultId: 0x000D000F
SpecData: 8ABC02890000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32707                           Device: PD 1
TimeStamp: Dec 5, 2021 19:14:43        DefaultId: 0x000D000F
SpecData: 8ABC028A0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32708                           Device: PD 1
TimeStamp: Dec 5, 2021 19:14:45        DefaultId: 0x000D000F
SpecData: 8ABC028B0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32709                           Device: PD 1
TimeStamp: Dec 5, 2021 19:14:47        DefaultId: 0x000D000F
SpecData: 8ABC028C0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32710                           Device: PD 1
TimeStamp: Dec 5, 2021 19:14:48        DefaultId: 0x000D000F
SpecData: 8ABC028D0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32711                           Device: PD 1
TimeStamp: Dec 5, 2021 19:14:49        DefaultId: 0x000D000F
SpecData: 8ABC028E0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32712                           Device: PD 1
TimeStamp: Dec 5, 2021 19:14:51        DefaultId: 0x000D000F
SpecData: 8ABC028F0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32713                           Device: PD 1
TimeStamp: Dec 5, 2021 19:15:04        DefaultId: 0x000D000F
SpecData: 8ABC02B80000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32714                           Device: PD 1
TimeStamp: Dec 5, 2021 19:15:09        DefaultId: 0x000D000F
SpecData: 8ABC02B90000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32715                           Device: PD 1
TimeStamp: Dec 5, 2021 19:15:10        DefaultId: 0x000D000F
SpecData: 8ABC02BA0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32716                           Device: PD 1
TimeStamp: Dec 5, 2021 19:15:12        DefaultId: 0x000D000F
SpecData: 8ABC02BB0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32717                           Device: PD 1
TimeStamp: Dec 5, 2021 19:15:13        DefaultId: 0x000D000F
SpecData: 8ABC02BC0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32718                           Device: PD 1
TimeStamp: Dec 5, 2021 19:15:14        DefaultId: 0x000D000F
SpecData: 8ABC02BD0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32719                           Device: PD 1
TimeStamp: Dec 5, 2021 19:15:16        DefaultId: 0x000D000F
SpecData: 8ABC02BE0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32720                           Device: PD 1
TimeStamp: Dec 5, 2021 19:15:17        DefaultId: 0x000D000F
SpecData: 8ABC02BF0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32721                           Device: PD 1
TimeStamp: Dec 5, 2021 19:15:22        DefaultId: 0x000D000F
SpecData: 8ABC02C00000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32722                           Device: PD 1
TimeStamp: Dec 5, 2021 19:15:27        DefaultId: 0x000D000F
SpecData: 8ABC02C10000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32723                           Device: PD 1
TimeStamp: Dec 5, 2021 19:15:28        DefaultId: 0x000D000F
SpecData: 8ABC02C20000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32724                           Device: PD 1
TimeStamp: Dec 5, 2021 19:15:29        DefaultId: 0x000D000F
SpecData: 8ABC02C30000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32725                           Device: PD 1
TimeStamp: Dec 5, 2021 19:15:31        DefaultId: 0x000D000F
SpecData: 8ABC02C40000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32726                           Device: PD 1
TimeStamp: Dec 5, 2021 19:15:32        DefaultId: 0x000D000F
SpecData: 8ABC02C50000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32727                           Device: PD 1
TimeStamp: Dec 5, 2021 19:15:33        DefaultId: 0x000D000F
SpecData: 8ABC02C60000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32728                           Device: PD 1
TimeStamp: Dec 5, 2021 19:15:35        DefaultId: 0x000D000F
SpecData: 8ABC02C70000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32729                           Device: PD 1
TimeStamp: Dec 5, 2021 19:15:41        DefaultId: 0x000D000F
SpecData: 8ABC02C80000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32730                           Device: PD 1
TimeStamp: Dec 5, 2021 19:15:46        DefaultId: 0x000D000F
SpecData: 8ABC02C90000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32731                           Device: PD 1
TimeStamp: Dec 5, 2021 19:15:47        DefaultId: 0x000D000F
SpecData: 8ABC02CA0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32732                           Device: PD 1
TimeStamp: Dec 5, 2021 19:15:48        DefaultId: 0x000D000F
SpecData: 8ABC02CB0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32733                           Device: PD 1
TimeStamp: Dec 5, 2021 19:15:50        DefaultId: 0x000D000F
SpecData: 8ABC02CC0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32734                           Device: PD 1
TimeStamp: Dec 5, 2021 19:15:51        DefaultId: 0x000D000F
SpecData: 8ABC02CD0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32735                           Device: PD 1
TimeStamp: Dec 5, 2021 19:15:52        DefaultId: 0x000D000F
SpecData: 8ABC02CE0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32736                           Device: PD 1
TimeStamp: Dec 5, 2021 19:15:54        DefaultId: 0x000D000F
SpecData: 8ABC02CF0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32737                           Device: PD 1
TimeStamp: Dec 5, 2021 19:15:59        DefaultId: 0x000D000F
SpecData: 8ABC02D00000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32738                           Device: PD 1
TimeStamp: Dec 5, 2021 19:16:03        DefaultId: 0x000D000F
SpecData: 8ABC02D10000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32739                           Device: PD 1
TimeStamp: Dec 5, 2021 19:16:05        DefaultId: 0x000D000F
SpecData: 8ABC02D20000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32740                           Device: PD 1
TimeStamp: Dec 5, 2021 19:16:07        DefaultId: 0x000D000F
SpecData: 8ABC02D30000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32741                           Device: PD 1
TimeStamp: Dec 5, 2021 19:16:08        DefaultId: 0x000D000F
SpecData: 8ABC02D40000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32742                           Device: PD 1
TimeStamp: Dec 5, 2021 19:16:10        DefaultId: 0x000D000F
SpecData: 8ABC02D50000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32743                           Device: PD 1
TimeStamp: Dec 5, 2021 19:16:11        DefaultId: 0x000D000F
SpecData: 8ABC02D60000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32744                           Device: PD 1
TimeStamp: Dec 5, 2021 19:16:12        DefaultId: 0x000D000F
SpecData: 8ABC02D70000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32745                           Device: PD 1
TimeStamp: Dec 5, 2021 19:16:18        DefaultId: 0x000D000F
SpecData: 8ABC02D80000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32746                           Device: PD 1
TimeStamp: Dec 5, 2021 19:16:23        DefaultId: 0x000D000F
SpecData: 8ABC02D90000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32747                           Device: PD 1
TimeStamp: Dec 5, 2021 19:16:25        DefaultId: 0x000D000F
SpecData: 8ABC02DA0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32748                           Device: PD 1
TimeStamp: Dec 5, 2021 19:16:26        DefaultId: 0x000D000F
SpecData: 8ABC02DB0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32749                           Device: PD 1
TimeStamp: Dec 5, 2021 19:16:27        DefaultId: 0x000D000F
SpecData: 8ABC02DC0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32750                           Device: PD 1
TimeStamp: Dec 5, 2021 19:16:29        DefaultId: 0x000D000F
SpecData: 8ABC02DD0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32751                           Device: PD 1
TimeStamp: Dec 5, 2021 19:16:30        DefaultId: 0x000D000F
SpecData: 8ABC02DE0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32752                           Device: PD 1
TimeStamp: Dec 5, 2021 19:16:31        DefaultId: 0x000D000F
SpecData: 8ABC02DF0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32753                           Device: PD 1
TimeStamp: Dec 5, 2021 19:16:36        DefaultId: 0x000D000F
SpecData: 8ABC02E00000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32754                           Device: PD 1
TimeStamp: Dec 5, 2021 19:16:42        DefaultId: 0x000D000F
SpecData: 8ABC02E10000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32755                           Device: PD 1
TimeStamp: Dec 5, 2021 19:16:43        DefaultId: 0x000D000F
SpecData: 8ABC02E20000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32756                           Device: PD 1
TimeStamp: Dec 5, 2021 19:16:45        DefaultId: 0x000D000F
SpecData: 8ABC02E30000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32757                           Device: PD 1
TimeStamp: Dec 5, 2021 19:16:46        DefaultId: 0x000D000F
SpecData: 8ABC02E40000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32758                           Device: PD 1
TimeStamp: Dec 5, 2021 19:16:47        DefaultId: 0x000D000F
SpecData: 8ABC02E50000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32759                           Device: PD 1
TimeStamp: Dec 5, 2021 19:16:49        DefaultId: 0x000D000F
SpecData: 8ABC02E60000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32760                           Device: PD 1
TimeStamp: Dec 5, 2021 19:16:50        DefaultId: 0x000D000F
SpecData: 8ABC02E70000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32761                           Device: PD 1
TimeStamp: Dec 5, 2021 19:16:58        DefaultId: 0x000D000F
SpecData: 8ABC02F80000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32762                           Device: PD 1
TimeStamp: Dec 5, 2021 19:17:03        DefaultId: 0x000D000F
SpecData: 8ABC02F90000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32763                           Device: PD 1
TimeStamp: Dec 5, 2021 19:17:05        DefaultId: 0x000D000F
SpecData: 8ABC02FA0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32764                           Device: PD 1
TimeStamp: Dec 5, 2021 19:17:06        DefaultId: 0x000D000F
SpecData: 8ABC02FB0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32765                           Device: PD 1
TimeStamp: Dec 5, 2021 19:17:08        DefaultId: 0x000D000F
SpecData: 8ABC02FC0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32766                           Device: PD 1
TimeStamp: Dec 5, 2021 19:17:10        DefaultId: 0x000D000F
SpecData: 8ABC02FD0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32767                           Device: PD 1
TimeStamp: Dec 5, 2021 19:17:11        DefaultId: 0x000D000F
SpecData: 8ABC02FE0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32768                           Device: PD 1
TimeStamp: Dec 5, 2021 19:17:12        DefaultId: 0x000D000F
SpecData: 8ABC02FF0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32769                           Device: PD 1
TimeStamp: Dec 5, 2021 19:17:17        DefaultId: 0x000D000F
SpecData: 8ABC03000000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32770                           Device: PD 1
TimeStamp: Dec 5, 2021 19:17:22        DefaultId: 0x000D000F
SpecData: 8ABC03010000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32771                           Device: PD 1
TimeStamp: Dec 5, 2021 19:17:24        DefaultId: 0x000D000F
SpecData: 8ABC03020000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32772                           Device: PD 1
TimeStamp: Dec 5, 2021 19:17:25        DefaultId: 0x000D000F
SpecData: 8ABC03030000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32773                           Device: PD 1
TimeStamp: Dec 5, 2021 19:17:26        DefaultId: 0x000D000F
SpecData: 8ABC03040000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32774                           Device: PD 1
TimeStamp: Dec 5, 2021 19:17:28        DefaultId: 0x000D000F
SpecData: 8ABC03050000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32775                           Device: PD 1
TimeStamp: Dec 5, 2021 19:17:29        DefaultId: 0x000D000F
SpecData: 8ABC03060000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32776                           Device: PD 1
TimeStamp: Dec 5, 2021 19:17:30        DefaultId: 0x000D000F
SpecData: 8ABC03070000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32777                           Device: PD 1
TimeStamp: Dec 5, 2021 19:17:35        DefaultId: 0x000D000F
SpecData: 8ABC03080000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32778                           Device: PD 1
TimeStamp: Dec 5, 2021 19:17:41        DefaultId: 0x000D000F
SpecData: 8ABC03090000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32779                           Device: PD 1
TimeStamp: Dec 5, 2021 19:17:42        DefaultId: 0x000D000F
SpecData: 8ABC030A0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32780                           Device: PD 1
TimeStamp: Dec 5, 2021 19:17:44        DefaultId: 0x000D000F
SpecData: 8ABC030B0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32781                           Device: PD 1
TimeStamp: Dec 5, 2021 19:17:45        DefaultId: 0x000D000F
SpecData: 8ABC030C0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32782                           Device: PD 1
TimeStamp: Dec 5, 2021 19:17:46        DefaultId: 0x000D000F
SpecData: 8ABC030D0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32783                           Device: PD 1
TimeStamp: Dec 5, 2021 19:17:49        DefaultId: 0x000D000F
SpecData: 8ABC030E0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32784                           Device: PD 1
TimeStamp: Dec 5, 2021 19:17:50        DefaultId: 0x000D000F
SpecData: 8ABC030F0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32785                           Device: PD 1
TimeStamp: Dec 5, 2021 19:17:55        DefaultId: 0x000D000F
SpecData: 8ABC03100000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32786                           Device: PD 1
TimeStamp: Dec 5, 2021 19:18:00        DefaultId: 0x000D000F
SpecData: 8ABC03110000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32787                           Device: PD 1
TimeStamp: Dec 5, 2021 19:18:01        DefaultId: 0x000D000F
SpecData: 8ABC03120000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32788                           Device: PD 1
TimeStamp: Dec 5, 2021 19:18:03        DefaultId: 0x000D000F
SpecData: 8ABC03130000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32789                           Device: PD 1
TimeStamp: Dec 5, 2021 19:18:04        DefaultId: 0x000D000F
SpecData: 8ABC03140000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32790                           Device: PD 1
TimeStamp: Dec 5, 2021 19:18:05        DefaultId: 0x000D000F
SpecData: 8ABC03150000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32791                           Device: PD 1
TimeStamp: Dec 5, 2021 19:18:06        DefaultId: 0x000D000F
SpecData: 8ABC03160000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32792                           Device: PD 1
TimeStamp: Dec 5, 2021 19:18:08        DefaultId: 0x000D000F
SpecData: 8ABC03170000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32793                           Device: PD 1
TimeStamp: Dec 5, 2021 19:18:13        DefaultId: 0x000D000F
SpecData: 8ABC03180000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32794                           Device: PD 1
TimeStamp: Dec 5, 2021 19:18:18        DefaultId: 0x000D000F
SpecData: 8ABC03190000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32795                           Device: PD 1
TimeStamp: Dec 5, 2021 19:18:19        DefaultId: 0x000D000F
SpecData: 8ABC031A0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32796                           Device: PD 1
TimeStamp: Dec 5, 2021 19:18:20        DefaultId: 0x000D000F
SpecData: 8ABC031B0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32797                           Device: PD 1
TimeStamp: Dec 5, 2021 19:18:22        DefaultId: 0x000D000F
SpecData: 8ABC031C0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32798                           Device: PD 1
TimeStamp: Dec 5, 2021 19:18:23        DefaultId: 0x000D000F
SpecData: 8ABC031D0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32799                           Device: PD 1
TimeStamp: Dec 5, 2021 19:18:24        DefaultId: 0x000D000F
SpecData: 8ABC031E0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32800                           Device: PD 1
TimeStamp: Dec 5, 2021 19:18:26        DefaultId: 0x000D000F
SpecData: 8ABC031F0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32801                           Device: PD 1
TimeStamp: Dec 5, 2021 19:18:31        DefaultId: 0x000D000F
SpecData: 8ABC03280000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32802                           Device: PD 1
TimeStamp: Dec 5, 2021 19:18:36        DefaultId: 0x000D000F
SpecData: 8ABC03290000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32803                           Device: PD 1
TimeStamp: Dec 5, 2021 19:18:38        DefaultId: 0x000D000F
SpecData: 8ABC032A0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32804                           Device: PD 1
TimeStamp: Dec 5, 2021 19:18:39        DefaultId: 0x000D000F
SpecData: 8ABC032B0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32805                           Device: PD 1
TimeStamp: Dec 5, 2021 19:18:41        DefaultId: 0x000D000F
SpecData: 8ABC032C0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32806                           Device: PD 1
TimeStamp: Dec 5, 2021 19:18:42        DefaultId: 0x000D000F
SpecData: 8ABC032D0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32807                           Device: PD 1
TimeStamp: Dec 5, 2021 19:18:43        DefaultId: 0x000D000F
SpecData: 8ABC032E0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32808                           Device: PD 1
TimeStamp: Dec 5, 2021 19:18:45        DefaultId: 0x000D000F
SpecData: 8ABC032F0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32809                           Device: PD 1
TimeStamp: Dec 5, 2021 19:18:50        DefaultId: 0x000D000F
SpecData: 8ABC03300000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32810                           Device: PD 1
TimeStamp: Dec 5, 2021 19:18:54        DefaultId: 0x000D000F
SpecData: 8ABC03310000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32811                           Device: PD 1
TimeStamp: Dec 5, 2021 19:18:56        DefaultId: 0x000D000F
SpecData: 8ABC03320000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32812                           Device: PD 1
TimeStamp: Dec 5, 2021 19:18:57        DefaultId: 0x000D000F
SpecData: 8ABC03330000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32813                           Device: PD 1
TimeStamp: Dec 5, 2021 19:18:58        DefaultId: 0x000D000F
SpecData: 8ABC03340000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32814                           Device: PD 1
TimeStamp: Dec 5, 2021 19:19:00        DefaultId: 0x000D000F
SpecData: 8ABC03350000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32815                           Device: PD 1
TimeStamp: Dec 5, 2021 19:19:01        DefaultId: 0x000D000F
SpecData: 8ABC03360000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32816                           Device: PD 1
TimeStamp: Dec 5, 2021 19:19:02        DefaultId: 0x000D000F
SpecData: 8ABC03370000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32817                           Device: PD 1
TimeStamp: Dec 5, 2021 19:19:08        DefaultId: 0x000D000F
SpecData: 8ABC03380000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32818                           Device: PD 1
TimeStamp: Dec 5, 2021 19:19:13        DefaultId: 0x000D000F
SpecData: 8ABC03390000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32819                           Device: PD 1
TimeStamp: Dec 5, 2021 19:19:15        DefaultId: 0x000D000F
SpecData: 8ABC033A0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32820                           Device: PD 1
TimeStamp: Dec 5, 2021 19:19:16        DefaultId: 0x000D000F
SpecData: 8ABC033B0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32821                           Device: PD 1
TimeStamp: Dec 5, 2021 19:19:17        DefaultId: 0x000D000F
SpecData: 8ABC033C0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32822                           Device: PD 1
TimeStamp: Dec 5, 2021 19:19:19        DefaultId: 0x000D000F
SpecData: 8ABC033D0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32823                           Device: PD 1
TimeStamp: Dec 5, 2021 19:19:20        DefaultId: 0x000D000F
SpecData: 8ABC033E0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32824                           Device: PD 1
TimeStamp: Dec 5, 2021 19:19:21        DefaultId: 0x000D000F
SpecData: 8ABC033F0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32825                           Device: PD 1
TimeStamp: Dec 5, 2021 19:19:26        DefaultId: 0x000D000F
SpecData: 8ABC03400000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32826                           Device: PD 1
TimeStamp: Dec 5, 2021 19:19:31        DefaultId: 0x000D000F
SpecData: 8ABC03410000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32827                           Device: PD 1
TimeStamp: Dec 5, 2021 19:19:32        DefaultId: 0x000D000F
SpecData: 8ABC03420000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32828                           Device: PD 1
TimeStamp: Dec 5, 2021 19:19:34        DefaultId: 0x000D000F
SpecData: 8ABC03430000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32829                           Device: PD 1
TimeStamp: Dec 5, 2021 19:19:35        DefaultId: 0x000D000F
SpecData: 8ABC03440000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32830                           Device: PD 1
TimeStamp: Dec 5, 2021 19:19:37        DefaultId: 0x000D000F
SpecData: 8ABC03450000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32831                           Device: PD 1
TimeStamp: Dec 5, 2021 19:19:39        DefaultId: 0x000D000F
SpecData: 8ABC03460000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32832                           Device: PD 1
TimeStamp: Dec 5, 2021 19:19:40        DefaultId: 0x000D000F
SpecData: 8ABC03470000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32833                           Device: PD 1
TimeStamp: Dec 5, 2021 19:19:45        DefaultId: 0x000D000F
SpecData: 8ABC03480000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32834                           Device: PD 1
TimeStamp: Dec 5, 2021 19:19:50        DefaultId: 0x000D000F
SpecData: 8ABC03490000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32835                           Device: PD 1
TimeStamp: Dec 5, 2021 19:19:51        DefaultId: 0x000D000F
SpecData: 8ABC034A0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32836                           Device: PD 1
TimeStamp: Dec 5, 2021 19:19:53        DefaultId: 0x000D000F
SpecData: 8ABC034B0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32837                           Device: PD 1
TimeStamp: Dec 5, 2021 19:19:54        DefaultId: 0x000D000F
SpecData: 8ABC034C0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32838                           Device: PD 1
TimeStamp: Dec 5, 2021 19:19:55        DefaultId: 0x000D000F
SpecData: 8ABC034D0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32839                           Device: PD 1
TimeStamp: Dec 5, 2021 19:19:57        DefaultId: 0x000D000F
SpecData: 8ABC034E0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32840                           Device: PD 1
TimeStamp: Dec 5, 2021 19:19:58        DefaultId: 0x000D000F
SpecData: 8ABC034F0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32841                           Device: PD 1
TimeStamp: Dec 5, 2021 19:20:03        DefaultId: 0x000D000F
SpecData: 8ABC03500000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32842                           Device: PD 1
TimeStamp: Dec 5, 2021 19:20:09        DefaultId: 0x000D000F
SpecData: 8ABC03510000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32843                           Device: PD 1
TimeStamp: Dec 5, 2021 19:20:10        DefaultId: 0x000D000F
SpecData: 8ABC03520000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32844                           Device: PD 1
TimeStamp: Dec 5, 2021 19:20:11        DefaultId: 0x000D000F
SpecData: 8ABC03530000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32845                           Device: PD 1
TimeStamp: Dec 5, 2021 19:20:13        DefaultId: 0x000D000F
SpecData: 8ABC03540000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32846                           Device: PD 1
TimeStamp: Dec 5, 2021 19:20:14        DefaultId: 0x000D000F
SpecData: 8ABC03550000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32847                           Device: PD 1
TimeStamp: Dec 5, 2021 19:20:15        DefaultId: 0x000D000F
SpecData: 8ABC03560000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32848                           Device: PD 1
TimeStamp: Dec 5, 2021 19:20:17        DefaultId: 0x000D000F
SpecData: 8ABC03570000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32849                           Device: PD 1
TimeStamp: Dec 5, 2021 19:20:22        DefaultId: 0x000D000F
SpecData: 8ABC03580000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32850                           Device: PD 1
TimeStamp: Dec 5, 2021 19:20:27        DefaultId: 0x000D000F
SpecData: 8ABC03590000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32851                           Device: PD 1
TimeStamp: Dec 5, 2021 19:20:28        DefaultId: 0x000D000F
SpecData: 8ABC035A0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32852                           Device: PD 1
TimeStamp: Dec 5, 2021 19:20:29        DefaultId: 0x000D000F
SpecData: 8ABC035B0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32853                           Device: PD 1
TimeStamp: Dec 5, 2021 19:20:31        DefaultId: 0x000D000F
SpecData: 8ABC035C0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32854                           Device: PD 1
TimeStamp: Dec 5, 2021 19:20:32        DefaultId: 0x000D000F
SpecData: 8ABC035D0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32855                           Device: PD 1
TimeStamp: Dec 5, 2021 19:20:33        DefaultId: 0x000D000F
SpecData: 8ABC035E0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32856                           Device: PD 1
TimeStamp: Dec 5, 2021 19:20:35        DefaultId: 0x000D000F
SpecData: 8ABC035F0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32857                           Device: PD 1
TimeStamp: Dec 5, 2021 19:20:44        DefaultId: 0x000D000F
SpecData: 8ABC03780000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32858                           Device: PD 1
TimeStamp: Dec 5, 2021 19:20:49        DefaultId: 0x000D000F
SpecData: 8ABC03790000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32859                           Device: PD 1
TimeStamp: Dec 5, 2021 19:20:50        DefaultId: 0x000D000F
SpecData: 8ABC037A0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32860                           Device: PD 1
TimeStamp: Dec 5, 2021 19:20:51        DefaultId: 0x000D000F
SpecData: 8ABC037B0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32861                           Device: PD 1
TimeStamp: Dec 5, 2021 19:20:53        DefaultId: 0x000D000F
SpecData: 8ABC037C0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32862                           Device: PD 1
TimeStamp: Dec 5, 2021 19:20:54        DefaultId: 0x000D000F
SpecData: 8ABC037D0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32863                           Device: PD 1
TimeStamp: Dec 5, 2021 19:20:55        DefaultId: 0x000D000F
SpecData: 8ABC037E0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32864                           Device: PD 1
TimeStamp: Dec 5, 2021 19:20:57        DefaultId: 0x000D000F
SpecData: 8ABC037F0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32865                           Device: PD 1
TimeStamp: Dec 5, 2021 19:21:02        DefaultId: 0x000D000F
SpecData: 8ABC03800000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32866                           Device: PD 1
TimeStamp: Dec 5, 2021 19:21:07        DefaultId: 0x000D000F
SpecData: 8ABC03810000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32867                           Device: PD 1
TimeStamp: Dec 5, 2021 19:21:09        DefaultId: 0x000D000F
SpecData: 8ABC03820000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32868                           Device: PD 1
TimeStamp: Dec 5, 2021 19:21:10        DefaultId: 0x000D000F
SpecData: 8ABC03830000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32869                           Device: PD 1
TimeStamp: Dec 5, 2021 19:21:11        DefaultId: 0x000D000F
SpecData: 8ABC03840000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32870                           Device: PD 1
TimeStamp: Dec 5, 2021 19:21:13        DefaultId: 0x000D000F
SpecData: 8ABC03850000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32871                           Device: PD 1
TimeStamp: Dec 5, 2021 19:21:14        DefaultId: 0x000D000F
SpecData: 8ABC03860000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32872                           Device: PD 1
TimeStamp: Dec 5, 2021 19:21:15        DefaultId: 0x000D000F
SpecData: 8ABC03870000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32873                           Device: PD 1
TimeStamp: Dec 5, 2021 19:21:45        DefaultId: 0x000D000F
SpecData: 8ABC04780000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32874                           Device: PD 1
TimeStamp: Dec 5, 2021 19:21:49        DefaultId: 0x000D000F
SpecData: 8ABC04790000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32875                           Device: PD 1
TimeStamp: Dec 5, 2021 19:21:51        DefaultId: 0x000D000F
SpecData: 8ABC047A0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32876                           Device: PD 1
TimeStamp: Dec 5, 2021 19:21:52        DefaultId: 0x000D000F
SpecData: 8ABC047B0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32877                           Device: PD 1
TimeStamp: Dec 5, 2021 19:21:53        DefaultId: 0x000D000F
SpecData: 8ABC047C0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32878                           Device: PD 1
TimeStamp: Dec 5, 2021 19:21:55        DefaultId: 0x000D000F
SpecData: 8ABC047D0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32879                           Device: PD 1
TimeStamp: Dec 5, 2021 19:21:56        DefaultId: 0x000D000F
SpecData: 8ABC047E0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32880                           Device: PD 1
TimeStamp: Dec 5, 2021 19:21:57        DefaultId: 0x000D000F
SpecData: 8ABC047F0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32881                           Device: PD 1
TimeStamp: Dec 5, 2021 19:22:12        DefaultId: 0x000D000F
SpecData: 8ABC04A00000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32882                           Device: PD 1
TimeStamp: Dec 5, 2021 19:22:17        DefaultId: 0x000D000F
SpecData: 8ABC04A10000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32883                           Device: PD 1
TimeStamp: Dec 5, 2021 19:22:18        DefaultId: 0x000D000F
SpecData: 8ABC04A20000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32884                           Device: PD 1
TimeStamp: Dec 5, 2021 19:22:19        DefaultId: 0x000D000F
SpecData: 8ABC04A30000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32885                           Device: PD 1
TimeStamp: Dec 5, 2021 19:22:21        DefaultId: 0x000D000F
SpecData: 8ABC04A40000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32886                           Device: PD 1
TimeStamp: Dec 5, 2021 19:22:22        DefaultId: 0x000D000F
SpecData: 8ABC04A50000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32887                           Device: PD 1
TimeStamp: Dec 5, 2021 19:22:23        DefaultId: 0x000D000F
SpecData: 8ABC04A60000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32888                           Device: PD 1
TimeStamp: Dec 5, 2021 19:22:25        DefaultId: 0x000D000F
SpecData: 8ABC04A70000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32889                           Device: PD 1
TimeStamp: Dec 5, 2021 19:22:31        DefaultId: 0x000D000F
SpecData: 8ABC04A80000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32890                           Device: PD 1
TimeStamp: Dec 5, 2021 19:22:36        DefaultId: 0x000D000F
SpecData: 8ABC04A90000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32891                           Device: PD 1
TimeStamp: Dec 5, 2021 19:22:37        DefaultId: 0x000D000F
SpecData: 8ABC04AA0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32892                           Device: PD 1
TimeStamp: Dec 5, 2021 19:22:38        DefaultId: 0x000D000F
SpecData: 8ABC04AB0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32893                           Device: PD 1
TimeStamp: Dec 5, 2021 19:22:40        DefaultId: 0x000D000F
SpecData: 8ABC04AC0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32894                           Device: PD 1
TimeStamp: Dec 5, 2021 19:22:41        DefaultId: 0x000D000F
SpecData: 8ABC04AD0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32895                           Device: PD 1
TimeStamp: Dec 5, 2021 19:22:42        DefaultId: 0x000D000F
SpecData: 8ABC04AE0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32896                           Device: PD 1
TimeStamp: Dec 5, 2021 19:22:44        DefaultId: 0x000D000F
SpecData: 8ABC04AF0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32897                           Device: PD 1
TimeStamp: Dec 5, 2021 19:22:49        DefaultId: 0x000D000F
SpecData: 8ABC04B00000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32898                           Device: PD 1
TimeStamp: Dec 5, 2021 19:22:53        DefaultId: 0x000D000F
SpecData: 8ABC04B10000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32899                           Device: PD 1
TimeStamp: Dec 5, 2021 19:22:55        DefaultId: 0x000D000F
SpecData: 8ABC04B20000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32900                           Device: PD 1
TimeStamp: Dec 5, 2021 19:22:56        DefaultId: 0x000D000F
SpecData: 8ABC04B30000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32901                           Device: PD 1
TimeStamp: Dec 5, 2021 19:22:58        DefaultId: 0x000D000F
SpecData: 8ABC04B40000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32902                           Device: PD 1
TimeStamp: Dec 5, 2021 19:23:00        DefaultId: 0x000D000F
SpecData: 8ABC04B50000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32903                           Device: PD 1
TimeStamp: Dec 5, 2021 19:23:01        DefaultId: 0x000D000F
SpecData: 8ABC04B60000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32904                           Device: PD 1
TimeStamp: Dec 5, 2021 19:23:02        DefaultId: 0x000D000F
SpecData: 8ABC04B70000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32905                           Device: PD 1
TimeStamp: Dec 5, 2021 19:23:10        DefaultId: 0x000D000F
SpecData: 8ABC04C00000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32906                           Device: PD 1
TimeStamp: Dec 5, 2021 19:23:15        DefaultId: 0x000D000F
SpecData: 8ABC04C10000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32907                           Device: PD 1
TimeStamp: Dec 5, 2021 19:23:17        DefaultId: 0x000D000F
SpecData: 8ABC04C20000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32908                           Device: PD 1
TimeStamp: Dec 5, 2021 19:23:18        DefaultId: 0x000D000F
SpecData: 8ABC04C30000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32909                           Device: PD 1
TimeStamp: Dec 5, 2021 19:23:19        DefaultId: 0x000D000F
SpecData: 8ABC04C40000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32910                           Device: PD 1
TimeStamp: Dec 5, 2021 19:23:21        DefaultId: 0x000D000F
SpecData: 8ABC04C50000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32911                           Device: PD 1
TimeStamp: Dec 5, 2021 19:23:22        DefaultId: 0x000D000F
SpecData: 8ABC04C60000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32912                           Device: PD 1
TimeStamp: Dec 5, 2021 19:23:23        DefaultId: 0x000D000F
SpecData: 8ABC04C70000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32913                           Device: PD 1
TimeStamp: Dec 5, 2021 19:23:29        DefaultId: 0x000D000F
SpecData: 8ABC04C80000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32914                           Device: PD 1
TimeStamp: Dec 5, 2021 19:23:34        DefaultId: 0x000D000F
SpecData: 8ABC04C90000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32915                           Device: PD 1
TimeStamp: Dec 5, 2021 19:23:35        DefaultId: 0x000D000F
SpecData: 8ABC04CA0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32916                           Device: PD 1
TimeStamp: Dec 5, 2021 19:23:37        DefaultId: 0x000D000F
SpecData: 8ABC04CB0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32917                           Device: PD 1
TimeStamp: Dec 5, 2021 19:23:38        DefaultId: 0x000D000F
SpecData: 8ABC04CC0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32918                           Device: PD 1
TimeStamp: Dec 5, 2021 19:23:39        DefaultId: 0x000D000F
SpecData: 8ABC04CD0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32919                           Device: PD 1
TimeStamp: Dec 5, 2021 19:23:41        DefaultId: 0x000D000F
SpecData: 8ABC04CE0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32920                           Device: PD 1
TimeStamp: Dec 5, 2021 19:23:42        DefaultId: 0x000D000F
SpecData: 8ABC04CF0000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32921                           Device: PD 1
TimeStamp: Dec 5, 2021 19:23:47        DefaultId: 0x000D000F
SpecData: 8ABC04D00000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32922                           Device: PD 1
TimeStamp: Dec 5, 2021 19:23:52        DefaultId: 0x000D000F
SpecData: 8ABC04D10000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32923                           Device: PD 1
TimeStamp: Dec 5, 2021 19:23:53        DefaultId: 0x000D000F
SpecData: 8ABC04D20000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32924                           Device: PD 1
TimeStamp: Dec 5, 2021 19:23:55        DefaultId: 0x000D000F
SpecData: 8ABC04D30000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32925                           Device: PD 1
TimeStamp: Dec 5, 2021 19:23:56        DefaultId: 0x000D000F
SpecData: 8ABC04D40000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32926                           Device: PD 1
TimeStamp: Dec 5, 2021 19:23:57        DefaultId: 0x000D000F
SpecData: 8ABC04D50000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32927                           Device: PD 1
TimeStamp: Dec 5, 2021 19:24:00        DefaultId: 0x000D000F
SpecData: 8ABC04D60000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32928                           Device: PD 1
TimeStamp: Dec 5, 2021 19:24:01        DefaultId: 0x000D000F
SpecData: 8ABC04D70000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32929                           Device: PD 1
TimeStamp: Dec 5, 2021 19:24:10        DefaultId: 0x000D000F
SpecData: 8ABC5A800000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32930                           Device: PD 1
TimeStamp: Dec 5, 2021 19:24:15        DefaultId: 0x000D000F
SpecData: 8ABC5A810000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32931                           Device: PD 1
TimeStamp: Dec 5, 2021 19:24:16        DefaultId: 0x000D000F
SpecData: 8ABC5A820000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32932                           Device: PD 1
TimeStamp: Dec 5, 2021 19:24:18        DefaultId: 0x000D000F
SpecData: 8ABC5A830000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32933                           Device: PD 1
TimeStamp: Dec 5, 2021 19:24:19        DefaultId: 0x000D000F
SpecData: 8ABC5A840000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32934                           Device: PD 1
TimeStamp: Dec 5, 2021 19:24:20        DefaultId: 0x000D000F
SpecData: 8ABC5A850000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32935                           Device: PD 1
TimeStamp: Dec 5, 2021 19:24:21        DefaultId: 0x000D000F
SpecData: 8ABC5A860000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32936                           Device: PD 1
TimeStamp: Dec 5, 2021 19:24:23        DefaultId: 0x000D000F
SpecData: 8ABC5A870000000000 0000012020202020 2020202020203734 3756535A4B4B53
SeqNo: 32937                           Device: LD 0
EventId: 0x00090002                    Severity: Info
TimeStamp: Dec 5, 2021 21:45:41        DefaultId: 0x00090002
SpecData: 000000000000000000 0000000000000000 0000000000000022 C3000155193966
Description: Logical drive has been placed online
SeqNo: 32938                           Device: PD 4
EventId: 0x000D0000                    Severity: Info
TimeStamp: Dec 5, 2021 21:45:41        DefaultId: 0x000D0000
SpecData: 000000000000000000 0000012020202020 2020202020205A30 45534748594153
Description: Physical Disk is marked online
SeqNo: 32939                           Device: Ctrl 1
EventId: 0x00040006                    Severity: Info
TimeStamp: Dec 5, 2021 23:21:59        DefaultId: 0x00040006
SpecData: 000000000000000000 0000000000000000 0000000000000000 00000000000000
Description: The system is stopped by unknown reason
SeqNo: 32940                           Device: Ctrl 1
EventId: 0x00040005                    Severity: Info
TimeStamp: Dec 6, 2021 04:19:43        DefaultId: 0x00040005
Description: The system is started
SeqNo: 32941                           Device: Ctrl 1
TimeStamp: Dec 6, 2021 04:20:11        DefaultId: 0x00040006
SeqNo: 32942                           Device: Ctrl 1
TimeStamp: Dec 6, 2021 11:18:52        DefaultId: 0x00040005
SeqNo: 32943                           Device: Ctrl 1
EventId: 0x001F0000                    Severity: Info
TimeStamp: Dec 6, 2021 17:19:18        DefaultId: 0x001F0000
Description: Firmware update has started
SeqNo: 32944                           Device: Ctrl 1
TimeStamp: Dec 6, 2021 17:26:28        DefaultId: 0x00040006
SeqNo: 32945                           Device: Ctrl 1
TimeStamp: Dec 6, 2021 17:27:59        DefaultId: 0x00040005
SeqNo: 32946                           Device: Ctrl 1
TimeStamp: Dec 6, 2021 18:04:46        DefaultId: 0x00040006
SpecData: 020000000000000000 0000000000000000 0000000000000000 00000000000000
Description: The system is stopped by host restart
SeqNo: 32947                           Device: Ctrl 1
TimeStamp: Dec 6, 2021 18:07:16        DefaultId: 0x00040005
SeqNo: 32948                           Device: Ctrl 1
TimeStamp: Dec 6, 2021 18:07:16        DefaultId: 0x00040006
SpecData: 110000000000000000 0000000000000000 0000000000000000 00000000000000
Description: The system is stopped by host unplug
SeqNo: 32949                           Device: Ctrl 1
SeqNo: 32950                           Device: Ctrl 1
TimeStamp: Dec 6, 2021 18:11:05        DefaultId: 0x00040006
SeqNo: 32951                           Device: Ctrl 1
TimeStamp: Dec 6, 2021 18:11:03        DefaultId: 0x00040005
SeqNo: 32952                           Device: Ctrl 1
TimeStamp: Dec 6, 2021 18:15:52        DefaultId: 0x00040006
SeqNo: 32953                           Device: Ctrl 1
TimeStamp: Dec 6, 2021 18:16:01        DefaultId: 0x00040005
SeqNo: 32954                           Device: Ctrl 1
TimeStamp: Dec 6, 2021 18:39:39        DefaultId: 0x00040006
SeqNo: 32955                           Device: Ctrl 1
TimeStamp: Dec 6, 2021 18:39:57        DefaultId: 0x00040005
SeqNo: 32956                           Device: Ctrl 1
TimeStamp: Dec 6, 2021 18:40:48        DefaultId: 0x00040006
SeqNo: 32957                           Device: Ctrl 1
TimeStamp: Dec 6, 2021 18:41:06        DefaultId: 0x00040005
SeqNo: 32958                           Device: Ctrl 1
TimeStamp: Dec 6, 2021 18:47:45        DefaultId: 0x00040006
SeqNo: 32959                           Device: Ctrl 1
TimeStamp: Dec 6, 2021 18:48:37        DefaultId: 0x00040005
SeqNo: 32960                           Device: Ctrl 1
TimeStamp: Dec 6, 2021 18:52:34        DefaultId: 0x00040006
SeqNo: 32961                           Device: Ctrl 1
TimeStamp: Dec 6, 2021 18:53:05        DefaultId: 0x00040005
SeqNo: 32962                           Device: Ctrl 1
TimeStamp: Dec 6, 2021 19:10:09        DefaultId: 0x00040006
SpecData: 160000000000000000 0000000000000000 0000000000000000 00000000000000
Description: The system is stopped by Power button
SeqNo: 32963                           Device: Ctrl 1
TimeStamp: Dec 6, 2021 19:12:50        DefaultId: 0x00040005
top
[Host Info]
OS Name: Darwin 21.1.0 x86_64
Host Name: BressersPro4219.fritz.box
Network Name: en1
IP Address: 192.168.178.20
Network Name: lo0
IP Address: 127.0.0.1
top
[HBA Driver Info]
Host driver version: 6.2.13
top
