Pegasus 1 R4 to work with Macbook Pro 2017?
  • 923 Views
  • Last Post 24 July 2017
Greg Joyce posted this 24 July 2017
Does anyone know if the legacy Pegasus (1) R4 will work on the new Macbook Pro 2017? If so, what adapter/dongle is required?
Venkatachalam Settu posted this 24 July 2017
Hi Greg,
You need use Thunderbolt3 to Thunderbolt 1/2 adaptor in order to connect the Pegasus R4 unit. Please refer the below mentioned forum link:
https://forum.promise.com/thread/peg3-r6-for-imac-27-tb1-and-sierra-anything-i-need-to-know-before-buying/
Thank you for that answer, Venkatachalam -- I'm glad to hear it!
Do I need to update the firmware on the Pegasus R4 unit or should I try it first with the adapter to see if it will work?
