Pegagus2 R4 with USB-3 or USB-C via d-adapter ?
  • 624 Views
  • Last Post 10 October 2025
Pierre-Alain Dorange posted this 09 October 2025
Got a Pegasus 2 R4 that works fine, but has we change our server (MacOS to Synology NAS) we will not have any thunderbold (TB2) available, only USB-3.2.
Pegasus has been tested through an adaptator TB2 <> USB-C ?
Apple claim it adapter is both way :
https://www.apple.com/fr/shop/product/MYH93ZM/A/adaptateur-thunderbolt-3-usb-c-vers-thunderbolt-2
This has been discussed in 2017, the situation has change ?
R P posted this 10 October 2025
Hi Pierre-Alain,
What i can understand is that there is no way to use Pegusus 2 R4 (TB2 device) with a Synology NAS that has only an USB 3.2 connectivity.
That was answered first.
  • The Pegasus 2 is a Thunderbolt 2 device, it is not a USB device and will not work on a USB port.
The Pegasus 2 will not work if conncted to a USB 3.2 only port.
And even if the Synology did have Thunderbolt port, it would still not work because a device driver is required. The Synology is a RAID appliance and there is no way to load the Pegasus device driver.
Pierre-Alain Dorange posted this 10 October 2025
@ RP :
Thanks for the information.
But i'm still a bit confused.
R P posted this 09 October 2025
Hi Pierre-Alain,
The Apple adapter is a TB2 to TB3 adapter, it is not a Thunderbolt to USB3.x adapter. It will not allow the Pegasus to connect to a USB port.
The Apple adapter does convert both ways, you can also use it to attach a Thunderbolt 3 device to a Thunderbolt 2 port, but while backwards compatibility is a thing, forward compatibilty is not, so attaching a Thunderbolt 3 device to a High Sierra Mac probably won't work because the High Sierra drivers don't support newer chipsets and thunderbolt protocols.
The confusion here is because both USB 3.x and Thunderbolt 3+ use the USB-C connector. The protocols are different generally not compatible. But the Thunderbolt 4 spec calls for USB 4.x support, so a Thunderbolt 4 port should also work with USB devices. This is not true for USB 4 however. The USB 4.0 spec allowes for Thunderbolt 3 support, but it is not requires and few USB4 ports support Thunderbolt 3. In order to use the Thunderbolt lightening symbol a device needs to pass Thunderbolt certification, this is expensive and few USB 4 devices do this. Oddly, many Thunderbolt docks don't go through certification, you can tell because they do not have the thunderbolt lightening symbol at the ports and the documentation does not use the word Thunderbolt. These docks may work conneting to the Mac, but devices attached to the dock may or may not work.
Interestingly, Thunderbolt has not yet invented it's own connector. Even Thunderbolt 1 and 2 used the mini displayport connector. If you search for a thunderbolt 2 cable on Amazon you'll see a lot of mini displayport cables. I do not know if you can use a mini displayport cable for Thunderbolt 1 and 2. The Thunderbolt 3 cables are higher bandwidth than the USB 3.x cables and they will not work to connect a thunderbolt device. But you can use a thunderbolt 3 cable to connect any USB device because they are higher bandwidth and quality. Thunderbolt cables also need to be certified to use the Thunderbolt logo.
