PCI Thunderbolt Card that works with pegasus series
  • 757 Views
  • Last Post 22 August 2017
Clement Batifoulier posted this 21 August 2017
I know there is no PCI card listed in your pdf compatibilty list (it's quite minimum..)
I am using a Asus MB (X99 deluxe2/3.1) and Asus PCI thunderbolt EX 3 is recommanded for thunderbolt 3 connecting....
I wonder if someone used a ASUS thunderbolt EX in the past to connect to a Pegasus DAS ?
Cheers! :)
Devendra Kumar posted this 21 August 2017
HI Clement,
Since Promise have not been tested with these type PCI hence it may work or may not. We always recommend to go compatiblity list.
Clement Batifoulier posted this 22 August 2017
I am very surprise that you didn't test it. Asus is one of the main motherboard brand, specialy if you build your own working station.
This card is recommanded with all their expensive and working station MB more than 10/15. So if you test it you can had 10/15 MB to your list with this PCI cards...
If I were you I would have test it. So few "compatility list" items... it is the same with other brand, this is so frustating...
Don't you have money to test things ? :)
