Not mounting EXFat Drive, Ventura Macos X MacBook Pro M1 Pro
  • 518 Views
  • Last Post 17 November 2022
Jens Kilian posted this 17 November 2022
Hello, my pegasus 32 R4 is not mounting I have not changed anything except updated mac os X, I just updated the new mac os x driver. Everything on the System Status App is green light, works fine. no error.
Activation of "pegasus map" failed. (com.apple.DiskManagement.disenter-Fehler 49244.)
What to do?
Babatunde Akinkuolie posted this 17 November 2022
Please use the driver below and try again
https://www.promise.com/DownloadFile.aspx?DownloadFileUID=6963
if the issue arises, Kindly register the unit using the serial number by logging into support.promise.com and open a web support ticket with the service report of the unit attached so we could check further.
1) Open Promise Utility.
