how can I reduce the fan nosie on my M4?
Its maybe possible to change the fan? Anybody have a recommendation which fan can be used?
The fan is too noisy and can only be replaced. Someone has tried this. If the manufacturer can use noiseless fans, the product will be even more perfect.
Hi Tudor,
We need to anaylze the subsystem report in order to verifify the reason the behind noise in the unit. Please go to support.promise.com and attach the report after creating support ticket.
