No volume found on DS4600
  • 503 Views
  • Last Post 01 June 2017
Daniel Eisinger posted this 01 June 2017
We are trying to recover archived content on an old SmartStor DS4600.  When I first powered it up, it beeped indicating one of the drives had failed.  I attached the DS4600 to my computer and opened the device in SmartNavi, which indicated the RAID5 array was critical.  Under Volume Configuration no volume was listed, which I assumed was a result of the array being in a critical state.  I purchased a new drive, and when I inserted it, SmartNavi indicated the array was being rebuit.  It completed a few hours later, but it still says Volume Not Found.  How do I find/recover the volume on this array?
Hariprasad Velmurugan posted this 01 June 2017
Hi Daniel,
It seems that file system could be corrupted. After rebuilding completed in critical mode then volume should mount, If volume failed to mount then DS4600 file system is corrupted probably you try verify the drive in MAC disk utility. If stillt he same then you will need to contact third party recovery company to recover the data.
Hari
