Meaning of many "the system has stopped" and "the system has started" in promiseutil
  • 73 Views
  • Last Post 2 weeks ago
Ard Jonker posted this 3 weeks ago
Issuing "event -l nvram" in promiseutil (on the old but reliable work horse combination mac mini running mac os 10.10.5, mac mini, Promise2), yields thousands of these lines:
16355 Ctrl 1          Info     Aug 26, 2021 06:46:33 The system is stopped
16356 Ctrl 1          Info     Aug 26, 2021 06:46:42 The system is started
16357 Ctrl 1          Info     Aug 26, 2021 06:48:14 The system is stopped
16358 Ctrl 1          Info     Aug 26, 2021 06:48:22 The system is started
What is the meaning of "The system", these messages, and should I worry?
I came to ask because the unit is said to produce strange sounds occasionally and then blinks a red power button. No other strange or alarming log entries were found however and operation seems normal from a user perspective; all status icons in the GUI Promise Utitlity are green.
The unit is placed in a remote location and only recently the exact physical behaviour became apparent. The unit turns off with the sound of a disk arm that retracts, then in one or two seconds turns back on with a red power button and blue thunderbolt LED. Within moments, the unit is back online, indicated by the blue power button. This pattern repeats about every other minute. No errors are shown in the Promise Utility.
Raghuraman Kannan posted this 2 weeks ago
Hi Ard,
It could happen because of loose Thunderbolt connection. Kindly verify the connectivity by changing the Cable/Port in Pegasus and in the MAC.
If the problem still persits,  Please open a case at https://support.promise.com/ with the Service Report.
1) Open Promise Utility.
4) Click on save service report button to save the subsystem report and attach it to the case
