Manual Rebuild Question on Pegasus 2 R6
  • 364 Views
  • Last Post 24 September 2018
Christopher Siwinski posted this 22 September 2018
I am using a Pegasus 2 R6 with 6 - Toshiba DT01ACA300 3TB drives; 18TB in all. One of my drives started to log a "Command Time Out" minor error and the system kept resetting the drive. I also experienced issues with copying files as I was getting system errors. So my first thought was to replace the drive before it failed. Was this the right thing to do?
So I hot-swapped the drive with the error with a new drive of the same model. The device power button turned red when I took out the bad drive and when I replaced it with the new drive the button turned orange. I then went to the Promise Utility and under Background Activities started a Rebuild on the new drive. It has been sitting at "0% Running" for an hour. Is this normal? How long does a manual rebuild take? BTW... all external drive lights are solid blue.
Venkatachalam Settu posted this 22 September 2018
What is the RAID level configured on the system & What is the status?
Christopher Siwinski posted this 23 September 2018
Raid 5; Critical.
Venkatachalam Settu posted this 23 September 2018
Hi Christopher,
It looks like another drive is started developing the error and it will not allow new drive to complete the rebuild process.Kindly stop the rebuild process and take a backup of your data as soon as possible from the volume.The dual drive failure may cause the data inaccessible on RAID 5 setup.
I tried to stop the Rebuild twice and I got the messages in this order:
  • Failed to stop rebuild: <something.... something..> system error.
  • Failed to stop rebuild: another rebuild command is pending.
Can you try to pause the rebuild process?
I tried to Pause the Rebuild and it was unsuccessful.
  • Failed to pause rebuild: another rebuild command is pending.
Do I turn off the device manually?
This is exactly why I switched from NetGear ReadyNAS to Pegasus. It seems whenever I move large volumes of data around this issue occurs. I barely us the device and then when I do JINX!
I did a hard reboot and severity is Major now. I am going to try to backup my files to another external HD.
Christopher Siwinski posted this 24 September 2018
Quick update. I was able to backup all data to two 4TB external HDs. I was then able to format the new HD to replace the damaged one. I decided to reformat the entire array to a 15TB Logical Drive with a 3TB spare. So the rebuild process worked and everything is back online. There does not seem to be an issue with the hardware or the other drives.
