macOS Big Sur - Volume Mounting Workaround
  • 150 Views
  • Last Post 4 days ago
Robert Bousfield posted this 3 weeks ago
As a temporary workaround (until Promise release an updated installer or Apple fixes the KEXT loading) Promise RAID volumes can be mounted at startup by using a manually created LaunchDaemon.
I had already installed the Promise Driver in a previous beta release so the required PromiseSTEX.kext  was already in place. You may need to do this.
I have tested the this on my Mac Pro with a Pegasus2 R4.
  • Text below entered into plain text editor (I used BBEdit)
  • Saved in /Library/LaunchDaemons with file name: com.promiseload.loader.plist (permissions set to 644)
  • Shut down Mac Pro.
  • Restarted Mac Pro
  • Expected RAID volumes mount when user logs on.
  • Tested with System Integrity Protection on and off.
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
<plist version="1.0">
<dict>
    <key>EnvironmentVariables</key>
    <dict>
        <key>PATH</key>
        <string>/usr/local/bin:/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/sbin</string>
    </dict>
    <key>Label</key>
    <string>com.promiseload.loader</string>
    <key>ProgramArguments</key>
    <array>
        <string>/sbin/kextload</string>
        <string>/System/Library/Extensions/PromiseSTEX.kext</string>
    </array>
    <key>RunAtLoad</key>
    <true/>
</dict>
</plist>
Hope this is useful for those helping to test the latest macOS release.
Rick Squires posted this 3 weeks ago
This is very helpful.  The alternative approach of running the Installer and force quitting it when its done works, but is a bit of a pain
Hopefully Apple will get their act together in some later version of the Big Sur beta
Thanks a gain
  • Restarted Mac Pro
<dict>
    <dict>
        <key>PATH</key>
    </dict>
    <key>Label</key>
    <array>
    </array>
    <true/>
</dict>
</plist>
I've tried this- put the plist in both /Library and /User/Library LaunchDaemons folders.  Doesnt work.  My workround is to put the installer into my Login Items llist and run it every time I log on. Then Force Quit the Installer. Takes a minute, but it is messy.  I'm using a Pegasus 3 R4, so maybe thats why it's not working..  I was disappointed as Beta 9 was supposed to fix this.  Having said that, I've run the Blackmagic speed tests and got essentially the same speeds I get under Mojave(I've not really opened the Catalina can of worms yet)
Hi Rick,
Can I ask - is the PromiseSTEX.kext located in your /System/Library/Extensions folder?
Or is is in /Library/Extensions?
You may need to edit the script to point to the correct location on this line:
I upgraded over a Catlina 10.5.7 install prior to testing this and the required KEXT on my machine was in the /System/Library area.
Looking at the installer for your device it looks like it puts the file in /Library/Extensions.
It looks like the same driver as for the R2 so I installed it, sure enough it puts files in /Library/Extensions
I modified the script and made sure the permissions were set as follows using a freeware app called batchmod:
Restarted and the RAID volumes mounted.
I would suggest the plist file does need to be in /Library/LaunchDaemons, not at the user account level.
Rob
Pieter Pretorius posted this 3 weeks ago
This also doesn't work for my Promise Pegasus 3 R6.
The PromiseSTEX.kext file is actually in both locations I see.
Pieter.
Leo Kuhn posted this 2 weeks ago
I have MacPro 2013 and a Pegasus2 R8.
After booting BigSur, the R8 does not appear.
But if I move the PromiseSTEX.kext to the desktop, and a few seconds later to the extensions folder, the volume appears.
Unfortunately my main user folder is on the R8, so that is not a usable solution.
Robert Bousfield posted this 4 days ago
Since upgrading to Big Sur Beta 10 (20A5395g ) I think the Promise drivers are now being loaded as expected, i.e. without any workaround.
I have disabled my custom LaunchDaemon and restarted several times with the drives mounting as expected.
Can someone else verify this?
