Keep power on without laptop connected
  • 758 Views
  • Last Post 20 October 2017
Yves Hsu posted this 19 October 2017
Hi all,
I am using Pagesus 3 as my backup storage.
So it will not always on all the time. Is it possible to keep Pegasus3 on without connecting to a laptop/PC?
I want my Pegasus3 to finish synchronization ASAP without my laptop since I need it during day time.
Hariprasad Velmurugan posted this 19 October 2017
Hi yves,
Its not possible to power on the unit with out connecting Mac or PC, When you disconnect the thunderbolt cable pegasus 3 it will  shutdown automatically and disconnect  So its mandatory to keep host pc to connected
Hari
Yves Hsu posted this 20 October 2017
Hi Hari,
If the behavior is defined like normal USB storage drive, why do I need to manually power off after safe remove storage device?
Is it safe to unplug cable directly after safe remove storage device on Windows? Or I have to manually power off before unplug?
