How to shutdown Pegasus3 without utility & shutdown PC
  • 823 Views
  • Last Post 21 October 2017
Yves Hsu posted this 19 October 2017
Hi all,
I am using Pegasus3 R8 on Macbook Pro running Windows 10.
In the user manual, it says I should press the power button to shutdown Pegasus3 after safe removed the USB storage device.
When I safe remove USB storage device on Win10 and unplug the USB-C cable, the Pegasus3 device will also shotdown. Is it safe to do it so?
Is it necessary to press power button for shutdown? Or direct unplug it is safe?
Karthik K posted this 20 October 2017
Hi Yves,
It's not safe to directly unplug and it is not necessary to press power button for shutdown if the Pegasus is getting shutdown after clicking on safe remove USB storage device.
karthik
Yves Hsu posted this 21 October 2017
Hi Karthik,
The Pegasus is getting shutdown after "clicking on safe remove USB storage device " & "unplug the USB-C cable".
Do you mean it is safe using above way?
