how to connect Vtrak D5320fxd + J5320xd + J5960sD
  • 1K Views
  • Last Post 28 August 2025
Mike Ross posted this 27 August 2025
Hi team
Can you tell me if I can connect these devices at the same time: Vtrak D5320fxD + J5320sD + J5960sD
(Because I am in need of building a storage system including: SSD SAS 43TB; HDD SAS 10K 30TB; HDD SAS 7.2K 440TB, all are configured raid 6)
Many thanks
R P posted this 27 August 2025
The D5000 product manual shows how to connect JBODs.
From page 38.
Note, on the D5320 you connect to SAS port 2 on the right.
Mike Ross posted this 28 August 2025
So can I connect the JBODs at the same time the VTRAK J5320 and VTRAK J5960?
R P posted this 28 August 2025
This did not translate well, I do not understand the question.
You can connect the JBODs to the D5320, but the proper way is to daisy chain them as in the illustration. Do not connect both JBODs directly to the D5320. It does not matter which JBOD you connect to the D5320, the second JBOD needs to be connected to the first as shown above.
