How to connect Pegasus2 R4 to 2009 Mac Pro Tower
  • 81 Views
  • Last Post 17 October 2018
David Williams posted this 15 October 2018
I have inherited a Pegasus2 R4 and am wanting to connect to my old Mac Pro Tower (circa 2009). Are you able to tell me what cable/adaptor I need to be able to connect directly to the rear? Preferably an Apple branded cable as opposed to a Generic one. If you can provide the product code that would be awesome. Any other information and assistance would be great too.
Many thanks in advance
David
Ranjith kumar posted this 17 October 2018
Hi David,
No.There is no way to connect Pegasus2 R4 with Mac Pro which does not have Thunderbolt port.
Ranjith
David Williams posted this 16 October 2018
Hello Ranjith,
I have no idea what that list means!
My Mac Pro Tower (circa 2009) does not have Thunderbolt connection ports. If it did, there would've been no need for me to ask the question.
Is there anyway to connect the Pegasus2 R4 to an older Mac Pro Tower with no Thunderbolt (2 or 3) ports, is my question?
David
Ranjith kumar posted this 16 October 2018
Hi David,
Pegasus2 R4 can be connect with the Mac which has Thunderbolt2 port using Thunderbolt2 cable.Kindly
use below link to download the compatibility list for Pegasus2 R4:
https://www.promise.com/DownloadFile.aspx?DownloadFileUID=4965
Ranjith
