Hitachi HUA723020ALA640, the same as Hitachi HUA723020ALA641?
  • 433 Views
  • Last Post 07 January 2019
Mick Ruane posted this 04 January 2019
Hi
I have a Pegasus R4 and one of the drives (Hitachi HUA723020ALA641) has gone down.
I can get a good deal on a Hitachi HUA723020ALA640 drive but dont know if it will work with my current set up.
Basically is there any differecne between the Hitachi HUA723020ALA641 and the Hitachi HUA723020ALA640? Note I would only be changing one drive so would be mixing 3 Hitachi HUA723020ALA641 and one new Hitachi HUA723020ALA640.
Thanks in advance
Mick
Mick Ruane posted this 07 January 2019
Hi Mick,
Both the drive models you have provided have similar specifications . You can use any hard drive as long as they have same Capacity, Buffer Size and RPM.
Having different model hard drives of same capacity will not cause any issue .
Thanks for that.  Appreciated
Raghuraman Kannan posted this 07 January 2019
Hi Mick,
