First Aid was first tried, and repeted a few times, spare I did deleted before running promiseutil commands ... now I just added it back and run again same commands:
cliib> phydrv
PdId Model Type Capacity Location OpStatus ConfigStatus
1 TOSHIBA DT01 SATA HDD 3TB Encl1 Slot1 OK Revert Global Sp
2 TOSHIBA DT01 SATA HDD 3TB Encl1 Slot2 OK Array0 No.0
3 TOSHIBA DT01 SATA HDD 3TB Encl1 Slot3 OK Array0 No.1
4 TOSHIBA DT01 SATA HDD 3TB Encl1 Slot4 OK Array0 No.2
5 TOSHIBA DT01 SATA HDD 3TB Encl1 Slot5 OK Array0 No.3
6 TOSHIBA DT01 SATA HDD 3TB Encl1 Slot6 OK Array0 No.4
7 TOSHIBA DT01 SATA HDD 3TB Encl1 Slot7 OK Array0 No.5
8 TOSHIBA DT01 SATA HDD 3TB Encl1 Slot8 OK Array0 No.6
cliib> array -v
DaId: 0
OperationalStatus: OK
Alias: OLD_P2
PhysicalCapacity: 21TB ConfigurableCapacity: 21TB
FreeCapacity: 0Byte MaxContiguousCapacity: 0Byte
AvailableRAIDLevels: 0 5 6 50 1E
PDM: Enabled MediaPatrol: Enabled
NumberOfPhysicalDrives: 7 NumberOfLogicalDrives: 1
NumberOfDedicatedSpares: 0
UserSetPowerSavingLevel: 0 CurrentPowerSavingLevel: 0
PowerManagement: Enabled
Physical Drives in the Array:
0 2 3TB 3.09MB OK
1 3 3TB 3.09MB OK
2 4 3TB 3.09MB OK
3 5 3TB 3.09MB OK
4 6 3TB 3.09MB OK
5 7 3TB 3.09MB OK
6 8 3TB 3.09MB OK
Logical Drives in the Array:
LdId Alias RAIDLevel Capacity OpStatus
0 OLD_P RAID0 21TB OK
Id OpStatus PdId CfgCapacity Revertible Type DedicatedToArray
0 OK 1 3TB Yes Global
cliib> logdrv -v
LdId: 0
ArrayId: 0 SYNCed: Yes
Alias: OLD_P TRIMSupport: Support TRIM
SerialNo: 0000000000000000000000002C0AEEFC362DB09B
WWN: 2287-0001-55e1-8a28 PreferredCtrlId: N/A
RAIDLevel: RAID0 StripeSize: 1MB
Capacity: 21TB PhysicalCapacity: 21TB
ReadPolicy: ReadCache WritePolicy: WriteBack
CurrentWritePolicy: WriteBack
NumOfUsedPD: 7 NumOfAxles: 1
SectorSize: 512Bytes RAID5&6Algorithm: N/A
TolerableNumOfDeadDrivesPerAxle: 0 ParityPace: N/A
CodecScheme: N/A
Thanks for info and help
