Help Primise Pegasus R4 Red Led
  • 454 Views
  • Last Post 13 October 2016
juan carlos posted this 12 October 2016
Hello good day, first of all, I feel for my poor English!
The problem I have is an error that I solved following these commands,
https://eclecticlight.co/2015/01/21/qa-broken-promise/
I have followed all the steps, but I'm still with the problem
https://s21.postimg.org/golzvn4sn/14689038_692821417541063_252642849_o_1.jpg
When you run the commands, send this error
(0x401) error: invalid command or request
 have updated the firmware of the application Promise Utility but still still giving thesame problem, helps, hope that someone I can help with this problem since I havemuch information in my Promise Pegasus R4
Pradeep Chidambaranath posted this 13 October 2016
Hi Juan,
We don't recommend to force online the drives without consulting Promise Technical support as it might lead to data corruption if the drives are having errors. We need to analyse the subsystem report to find the exact problem.
Steps to save the report .
- Open Promise Utility.
- Click the lock symbol on the left bottom corner of the screen to unlock the utility.
Once the report is saved , register yourself as a user at support.promise.com and register your product.
Open a web support case and attach the subsystem report for our review.
We will check the logs and will guide you on how to proceed further.
