Firmware Flashing stuck
  • 170 Views
  • Last Post 2 weeks ago
Robert Lawrence posted this 13 July 2022
Pegasus3 R4 firmware flashing after Operating Utility Update is now stuck on the following: Firmware Flashing Please wait. Firmware update is in progress... Neither of the two buttons is working (grayed out, cancel, ok). Afarid to reboot the system. Please advise. Running Mac OS Monterey v 12.4. Promise Utility V 4.06.0000.04 (C04).
Also, the drive is still connected and I can access the data. But the utility is in the state described above.
Raoul Schaffner posted this 2 weeks ago
I have the same situation, well, nearly:
macOS 12.6.1, Promise Utility 4.06.0000.04
Firmware Update is stuck at "Please wait. Firmware update is in progress..." for 20 minutes now.
Any advice?
  • Robert Lawrence
Babatunde Akinkuolie posted this 2 weeks ago
 Kindly use the following utility to flash the firmware update again
https://www.promise.com/DownloadFile.aspx?DownloadFileUID=4619
If the issue still arises, kindly register the unit using the serial number by logging into support.promise.com and open a web support ticket with the service report of the unit attached so we could check further.
1) Open Promise Utility.
Robert Lawrence posted this 2 weeks ago
Raoul Schaffner:
I bravely (stupidly) rebooted after about 1hr. Largely took this step because I had a backup for the drive. It rebooted with the updated firmware in place.
Not sure why it was "stuck" but regardless, this worked for me. Obviously not a great situation that caused some heartburn.
