Fan always on even while asleep?
  • 1.1K Views
  • Last Post 05 January 2021
James Culbertson posted this 01 May 2019
Is it normal for my new Pegasus3 R6 24TB to always have its fan on even after being asleep overnight? The fan is on pretty low, but I don't recall either of my Pegasus2 R4 8TB drives ever having their fan on after being asleep awhile.
  • Carl Metzler
  • Stuart Bedford
Stuart Bedford posted this 05 January 2021
I am having the same issues here, is there a fix?
Also my units fans spin up to 3500 rpm while doing nothing.  Has anyone else had this?
Pete Dillon posted this 14 November 2020
My new Pegasus 32 R4 does the same thing. Fan runs forever, even when the unit is off and the connected Mac is shut down. The old Pegasus 2 turns off as you'd expect.
Very dissapointing.
John Evans posted this 22 September 2020
Sleep mode still uses power to maintain it's state and be able to quickly respond to waking up. The fan is likely needed to keep the components at the right operating temperature. If it's too noisy you can try cleaning out the computer. Dust build up causes increased heat which triggers the fan switch. If it's always been noisy, you can probably replace the fan to a quieter one or, as stated above, start using hibernate.
Kevin Hale posted this 22 August 2020
Same.  I  upgraded from a Pegasus3 R4 to a Pagasus32 R4.  The Pegasus3 was always silent and off for sleep or shutdown, but that's not the case for this new Pegsus32.  I created a ticket for it and after numous exchanges they informed me that the big fan should turn off, but there's a smaller fan that is always running all the time.  I beleive if you shut it down/sleep via your computer, this is the case, but if you physically turn it off by pushing the button, THEN the fan turns off.
  • Stuart Bedford
Unto Mattila posted this 05 May 2019
I have same problem. Before it works right, went to sleep with iMac, but not any more?
  • Stuart Bedford
