EX8350 rebuilding stuck at 1%
  • 694 Views
  • Last Post 24 November 2018
Hung Pham posted this 24 November 2018
I have a raid10 with 6 disks. There are 3 disks failed. So I replaced the first disk, ran rebuild. It’s finished within 2 hours.
The next disk is in now, and the rebuilding stuck at 1% for 12 hours now. From event log in cli command, I saw repeating task 30 timeout error.
what should I do now? The light on the disk is keeping blinking, so I am not sure what’s going on there.
Please advice.
thanks.
Venkatachalam Settu posted this 24 November 2018
Hi Hung,
We have already replied and waiting for your response on the case. Please follow up the case.
Thank you,
Hi.
I have created a support case in support.promise.com. How long does it take to have an answer?
Hi Hung,
It looks like this issue needs to be analyzed with the help of the logs.You can call technical support at 408-228-1500 or reach out through support case at  https://support.promise.com/.
Thank you,
