Eject error with Pegasus2 and iMac Pro
  • 354 Views
  • Last Post 21 November 2018
Fergus Hammond posted this 12 February 2018
I recently got an iMac Pro. I've had a Pegasus2 for a while, connected to my old computer (a Mac Pro) and it's worked perfectly. However, with the new iMac Pro, it's not working as well.
The issue is that every time I wake the Mac from sleep, I see a bunch of errors on screen regarding the ejection of the array. Here's what it looks like:
https://imgur.com/a/ix7Iy (I've also attached the same file)
What is causing this and how can I solve the problem?
Bela Kiss posted this 21 November 2018
Hi Keith,
This issue was fixed back in May of 2018. The new driver (SR3.2, dated 2017/05/10) should fix the problem.
If the problem persists after an update it may be necessary to manually uninstall the old driver first. Let me know and I will provide instructions if needed.
FWIW, I see this eject error all the time on my Pegasys2 R4 running the latest FW version 5.04.0000.61 and haven't been able to find a fix for it, even by disabling "Put hard disks to sleep where possible". Contacting Promise support has proven unhelpful. I think that I'm ready to move on to other products that will hopefully prove less problematic.
PROMISE Technology Inc. posted this 08 October 2018
That's good news! Does that mean it should be possible to leave "Put hard disks to sleep where possible." turned on?
Yes, but be advised that when the MAC wakes for various houskeeping tasks it will wake any attached drives (USB, TB and even Firewire). If the computer is in or near a bedroom this could be a problem.
Also, does the latest version of the driver and utility support OS X 10.14?
As far as I know, this driver has not been tested with Mojave. It will probably work. I will see if I can find out more.
  • Fergus Hammond
Fergus Hammond posted this 08 October 2018
Hi Keith,
Turning off "Put hard disks to sleep where possible." seems to mostly get rid of this problem.
keith plechaty posted this 08 October 2018
Was any solution found for this Eject error? I am getting the same error on my macbook pro.
H Kees posted this 17 February 2018
Fergus Hammond posted this 14 February 2018
"By the way, you CAN check compatibility of accessories with iMacs and MacPro - they are listed (Compatibility > more)."
Where do you see the "More" option? Here's when I see when, for example, I do a search for LaCie:
https://imgur.com/a/5G5O4
H Kees posted this 14 February 2018
Apple pays painstaking attention to its website and mistakes are rare. By the way, you CAN check compatibility of accessories with iMacs and MacPro - they are listed (Compatibility > more). There's around 35 storage devices that are shown when you select iMac or MacPro. When selecting iMac Pro no Promise or G-Technology devices are shown.
Furthermore... the iMac Pro is not on the Promise's official Mac compatibity list, and when asked about it, they give an evasive answer. I suspect Promise are still working on getting rid of technical glitches before it can be called full compatible with iMacPro (a brand new computer!).
Enough reason for me to postpone and possibly cancel my buying decision for an iMac Pro.
Fergus Hammond posted this 13 February 2018
I agree with Richard. The idea that Apple's made a computer that can only connect to four storage items is silly. Also, it's not just the iMac Pro that's missing: it's all iMacs, the Mac mini and the Mac Pro. Those computers have been on the market for years. This is a web site problem, not a technology problem.
Richard Oettinger posted this 13 February 2018
Hi "H",
it is not "significant" at all - Apple has worked with Promise on Thunderbolt products since day one, and the Pegasus3 line is supported by macOS and the iMacPro.
The Promise compatibility list wil be updated soon, the Apple site takes a little longer...
H Kees posted this 13 February 2018
Please check the store under Mac - Storage. When selecting under Mac Compatibility - iMacPro, no storage devises are listed, except for Promise Sanlink3, Airport Time capsule 2, and two more items. It’s significant, I don’t think it’s an error. It leaves me wondering do I purchase a Peagasus3 or not, or even - do I buy an iMacPro or not?
"This cleary indicates that Apple does not recommend these drives for use with iMacPro."
I don't think so. I think this might be an Apple problem. If you do a search for any product on Apple's Web site - including Apple's own products - the Mac Compability pop-down menu only lists Mac Books - no iMacs, Mac Pros or Mac minis. I think Apple's site is broken.
H Kees posted this 12 February 2018
Apple does sell Pegasus on their website, however, when you filter by Mac Compatibility > iMacPro all storage devices disappear. This cleary indicates that Apple does not recommend these drives for use with iMacPro.
Is Promise still working on this? I’ve asked here on the forum if Pegasus + iMacPro are a happy marriage, and the reply was evasive - yes Pegasus can be used for video editing. Duh.
It's annoying that Promise hasn't updated their compatiblity list but I don't think that's a sign that the array isn't compatible with the iMac Pro. Apple sells the Pegasus3 (and 2) on their Web site and I don't think they'd do that if they weren't iMac Pro compatible.
The LaCie 6big and 12big seems closest to the Promise products. I've also been looking at NAS devices, which would attach via the 10 Gbps Ethernet port on the iMac Pro but they seem like more trouble (e.g., I would have to buy a 10 Gbps switch and they are expensive).
I’m still looking for an external drive that works with iMac Pro. The latter is not on the official Promise list of devices that work well with Pegasus drives.
