No matter what firmware I install via TFP the controller boots up then power cycle,   ex10_fw_multi_3_33_0000_00.img
PBL_ROM Ver 1.02.0000.00
Built 13:57:15, May  7 2007   Platform Setup completed +execs Load & Run:  PBLRAM + DHCP Disabled Ethernet MAC address: 00:01:55:10:02:7e IP: 10.0.0.2/255.0.0.0, Gateway: 0.0.0.0 Default server: 0.0.0.0, DNS server IP: 0.0.0.0   PBLRAM Ver 1.02.0000.03 Built 14:49:31, Aug 25 2009   == Executing boot script in 30.000 seconds - enter ^C to abort ==> 0.010 sec PBLRAM> execs Software modules check OK SDRAM Size: 0x20000000, OS Size: 0x0c000000 Flash size: 0x02000000, Flash blk size: 0x00020000, blk count: 0x00000100 Using base address 0x01008000 and length 0x001c3460 Loading software modules ....... Unhandled fault: imprecise external abort (0x406) at 0x3f800000 Internal error: : 406 [#1] Modules linked in: plog CPU: 0 PC is at sysinitmodule+0x91c/0x16f4 LR is at sysinitmodule+0x914/0x16f4 pc : [<400565f8>]    lr : [<400565f0>]    Not tainted sp : 4b74dee0  ip : 00000000  fp : 4b74dfa4 r10: 00000000  r9 : 00000000  r8 : 00000019 r7 : 00000017  r6 : 4cc59ce0  r5 : 00000004  r4 : 3f004000 r3 : 00000000  r2 : 00000000  r1 : ffffffd8  r0 : 00000000 Flags: nZcv  IRQs on  FIQs on  Mode SVC32  Segment user Control: 400397F  Table: 0A4EC018  DAC: 00000015 Process insmod (pid: 756, stack limit = 0x4b74c198) File handle MP is   4071c220 Unhandled fault: imprecise external abort (0x406) at 0x3f800000 Internal error: : 406 [#2] Modules linked in: plog CPU: 0 PC is at zlibinflatetreesfixed+0x48/0x1e0 LR is at 0x4b74d890 pc : [<40119ae8>]    lr : [<4b74d890>]    Not tainted sp : 4b74d388  ip : 0000002a  fp : 4b74d84c r10: 4b74d884  r9 : 4c851a40  r8 : 4b74d88c r7 : 4b74d888  r6 : 00000802  r5 : 00000006  r4 : 00000002 r3 : 4b74d8cc  r2 : 0000002a  r1 : 00000008  r0 : 4b74d890 Flags: Nzcv  IRQs on  FIQs on  Mode SVC32  Segment kernel Control: 400397F  Table: 0A4EC018  DAC: 00000035 Process insmod (pid: 756, stack limit = 0x4b74c198) File handle MP is   4bf4c440       PBLROM Ver 1.02.0000.00 Built 13:57:15, May  7 2007   Platform Setup completed +execs Load & Run:  PBLRAM + DHCP Disabled Ethernet MAC address: 00:01:55:10:02:7e IP: 10.0.0.2/255.0.0.0, Gateway: 0.0.0.0 Default server: 0.0.0.0, DNS server IP: 0.0.0.0   PBLRAM Ver 1.02.0000.04 Built 10:57:33, Mar 18 2009   == Executing boot script in 30.000 seconds - enter ^C to abort PBLRAM> execs Software modules check OK SDRAM Size: 0x20000000, OS Size: 0x0c000000 Flash size: 0x02000000, Flash blk size: 0x00020000, blk count: 0x00000100 Using base address 0x01008000 and length 0x001c3460 Loading software modules ....... Bad mode in data abort handler detected: mode ABT32 Internal error: Oops - bad mode: 0 [#1] Modules linked in: raidcore plog CPU: 0 PC is at 0xffff027c LR is at 0x36 pc : [<ffff027c>]    lr : [<00000036>]    Tainted: PF sp : 4ab39de4  ip : 00000000  fp : 4ab39e5c r10: 402ce780  r9 : 00000003  r8 : 00000020 r7 : 00000000  r6 : 48f258bc  r5 : 48f258a0  r4 : 00000000 r3 : 00001000  r2 : 00000003  r1 : 402ce780  r0 : 00000000 Flags: nZCv  IRQs off  FIQs on  Mode ABT32  Segment user Control: 400397F  Table: 0A548018  DAC: 00000015 Process insmod (pid: 756, stack limit = 0x4ab38198) Unhandled fault: imprecise external abort (0x406) at 0x68400000 Internal error: : 406 [#2] Modules linked in: raidcore plog CPU: 0 PC is at memcpyfromio+0x1c/0x28 LR is at simplemapcopyfrom+0x64/0x7c pc : [<4002af70>]    lr : [<4016fbe0>]    Tainted: PF sp : 4ab39858  ip : 4ab39868  fp : 4ab39864 r10: 00000000  r9 : 00223998  r8 : 405fd7d8 r7 : 40257500  r6 : 00000002  r5 : 48f36000  r4 : 40257500 r3 : 00000035  r2 : 00000000  r1 : 5122399a  r0 : 48f36001 Flags: nZCv  IRQs on  FIQs on  Mode SVC32  Segment kernel Control: 400397F  Table: 0A548018  DAC: 00000035 Process insmod (pid: 756, stack limit = 0x4ab38198) 05:07:20:08:27:14#THREAD INFO: MainScheduler - PID: 0x2f6 05:07:20:08:27:14# The CDB of MIC received before reboot/watchdog  is 05:07:20:08:27:14# 00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00 05:07:20:08:27:14#Last Power down was done by WatchDog timer reset... Bad mode in data abort handler detected: mode ABT32 Internal error: Oops - bad mode: 0 [#3] Modules linked in: raidcore plog CPU: 0 PC is at 0xffff0280 LR is at _vmallocnode+0x78/0x88 pc : [<ffff0280>]    lr : [<4006e748>]    Tainted: PF sp : 4a54de1c  ip : 4a54de9c  fp : 4a54de98 r10: 00000080  r9 : 402bae78  r8 : 000000d2 r7 : 48f25860  r6 : 000000ef  r5 : 000000d2  r4 : ffffffff r3 : ffffffff  r2 : 000000ef  r1 : 000000d2  r0 : 48f25860 Flags: nzCv  IRQs off  FIQs on  Mode ABT_32  Segment user Control: 400397F  Table: 0A508018  DAC: 00000015 Process syslogd (pid: 747, stack limit = 0x4a54c198)
