Does SANLink2 10GBase-T works with other 10Gbps switches
  • 500 Views
  • Last Post 24 March 2018
Baptiste Massey posted this 21 March 2018
I would like to know if SANLink2 10GBase-T works with all 10Gbps switches? Or is it strictly compatible with Ethernet Switches mentioned in the Compatibility List?
Thank you for your help!
Baptiste
Devendra Kumar posted this 24 March 2018
Hi Baptiste,
We have tested few Switches as of now which are listed in the compatibility list and  It doesn't mean the other Switches will not work however it is recommended to have the compatible switches for better performance.
Please find the below compatibility list
https://www.promise.com/DownloadFile.aspx?DownloadFileUID=4272
