Disk Error - HELP
  • 369 Views
  • Last Post 28 February 2021
Brian Krupp posted this 05 November 2020
I have an R4 (configured for RAID5) that has a red light and what appears to be a purple light for the top disk slot.  The lights just appeared today. I downloaded the utility and it shows there are errors.  When I click on physical drive list I see my list of drives but I can't click on them for further diagnostics per the user manual.  I'm assuming the drive is failing or has already failed but would like to confirm this.  Secondly, is there a problem with my utility since I can't view individual drives?
Drive is currently connected via thunderbolt cable to a 2013 Mac Pro running Catalina.
R P posted this 06 November 2020
Hi Brian,
We will need more information to determine the correct course of action. Please open a terminal, type 'promiseutil' to bring up the CLI and enter the following commands and post the output here.
array -v
phydrv
phydrv -v
event -l NVRAM
If this is a Pegasus 1 R4, then the disk may have gone bad, the event logs should show us this.
Also, the Pegasus 1 Promise Utility may not be fully compatible with Catalina, please uninstall the Promise Utility you installed (drag it from the Applications folder to the trashcan) and install the latest Promise Utility.
https://www.promise.com/DownloadFile.aspx?DownloadFileUID=6536
Brian Krupp posted this 06 November 2020
Thanks for the help.  This is a Pegasus2 R4.
After a good night's sleep I realized I wasn't using the utility properly.  Drive 1 is showing it's operational status as Dead.
Here's the results from the terminal commands:
Promise Utility
Version: 4.04.0000.42 Build Date: Aug 28, 2020
Type  #    Model         Alias                         WWN                 Seq
hba   1  * Pegasus2 R4                                 2000-0001-555b-4ebb  1
cliib> array -v
DaId: 0
OperationalStatus: Degraded
Alias:
PhysicalCapacity: 8TB                  ConfigurableCapacity: 8TB
FreeCapacity: 0Byte                    MaxContiguousCapacity: 0Byte
AvailableRAIDLevels: 0 5 6 10 1E
PDM: Enabled                           MediaPatrol: Enabled
NumberOfPhysicalDrives: 4              NumberOfLogicalDrives: 1
NumberOfDedicatedSpares: 0
UserSetPowerSavingLevel: 0             CurrentPowerSavingLevel: 0
PowerManagement: Enabled
Physical Drives in the Array:
0     1    2TB         2.76MB       Dead
1     2    2TB         2.76MB       OK
2     3    2TB         2.76MB       OK
3     4    2TB         2.76MB       OK
Logical Drives in the Array:
LdId Alias          RAIDLevel Capacity  OpStatus
0                   RAID5     6TB       Critical
Id  OpStatus  PdId CfgCapacity Revertible Type      DedicatedToArray
cliib> phydrv
1    TOSHIBA DT01 SATA HDD  2TB       Encl1 Slot1   Dead      Array0 No.0
2    TOSHIBA DT01 SATA HDD  2TB       Encl1 Slot2   OK        Array0 No.1
3    TOSHIBA DT01 SATA HDD  2TB       Encl1 Slot3   OK        Array0 No.2
4    TOSHIBA DT01 SATA HDD  2TB       Encl1 Slot4   OK        Array0 No.3
cliib> phydrv -v
PdId: 1
OperationalStatus: Dead
Alias:
PhysicalCapacity: 2TB                  ConfigurableCapacity: 2TB
UsedCapacity: 2TB                      LogicalBlockSize: 512Bytes
ConfigStatus: Array0 No.0              Location: Encl1 Slot1
ModelNo: TOSHIBA DT01ACA2
SerialNo: 45K3H3GAS                    FirmwareVersion: MX4OABB0
DriveInterface: SATA 6Gb/s             Protocol: ATA/ATAPI-8
WriteCacheSupport: Yes                 WriteCache: Enabled
RLACacheSupport: Yes                   RLACache: Enabled
SMARTFeatureSetSupport: Yes
SMARTSelfTestSetSupport: Yes           SMARTErrorLoggingSupport: Yes
CmdQueuingSupport: NCQ                 CmdQueuing: Enabled
CmdQueueDepth: 32                      MediumErrorThreshold: 64
Errors: 0                              NonRWErrors: 0
ReadErrors: 0                          WriteErrors: 0
PowerSavingStatus: Full Power          TemperaturePollingInterval: 3 minutes
DriveTemperature: 37C/98F              ReferenceDriveTemperature: N/A
Flags: N/A                             LastUnconfiguredFragement: N/A
PhysicalSectorSize: 0Byte
PdId: 2
OperationalStatus: OK
Alias:
ConfigStatus: Array0 No.1              Location: Encl1 Slot2
SerialNo: 45K3K6TAS                    FirmwareVersion: MX4OABB0
PdId: 3
Alias:
ConfigStatus: Array0 No.2              Location: Encl1 Slot3
SerialNo: 45K3K5ZAS                    FirmwareVersion: MX4OABB0
DriveTemperature: 38C/100F             ReferenceDriveTemperature: N/A
PdId: 4
Alias:
ConfigStatus: Array0 No.3              Location: Encl1 Slot4
SerialNo: 45K3H22AS                    FirmwareVersion: MX4OABB0
cliib> event -l NVRAM
Seq   Device          Severity TimeStamp             Description
2578  Ctrl 1          Info     May 23, 2019 11:40:10 The system is started
2579  Ctrl 1          Info     May 23, 2019 12:07:10 The system is stopped by
                                                     host unplug
2580  Ctrl 1          Info     May 23, 2019 12:07:05 The system is started
2581  Ctrl 1          Info     May 23, 2019 12:08:42 The system is stopped by
                                                     host unplug
2582  Ctrl 1          Info     May 23, 2019 12:11:14 The system is started
2583  Ctrl 1          Info     May 28, 2019 15:32:20 The system is stopped by
                                                     host shutdown
2584  Ctrl 1          Info     May 28, 2019 15:59:23 The system is started
2585  Ctrl 1          Info     May 28, 2019 17:06:22 The system is stopped by
                                                     host shutdown
2586  Ctrl 1          Info     May 29, 2019 07:42:37 The system is started
2587  Ctrl 1          Warning  Jun 12, 2019 08:31:23 Last shutdown is abnormal
2588  Ctrl 1          Info     Jun 12, 2019 08:31:31 The system is started
2589  Ctrl 1          Info     Jun 12, 2019 08:31:49 The system is stopped by
                                                     host sleep
2590  Ctrl 1          Info     Jun 12, 2019 08:31:49 The system is started
2591  Ctrl 1          Info     Jun 24, 2019 10:44:46 The system is stopped by
                                                     host unplug
2592  Ctrl 1          Info     Jun 24, 2019 10:45:14 The system is started
2593  Ctrl 1          Info     Jul 3, 2019 09:48:21  The system is stopped by
                                                     host shutdown
2594  Ctrl 1          Info     Jul 3, 2019 10:06:57  The system is started
2595  Ctrl 1          Info     Jul 26, 2019 16:52:31 The system is stopped by
                                                     host shutdown
2596  Ctrl 1          Info     Jul 29, 2019 08:40:52 The system is started
2597  Ctrl 1          Info     Aug 6, 2019 11:49:50  The system is stopped by
                                                     host restart
2598  Ctrl 1          Info     Aug 6, 2019 11:49:25  The system is started
2599  Ctrl 1          Info     Aug 6, 2019 11:50:46  The system is stopped by
                                                     host restart
2600  Ctrl 1          Info     Aug 6, 2019 11:52:25  The system is started
2601  Ctrl 1          Info     Aug 6, 2019 11:52:25  The system is stopped by
                                                     host unplug
2602  Ctrl 1          Info     Aug 6, 2019 11:52:25  The system is started
2603  Ctrl 1          Info     Aug 6, 2019 11:56:29  The system is stopped by
                                                     host restart
2604  Ctrl 1          Info     Aug 6, 2019 11:56:30  The system is started
2605  Ctrl 1          Info     Sep 4, 2019 09:46:24  The system is stopped by
                                                     host unplug
2606  Ctrl 1          Info     Sep 4, 2019 09:46:40  The system is started
2607  Ctrl 1          Info     Sep 4, 2019 09:57:46  The system is stopped by
                                                     host unplug
2608  Ctrl 1          Info     Sep 4, 2019 10:00:26  The system is started
2609  Ctrl 1          Info     Sep 4, 2019 10:37:04  The system is stopped by
                                                     host unplug
2610  Ctrl 1          Info     Sep 4, 2019 10:36:32  The system is started
2611  Ctrl 1          Info     Sep 4, 2019 14:45:22  The system is stopped by
                                                     host shutdown
2612  Ctrl 1          Info     Sep 4, 2019 14:46:16  The system is started
2613  Ctrl 1          Info     Sep 4, 2019 15:38:37  The system is stopped by
                                                     host restart
2614  Ctrl 1          Info     Sep 4, 2019 15:38:41  The system is started
2615  Ctrl 1          Info     Sep 4, 2019 15:41:52  The system is stopped by
                                                     host restart
2616  Ctrl 1          Info     Sep 4, 2019 15:41:58  The system is started
2617  Ctrl 1          Info     Sep 13, 2019 17:09:29 The system is stopped by
                                                     host unplug
2618  Ctrl 1          Info     Sep 13, 2019 17:10:25 The system is started
2619  Ctrl 1          Info     Sep 13, 2019 17:10:25 The system is stopped by
                                                     host restart
2620  Ctrl 1          Info     Sep 13, 2019 17:10:25 The system is started
2621  Ctrl 1          Info     Sep 13, 2019 17:12:08 The system is stopped by
                                                     host unplug
2622  Ctrl 1          Info     Sep 13, 2019 17:11:59 The system is started
2623  Ctrl 1          Info     Sep 13, 2019 17:36:22 The system is stopped by
                                                     host shutdown
2624  Ctrl 1          Info     Sep 16, 2019 08:59:22 The system is started
2625  Ctrl 1          Info     Sep 27, 2019 08:51:28 The system is stopped by
                                                     host restart
2626  Ctrl 1          Info     Sep 27, 2019 08:51:52 The system is started
2627  Ctrl 1          Info     Sep 27, 2019 08:54:57 The system is stopped by
                                                     host restart
2628  Ctrl 1          Info     Sep 27, 2019 08:54:44 The system is started
2629  Ctrl 1          Info     Nov 11, 2019 14:28:02 The system is stopped by
                                                     host shutdown
2630  Ctrl 1          Info     Nov 11, 2019 14:39:08 The system is started
2631  Ctrl 1          Info     Dec 19, 2019 10:30:37 The system is stopped by
                                                     host restart
2632  Ctrl 1          Info     Dec 19, 2019 10:30:48 The system is started
2633  Ctrl 1          Info     Dec 19, 2019 10:34:17 The system is stopped by
                                                     host restart
2634  Ctrl 1          Info     Dec 19, 2019 10:33:08 The system is started
2635  Ctrl 1          Info     Dec 19, 2019 10:39:04 The system is stopped by
                                                     host shutdown
2636  Ctrl 1          Info     Dec 19, 2019 10:55:20 The system is started
2637  Ctrl 1          Info     Dec 23, 2019 16:47:16 The system is stopped by
                                                     host shutdown
2638  Ctrl 1          Info     Dec 27, 2019 08:59:09 The system is started
2639  Ctrl 1          Info     Dec 27, 2019 10:18:21 The system is stopped by
                                                     host restart
2640  Ctrl 1          Info     Dec 27, 2019 10:18:09 The system is started
2641  Ctrl 1          Info     Dec 27, 2019 10:21:38 The system is stopped by
                                                     host restart
2642  Ctrl 1          Info     Dec 27, 2019 10:21:43 The system is started
2643  Ctrl 1          Info     Jan 7, 2020 09:21:54  The system is stopped by
                                                     host restart
2644  Ctrl 1          Info     Jan 7, 2020 09:22:26  The system is started
2645  Ctrl 1          Info     Jan 7, 2020 09:26:16  The system is stopped by
                                                     host restart
2646  Ctrl 1          Info     Jan 7, 2020 09:26:03  The system is started
2647  Ctrl 1          Info     Jan 27, 2020 15:20:10 The system is stopped by
                                                     host shutdown
2648  Ctrl 1          Info     Jan 27, 2020 15:25:13 The system is started
2649  Ctrl 1          Info     Feb 5, 2020 08:43:33  The system is stopped by
                                                     host restart
2650  Ctrl 1          Info     Feb 5, 2020 08:43:19  The system is started
2651  Ctrl 1          Info     Feb 5, 2020 12:47:39  The system is stopped by
                                                     host unplug
2652  Ctrl 1          Info     Feb 5, 2020 14:20:26  The system is started
2653  Ctrl 1          Warning  Feb 5, 2020 14:20:06  Last shutdown is abnormal
2654  Ctrl 1          Info     Feb 5, 2020 14:20:14  The system is started
2655  Ctrl 1          Info     Feb 5, 2020 14:20:26  The system is stopped by
                                                     host sleep
2656  Ctrl 1          Info     Feb 5, 2020 14:20:26  The system is started
2657  Ctrl 1          Info     Feb 5, 2020 14:51:47  The system is stopped by
                                                     host restart
2658  Ctrl 1          Info     Feb 5, 2020 14:51:53  The system is started
2659  Ctrl 1          Info     Feb 5, 2020 16:54:15  The system is stopped by
                                                     host shutdown
2660  Ctrl 1          Info     Feb 6, 2020 09:12:41  The system is started
2661  Ctrl 1          Info     Feb 6, 2020 09:16:55  The system is stopped by
                                                     host restart
2662  Ctrl 1          Info     Feb 6, 2020 09:17:00  The system is started
2663  Ctrl 1          Info     Feb 6, 2020 09:19:46  The system is stopped by
                                                     host shutdown
2664  Ctrl 1          Info     Feb 6, 2020 09:20:10  The system is started
2665  Ctrl 1          Info     Feb 6, 2020 09:21:27  The system is stopped by
                                                     host shutdown
2666  Ctrl 1          Info     Feb 6, 2020 09:22:01  The system is started
2667  Ctrl 1          Info     Feb 6, 2020 09:32:49  The system is stopped by
                                                     host restart
2668  Ctrl 1          Info     Feb 6, 2020 09:32:53  The system is started
2669  Ctrl 1          Info     Feb 6, 2020 09:46:34  The system is stopped by
                                                     host shutdown
2670  Ctrl 1          Info     Feb 6, 2020 09:47:00  The system is started
2671  Ctrl 1          Info     Feb 7, 2020 17:06:11  The system is stopped by
                                                     host shutdown
2672  Ctrl 1          Info     Feb 10, 2020 08:25:22 The system is started
2673  Ctrl 1          Info     Feb 13, 2020 16:11:18 The system is stopped by
                                                     host unplug
2674  Ctrl 1          Info     Feb 13, 2020 16:48:34 The system is started
2675  Ctrl 1          Info     Feb 27, 2020 08:48:36 The system is stopped by
                                                     host unplug
2676  Ctrl 1          Info     Feb 27, 2020 08:48:54 The system is started
2677  Ctrl 1          Info     Mar 19, 2020 15:23:44 The system is stopped by
                                                     host shutdown
2678  Ctrl 1          Info     Mar 20, 2020 13:10:47 The system is started
2679  Ctrl 1          Info     Mar 20, 2020 13:10:47 The system is stopped by
                                                     host sleep
2680  Ctrl 1          Info     Mar 20, 2020 13:10:47 The system is started
2681  Ctrl 1          Info     Mar 25, 2020 23:07:56 The system is stopped by
                                                     host sleep
2682  Ctrl 1          Info     Mar 25, 2020 23:44:49 The system is started
2683  Ctrl 1          Info     Mar 25, 2020 23:46:02 The system is stopped by
                                                     host sleep
2684  Ctrl 1          Info     Mar 26, 2020 01:19:00 The system is started
2685  Ctrl 1          Info     Mar 26, 2020 01:20:13 The system is stopped by
                                                     host sleep
2686  Ctrl 1          Info     Mar 26, 2020 04:03:27 The system is started
2687  Ctrl 1          Info     Mar 26, 2020 04:04:40 The system is stopped by
                                                     host sleep
2688  Ctrl 1          Info     Mar 26, 2020 05:26:15 The system is started
2689  Ctrl 1          Info     Mar 26, 2020 05:27:28 The system is stopped by
                                                     host sleep
2690  Ctrl 1          Info     Mar 26, 2020 06:51:44 The system is started
2691  Ctrl 1          Info     Mar 26, 2020 06:52:57 The system is stopped by
                                                     host sleep
2692  Ctrl 1          Info     Mar 26, 2020 08:15:05 The system is started
2693  Ctrl 1          Info     Mar 26, 2020 09:15:05 The system is stopped by
                                                     host sleep
2694  Ctrl 1          Info     Mar 26, 2020 10:47:38 The system is started
2695  Ctrl 1          Info     Mar 26, 2020 10:48:52 The system is stopped by
                                                     host sleep
2696  Ctrl 1          Info     Mar 26, 2020 12:31:07 The system is started
2697  Ctrl 1          Info     Mar 28, 2020 00:05:19 The system is stopped by
                                                     host sleep
2698  Ctrl 1          Info     Mar 28, 2020 01:41:02 The system is started
2699  Ctrl 1          Info     Mar 28, 2020 01:42:15 The system is stopped by
                                                     host sleep
2700  Ctrl 1          Info     Mar 28, 2020 03:12:35 The system is started
2701  Ctrl 1          Info     Mar 28, 2020 03:13:48 The system is stopped by
                                                     host sleep
2702  Ctrl 1          Info     Mar 28, 2020 08:30:05 The system is started
2703  Ctrl 1          Info     Mar 28, 2020 09:30:05 The system is stopped by
                                                     host sleep
2704  Ctrl 1          Info     Mar 28, 2020 09:33:17 The system is started
2705  Ctrl 1          Info     Mar 28, 2020 09:34:30 The system is stopped by
                                                     host sleep
2706  Ctrl 1          Info     Mar 28, 2020 11:07:27 The system is started
2707  Ctrl 1          Info     Mar 28, 2020 11:08:39 The system is stopped by
                                                     host sleep
2708  Ctrl 1          Info     Mar 28, 2020 12:23:32 The system is started
2709  Ctrl 1          Info     Mar 28, 2020 12:24:45 The system is stopped by
                                                     host sleep
2710  Ctrl 1          Info     Mar 28, 2020 12:54:56 The system is started
2711  Ctrl 1          Info     Mar 29, 2020 15:33:50 The system is stopped by
                                                     host shutdown
2712  Ctrl 1          Info     Mar 29, 2020 15:35:41 The system is started
2713  Ctrl 1          Info     Apr 4, 2020 23:30:28  The system is stopped by
                                                     host sleep
2714  Ctrl 1          Info     Apr 4, 2020 23:39:38  The system is started
2715  Ctrl 1          Info     Apr 4, 2020 23:40:51  The system is stopped by
                                                     host sleep
2716  Ctrl 1          Info     Apr 5, 2020 00:34:46  The system is started
2717  Ctrl 1          Info     Apr 5, 2020 00:35:59  The system is stopped by
                                                     host sleep
2718  Ctrl 1          Info     Apr 5, 2020 01:52:57  The system is started
2719  Ctrl 1          Info     Apr 5, 2020 01:54:11  The system is stopped by
                                                     host sleep
2720  Ctrl 1          Info     Apr 5, 2020 04:18:43  The system is started
2721  Ctrl 1          Info     Apr 5, 2020 04:19:56  The system is stopped by
                                                     host sleep
2722  Ctrl 1          Info     Apr 5, 2020 06:45:28  The system is started
2723  Ctrl 1          Info     Apr 5, 2020 06:46:41  The system is stopped by
                                                     host sleep
2724  Ctrl 1          Info     Apr 5, 2020 06:48:35  The system is started
2725  Ctrl 1          Info     Apr 5, 2020 06:49:48  The system is stopped by
                                                     host sleep
2726  Ctrl 1          Info     Apr 5, 2020 10:10:11  The system is started
2727  Ctrl 1          Info     Apr 7, 2020 10:04:19  The system is stopped by
                                                     host shutdown
2728  Ctrl 1          Info     Apr 7, 2020 10:05:24  The system is started
2729  Ctrl 1          Info     Apr 22, 2020 09:15:38 The system is stopped by
                                                     host shutdown
2730  Ctrl 1          Info     Apr 22, 2020 09:16:32 The system is started
2731  Ctrl 1          Info     Apr 25, 2020 00:57:01 The system is stopped by
                                                     host shutdown
2732  Ctrl 1          Info     Apr 25, 2020 10:30:44 The system is started
2733  Ctrl 1          Warning  May 11, 2020 10:38:11 Last shutdown is abnormal
2734  Ctrl 1          Info     May 11, 2020 10:38:19 The system is started
2735  Ctrl 1          Info     May 11, 2020 10:38:33 The system is stopped by
                                                     host sleep
2736  Ctrl 1          Info     May 11, 2020 10:38:33 The system is started
2737  Ctrl 1          Info     May 13, 2020 06:45:02 The system is stopped by
                                                     host shutdown
2738  Ctrl 1          Info     May 13, 2020 10:59:11 The system is started
2739  Ctrl 1          Info     May 13, 2020 10:59:11 The system is stopped by
                                                     host sleep
2740  Ctrl 1          Info     May 13, 2020 10:59:11 The system is started
2741  Ctrl 1          Info     May 13, 2020 11:04:42 The system is stopped by
                                                     host unplug
2742  Ctrl 1          Info     May 13, 2020 11:05:09 The system is started
2743  Ctrl 1          Info     May 13, 2020 12:57:43 The system is stopped by
                                                     host sleep
2744  Ctrl 1          Info     May 13, 2020 13:43:21 The system is started
2745  Ctrl 1          Info     May 13, 2020 13:44:37 The system is stopped by
                                                     host sleep
2746  Ctrl 1          Info     May 13, 2020 15:44:38 The system is started
2747  Ctrl 1          Info     May 13, 2020 15:46:15 The system is stopped by
                                                     host sleep
2748  Ctrl 1          Info     May 13, 2020 16:26:29 The system is started
2749  Ctrl 1          Info     May 13, 2020 17:05:53 The system is stopped by
                                                     host unplug
2750  Ctrl 1          Info     May 14, 2020 10:09:33 The system is started
2751  Ctrl 1          Info     May 14, 2020 10:09:33 The system is stopped by
                                                     host sleep
2752  Ctrl 1          Info     May 14, 2020 10:09:33 The system is started
2753  Ctrl 1          Info     May 26, 2020 00:01:18 The system is stopped by
                                                     host shutdown
2754  Ctrl 1          Info     May 26, 2020 09:06:13 The system is started
2755  Ctrl 1          Warning  May 29, 2020 19:29:20 Last shutdown is abnormal
2756  Ctrl 1          Info     May 29, 2020 19:29:28 The system is started
2757  Ctrl 1          Info     May 29, 2020 19:29:46 The system is stopped by
                                                     host sleep
2758  Ctrl 1          Info     May 29, 2020 19:29:46 The system is started
2759  Ctrl 1          Info     May 29, 2020 21:31:10 The system is stopped by
                                                     host sleep
2760  Ctrl 1          Info     May 29, 2020 22:02:28 The system is started
2761  Ctrl 1          Info     May 29, 2020 22:03:40 The system is stopped by
                                                     host sleep
2762  Ctrl 1          Info     May 29, 2020 22:19:03 The system is started
2763  Ctrl 1          Info     May 29, 2020 22:20:15 The system is stopped by
                                                     host sleep
2764  Ctrl 1          Info     May 30, 2020 00:40:06 The system is started
2765  Ctrl 1          Info     May 30, 2020 00:41:22 The system is stopped by
                                                     host sleep
2766  Ctrl 1          Info     May 30, 2020 05:28:19 The system is started
2767  Ctrl 1          Info     May 30, 2020 05:29:35 The system is stopped by
                                                     host sleep
2768  Ctrl 1          Info     May 30, 2020 09:30:05 The system is started
2769  Ctrl 1          Info     May 30, 2020 10:30:08 The system is stopped by
                                                     host sleep
2770  Ctrl 1          Info     May 30, 2020 19:42:02 The system is started
2771  Ctrl 1          Info     May 30, 2020 19:43:18 The system is stopped by
                                                     host sleep
2772  Ctrl 1          Info     May 30, 2020 20:36:05 The system is started
2773  Ctrl 1          Info     May 30, 2020 20:37:17 The system is stopped by
                                                     host sleep
2774  Ctrl 1          Info     May 30, 2020 22:14:52 The system is started
2775  Ctrl 1          Info     May 30, 2020 22:16:04 The system is stopped by
                                                     host sleep
2776  Ctrl 1          Info     May 31, 2020 07:10:53 The system is started
2777  Ctrl 1          Info     May 31, 2020 07:12:09 The system is stopped by
                                                     host sleep
2778  Ctrl 1          Info     May 31, 2020 09:30:05 The system is started
2779  Ctrl 1          Info     May 31, 2020 10:30:09 The system is stopped by
                                                     host sleep
2780  Ctrl 1          Info     Jun 1, 2020 07:10:32  The system is started
2781  Ctrl 1          Info     Jun 1, 2020 07:11:02  The system is stopped by
                                                     host shutdown
2782  Ctrl 1          Info     Jun 1, 2020 13:24:34  The system is started
2783  Ctrl 1          Info     Jun 1, 2020 13:24:34  The system is stopped by
                                                     host sleep
2784  Ctrl 1          Info     Jun 1, 2020 13:24:34  The system is started
2785  Ctrl 1          Info     Jun 12, 2020 16:29:03 The system is stopped by
                                                     host shutdown
2786  Ctrl 1          Info     Jun 15, 2020 08:51:51 The system is started
2787  Ctrl 1          Info     Jun 26, 2020 08:46:42 The system is stopped by
                                                     host restart
2788  Ctrl 1          Info     Jun 26, 2020 08:46:44 The system is started
2789  Ctrl 1          Info     Jun 26, 2020 17:13:33 The system is stopped by
                                                     host shutdown
2790  Ctrl 1          Info     Jun 29, 2020 08:47:29 The system is started
2791  Ctrl 1          Info     Jul 2, 2020 13:38:24  The system is stopped by
                                                     host shutdown
2792  Ctrl 1          Info     Jul 6, 2020 10:26:25  The system is started
2793  Ctrl 1          Info     Jul 6, 2020 10:26:25  The system is stopped by
                                                     host sleep
2794  Ctrl 1          Info     Jul 6, 2020 10:26:25  The system is started
2795  Ctrl 1          Info     Jul 6, 2020 13:40:39  The system is stopped by
                                                     host shutdown
2796  Ctrl 1          Info     Jul 13, 2020 12:19:15 The system is started
2797  Ctrl 1          Info     Jul 13, 2020 12:19:15 The system is stopped by
                                                     host sleep
2798  Ctrl 1          Info     Jul 13, 2020 12:19:15 The system is started
2799  Ctrl 1          Info     Jul 31, 2020 16:56:36 The system is stopped by
                                                     host shutdown
2800  Ctrl 1          Info     Aug 3, 2020 09:07:22  The system is started
2801  Ctrl 1          Info     Aug 10, 2020 17:37:36 The system is stopped by
                                                     host shutdown
2802  Ctrl 1          Info     Aug 10, 2020 20:41:48 The system is started
2803  Ctrl 1          Info     Aug 10, 2020 20:41:48 The system is stopped by
                                                     host sleep
2804  Ctrl 1          Info     Aug 10, 2020 20:41:48 The system is started
2805  Ctrl 1          Info     Aug 11, 2020 13:01:49 The system is stopped by
                                                     host unplug
2806  Ctrl 1          Info     Aug 11, 2020 13:03:24 The system is started
2807  Ctrl 1          Info     Aug 11, 2020 13:07:12 The system is stopped by
                                                     host shutdown
2808  Ctrl 1          Info     Aug 11, 2020 13:32:58 The system is started
2809  Ctrl 1          Info     Aug 12, 2020 08:43:49 The system is stopped by
                                                     host shutdown
2810  Ctrl 1          Info     Aug 13, 2020 09:22:12 The system is started
2811  Ctrl 1          Info     Aug 14, 2020 08:21:14 The system is stopped by
                                                     host shutdown
2812  Ctrl 1          Info     Aug 14, 2020 09:15:16 The system is started
2813  Ctrl 1          Info     Aug 14, 2020 09:15:16 The system is stopped by
                                                     host sleep
2814  Ctrl 1          Info     Aug 14, 2020 09:15:16 The system is started
2815  Ctrl 1          Info     Aug 17, 2020 17:41:01 The system is stopped by
                                                     host shutdown
2816  Ctrl 1          Info     Aug 17, 2020 21:00:31 The system is started
2817  Ctrl 1          Info     Aug 17, 2020 21:00:31 The system is stopped by
                                                     host sleep
2818  Ctrl 1          Info     Aug 17, 2020 21:00:31 The system is started
2819  Ctrl 1          Info     Aug 17, 2020 23:09:34 The system is stopped by
                                                     host sleep
2820  Ctrl 1          Info     Aug 18, 2020 00:39:40 The system is started
2821  Ctrl 1          Info     Aug 18, 2020 00:41:02 The system is stopped by
                                                     host sleep
2822  Ctrl 1          Info     Aug 18, 2020 08:30:19 The system is started
2823  Ctrl 1          Info     Aug 18, 2020 09:46:47 The system is stopped by
                                                     host unplug
2824  Ctrl 1          Info     Aug 18, 2020 09:47:17 The system is started
2825  Ctrl 1          Info     Aug 20, 2020 21:26:36 The system is stopped by
                                                     host shutdown
2826  Ctrl 1          Info     Aug 20, 2020 22:36:43 The system is started
2827  Ctrl 1          Info     Aug 20, 2020 22:45:43 The system is stopped by
                                                     host shutdown
2828  Ctrl 1          Info     Aug 21, 2020 09:13:16 The system is started
2829  Ctrl 1          Info     Aug 21, 2020 09:15:28 The system is stopped by
                                                     host sleep
2830  Ctrl 1          Info     Aug 21, 2020 09:16:27 The system is started
2831  Ctrl 1          Info     Aug 21, 2020 09:16:27 The system is stopped by
                                                     host sleep
2832  Ctrl 1          Info     Aug 21, 2020 09:16:27 The system is started
2833  Ctrl 1          Info     Aug 21, 2020 09:29:10 The system is stopped by
                                                     host unplug
2834  Ctrl 1          Info     Aug 21, 2020 09:30:16 The system is started
2835  Ctrl 1          Info     Aug 21, 2020 17:47:16 The system is stopped by
                                                     host shutdown
2836  Ctrl 1          Info     Aug 24, 2020 08:56:47 The system is started
2837  Ctrl 1          Info     Aug 24, 2020 16:26:06 The system is stopped by
                                                     host shutdown
2838  Ctrl 1          Info     Aug 24, 2020 17:24:49 The system is started
2839  Ctrl 1          Info     Aug 24, 2020 17:24:49 The system is stopped by
                                                     host sleep
2840  Ctrl 1          Info     Aug 24, 2020 17:24:49 The system is started
2841  Ctrl 1          Info     Aug 25, 2020 00:58:52 The system is stopped by
                                                     host sleep
2842  Ctrl 1          Info     Aug 25, 2020 00:58:38 The system is started
2843  Ctrl 1          Info     Aug 25, 2020 01:00:01 The system is stopped by
                                                     host sleep
2844  Ctrl 1          Info     Aug 25, 2020 01:35:29 The system is started
2845  Ctrl 1          Info     Aug 25, 2020 01:36:51 The system is stopped by
                                                     host sleep
2846  Ctrl 1          Info     Aug 25, 2020 02:10:33 The system is started
2847  Ctrl 1          Info     Aug 25, 2020 02:12:00 The system is stopped by
                                                     host sleep
2848  Ctrl 1          Info     Aug 25, 2020 07:07:35 The system is started
2849  Ctrl 1          Info     Aug 25, 2020 07:09:01 The system is stopped by
                                                     host sleep
2850  Ctrl 1          Info     Aug 25, 2020 08:30:05 The system is started
2851  Ctrl 1          Info     Aug 25, 2020 08:52:30 The system is stopped by
                                                     host sleep
2852  Ctrl 1          Info     Aug 25, 2020 09:55:00 The system is started
2853  Ctrl 1          Info     Aug 27, 2020 08:27:52 The system is stopped by
                                                     host shutdown
2854  Ctrl 1          Info     Aug 27, 2020 09:41:25 The system is started
2855  Ctrl 1          Info     Aug 27, 2020 09:41:25 The system is stopped by
                                                     host sleep
2856  Ctrl 1          Info     Aug 27, 2020 09:41:25 The system is started
2857  Ctrl 1          Info     Aug 28, 2020 17:20:47 The system is stopped by
                                                     host shutdown
2858  Ctrl 1          Info     Sep 8, 2020 08:10:38  The system is started
2859  Ctrl 1          Info     Sep 8, 2020 08:10:38  The system is stopped by
                                                     host sleep
2860  Ctrl 1          Info     Sep 8, 2020 08:10:38  The system is started
2861  Ctrl 1          Info     Sep 14, 2020 08:15:02 The system is stopped by
                                                     host shutdown
2862  Ctrl 1          Info     Sep 14, 2020 09:18:20 The system is started
2863  Ctrl 1          Info     Sep 14, 2020 16:40:37 The system is stopped by
                                                     host shutdown
2864  Ctrl 1          Info     Sep 15, 2020 09:15:58 The system is started
2865  Ctrl 1          Info     Sep 15, 2020 09:15:58 The system is stopped by
                                                     host sleep
2866  Ctrl 1          Info     Sep 15, 2020 09:15:58 The system is started
2867  Ctrl 1          Info     Sep 16, 2020 22:45:05 The system is stopped by
                                                     host sleep
2868  Ctrl 1          Info     Sep 16, 2020 22:44:53 The system is started
2869  Ctrl 1          Info     Sep 16, 2020 22:46:15 The system is stopped by
                                                     host sleep
2870  Ctrl 1          Info     Sep 16, 2020 23:20:23 The system is started
2871  Ctrl 1          Info     Sep 16, 2020 23:21:45 The system is stopped by
                                                     host sleep
2872  Ctrl 1          Info     Sep 17, 2020 02:28:34 The system is started
2873  Ctrl 1          Info     Sep 17, 2020 02:30:00 The system is stopped by
                                                     host sleep
2874  Ctrl 1          Info     Sep 17, 2020 08:10:31 The system is started
2875  Ctrl 1          Info     Sep 18, 2020 00:17:15 The system is stopped by
                                                     host sleep
2876  Ctrl 1          Info     Sep 18, 2020 00:56:31 The system is started
2877  Ctrl 1          Info     Sep 18, 2020 00:57:53 The system is stopped by
                                                     host sleep
2878  Ctrl 1          Info     Sep 18, 2020 01:30:58 The system is started
2879  Ctrl 1          Info     Sep 18, 2020 01:32:24 The system is stopped by
                                                     host sleep
2880  Ctrl 1          Info     Sep 18, 2020 07:20:17 The system is started
2881  Ctrl 1          Info     Sep 18, 2020 07:21:43 The system is stopped by
                                                     host sleep
2882  Ctrl 1          Info     Sep 18, 2020 08:22:46 The system is started
2883  Ctrl 1          Info     Sep 23, 2020 09:18:48 The system is stopped by
                                                     host shutdown
2884  Ctrl 1          Info     Sep 23, 2020 14:19:55 The system is started
2885  Ctrl 1          Info     Sep 23, 2020 21:59:28 The system is stopped by
                                                     host sleep
2886  Ctrl 1          Info     Sep 23, 2020 21:59:18 The system is started
2887  Ctrl 1          Info     Sep 23, 2020 22:00:40 The system is stopped by
                                                     host sleep
2888  Ctrl 1          Info     Sep 23, 2020 22:34:42 The system is started
2889  Ctrl 1          Info     Sep 23, 2020 22:36:04 The system is stopped by
                                                     host sleep
2890  Ctrl 1          Info     Sep 23, 2020 23:07:16 The system is started
2891  Ctrl 1          Info     Sep 23, 2020 23:08:42 The system is stopped by
                                                     host sleep
2892  Ctrl 1          Info     Sep 24, 2020 02:26:55 The system is started
2893  Ctrl 1          Info     Sep 24, 2020 02:28:21 The system is stopped by
                                                     host sleep
2894  Ctrl 1          Info     Sep 24, 2020 08:15:05 The system is started
2895  Ctrl 1          Info     Sep 25, 2020 08:02:42 The system is stopped by
                                                     host shutdown
2896  Ctrl 1          Info     Sep 25, 2020 08:52:25 The system is started
2897  Ctrl 1          Info     Sep 25, 2020 08:52:25 The system is stopped by
                                                     host sleep
2898  Ctrl 1          Info     Sep 25, 2020 08:52:25 The system is started
2899  Ctrl 1          Info     Sep 25, 2020 19:59:00 The system is stopped by
                                                     host shutdown
2900  Ctrl 1          Info     Sep 28, 2020 06:24:04 The system is started
2901  Ctrl 1          Info     Sep 29, 2020 14:56:27 The system is stopped by
                                                     host shutdown
2902  Ctrl 1          Info     Sep 30, 2020 09:11:19 The system is started
2903  Ctrl 1          Info     Sep 30, 2020 09:11:19 The system is stopped by
                                                     host sleep
2904  Ctrl 1          Info     Sep 30, 2020 09:11:19 The system is started
2905  Ctrl 1          Info     Oct 2, 2020 07:38:00  The system is stopped by
                                                     host shutdown
2906  Ctrl 1          Info     Oct 2, 2020 08:45:14  The system is started
2907  Ctrl 1          Info     Oct 2, 2020 08:45:14  The system is stopped by
                                                     host sleep
2908  Ctrl 1          Info     Oct 2, 2020 08:45:14  The system is started
2909  Ctrl 1          Info     Oct 2, 2020 17:54:30  The system is stopped by
                                                     host shutdown
2910  Ctrl 1          Info     Oct 3, 2020 18:46:15  The system is started
2911  Ctrl 1          Info     Oct 3, 2020 20:26:48  The system is stopped by
                                                     host shutdown
2912  Ctrl 1          Info     Oct 4, 2020 20:41:32  The system is started
2913  Ctrl 1          Info     Oct 4, 2020 20:41:32  The system is stopped by
                                                     host sleep
2914  Ctrl 1          Info     Oct 4, 2020 20:41:32  The system is started
2915  Ctrl 1          Info     Oct 4, 2020 23:52:01  The system is stopped by
                                                     host shutdown
2916  Ctrl 1          Info     Oct 5, 2020 08:53:50  The system is started
2917  Ctrl 1          Info     Oct 5, 2020 08:53:50  The system is stopped by
                                                     host sleep
2918  Ctrl 1          Info     Oct 5, 2020 08:53:50  The system is started
2919  Ctrl 1          Info     Oct 5, 2020 16:09:34  The system is stopped by
                                                     host shutdown
2920  Ctrl 1          Info     Oct 6, 2020 08:33:31  The system is started
2921  Ctrl 1          Info     Oct 6, 2020 08:33:31  The system is stopped by
                                                     host sleep
2922  Ctrl 1          Info     Oct 6, 2020 08:33:31  The system is started
2923  Ctrl 1          Info     Oct 8, 2020 23:36:25  The system is stopped by
                                                     host sleep
2924  Ctrl 1          Info     Oct 8, 2020 23:43:33  The system is started
2925  Ctrl 1          Info     Oct 8, 2020 23:44:55  The system is stopped by
                                                     host sleep
2926  Ctrl 1          Info     Oct 9, 2020 00:24:18  The system is started
2927  Ctrl 1          Info     Oct 9, 2020 00:25:40  The system is stopped by
                                                     host sleep
2928  Ctrl 1          Info     Oct 9, 2020 01:09:13  The system is started
2929  Ctrl 1          Info     Oct 9, 2020 01:10:40  The system is stopped by
                                                     host sleep
2930  Ctrl 1          Info     Oct 9, 2020 06:41:21  The system is started
2931  Ctrl 1          Info     Oct 9, 2020 06:42:47  The system is stopped by
                                                     host sleep
2932  Ctrl 1          Info     Oct 9, 2020 08:37:04  The system is started
2933  Ctrl 1          Info     Oct 9, 2020 08:38:15  The system is stopped by
                                                     host shutdown
2934  Ctrl 1          Info     Oct 9, 2020 09:34:51  The system is started
2935  Ctrl 1          Info     Oct 12, 2020 16:30:28 The system is stopped by
                                                     host shutdown
2936  Ctrl 1          Info     Oct 13, 2020 09:53:40 The system is started
2937  Ctrl 1          Info     Oct 13, 2020 13:45:23 The system is stopped by
                                                     host shutdown
2938  Ctrl 1          Info     Oct 14, 2020 11:51:40 The system is started
2939  Ctrl 1          Info     Oct 14, 2020 12:20:17 The system is stopped by
                                                     host shutdown
2940  Ctrl 1          Info     Oct 14, 2020 13:41:52 The system is started
2941  Ctrl 1          Info     Oct 14, 2020 13:41:52 The system is stopped by
                                                     host sleep
2942  Ctrl 1          Info     Oct 14, 2020 13:41:52 The system is started
2943  Ctrl 1          Info     Oct 15, 2020 21:49:04 The system is stopped by
                                                     host sleep
2944  Ctrl 1          Info     Oct 15, 2020 22:21:36 The system is started
2945  Ctrl 1          Info     Oct 15, 2020 22:23:02 The system is stopped by
                                                     host sleep
2946  Ctrl 1          Info     Oct 15, 2020 23:14:58 The system is started
2947  Ctrl 1          Info     Oct 15, 2020 23:16:24 The system is stopped by
                                                     host sleep
2948  Ctrl 1          Info     Oct 16, 2020 01:16:25 The system is started
2949  Ctrl 1          Info     Oct 16, 2020 01:17:51 The system is stopped by
                                                     host sleep
2950  Ctrl 1          Info     Oct 16, 2020 03:17:52 The system is started
2951  Ctrl 1          Info     Oct 16, 2020 03:19:18 The system is stopped by
                                                     host sleep
2952  Ctrl 1          Info     Oct 16, 2020 05:19:19 The system is started
2953  Ctrl 1          Info     Oct 16, 2020 05:20:45 The system is stopped by
                                                     host sleep
2954  Ctrl 1          Info     Oct 16, 2020 07:20:46 The system is started
2955  Ctrl 1          Info     Oct 16, 2020 07:22:12 The system is stopped by
                                                     host sleep
2956  Ctrl 1          Info     Oct 16, 2020 07:52:48 The system is started
2957  Ctrl 1          Info     Oct 16, 2020 07:59:26 The system is stopped by
                                                     host shutdown
2958  Ctrl 1          Info     Oct 16, 2020 08:56:34 The system is started
2959  Ctrl 1          Info     Oct 16, 2020 08:56:34 The system is stopped by
                                                     host sleep
2960  Ctrl 1          Info     Oct 16, 2020 08:56:34 The system is started
2961  Ctrl 1          Info     Oct 16, 2020 16:49:10 The system is stopped by
                                                     host shutdown
2962  Ctrl 1          Info     Oct 18, 2020 14:55:35 The system is started
2963  Ctrl 1          Info     Oct 18, 2020 14:55:35 The system is stopped by
                                                     host sleep
2964  Ctrl 1          Info     Oct 18, 2020 14:55:35 The system is started
2965  Ctrl 1          Warning  Oct 19, 2020 08:41:33 Last shutdown is abnormal
2966  Ctrl 1          Info     Oct 19, 2020 08:41:41 The system is started
2967  Ctrl 1          Info     Oct 19, 2020 08:41:55 The system is stopped by
                                                     host sleep
2968  Ctrl 1          Info     Oct 19, 2020 08:41:55 The system is started
2969  Ctrl 1          Info     Oct 20, 2020 09:04:44 The system is stopped by
                                                     host shutdown
2970  Ctrl 1          Info     Oct 20, 2020 10:19:51 The system is started
2971  Ctrl 1          Info     Oct 20, 2020 10:24:11 The system is stopped by
                                                     host unplug
2972  Ctrl 1          Info     Oct 20, 2020 10:19:50 The system is started
2973  Ctrl 1          Info     Oct 20, 2020 10:19:50 The system is stopped by
                                                     host sleep
2974  Ctrl 1          Info     Oct 20, 2020 10:19:50 The system is started
2975  Ctrl 1          Info     Oct 20, 2020 12:54:56 The system is stopped by
                                                     host unplug
2976  Ctrl 1          Info     Oct 20, 2020 16:25:08 The system is started
2977  Ctrl 1          Info     Oct 20, 2020 16:25:08 The system is stopped by
                                                     host sleep
2978  Ctrl 1          Info     Oct 20, 2020 16:25:08 The system is started
2979  Ctrl 1          Info     Oct 20, 2020 22:54:35 The system is stopped by
                                                     host sleep
2980  Ctrl 1          Info     Oct 20, 2020 22:58:45 The system is started
2981  Ctrl 1          Info     Oct 20, 2020 22:59:57 The system is stopped by
                                                     host sleep
2982  Ctrl 1          Info     Oct 20, 2020 23:35:27 The system is started
2983  Ctrl 1          Info     Oct 20, 2020 23:36:39 The system is stopped by
                                                     host sleep
2984  Ctrl 1          Info     Oct 21, 2020 03:05:02 The system is started
2985  Ctrl 1          Info     Oct 21, 2020 03:06:15 The system is stopped by
                                                     host sleep
2986  Ctrl 1          Info     Oct 21, 2020 08:06:16 The system is started
2987  Ctrl 1          Info     Oct 21, 2020 17:49:39 The system is stopped by
                                                     host sleep
2988  Ctrl 1          Info     Oct 21, 2020 17:54:15 The system is started
2989  Ctrl 1          Info     Oct 21, 2020 17:55:27 The system is stopped by
                                                     host sleep
2990  Ctrl 1          Info     Oct 21, 2020 18:27:05 The system is started
2991  Ctrl 1          Info     Oct 21, 2020 18:28:17 The system is stopped by
                                                     host sleep
2992  Ctrl 1          Info     Oct 21, 2020 19:16:20 The system is started
2993  Ctrl 1          Info     Oct 21, 2020 19:17:39 The system is stopped by
                                                     host sleep
2994  Ctrl 1          Info     Oct 22, 2020 08:03:20 The system is started
2995  Ctrl 1          Info     Oct 22, 2020 08:04:33 The system is stopped by
                                                     host sleep
2996  Ctrl 1          Info     Oct 22, 2020 08:15:05 The system is started
2997  Ctrl 1          Info     Oct 23, 2020 09:50:23 The system is stopped by
                                                     host shutdown
2998  Ctrl 1          Info     Oct 23, 2020 09:53:12 The system is started
2999  Ctrl 1          Info     Oct 23, 2020 09:57:53 The system is stopped by
                                                     host unplug
3000  Ctrl 1          Info     Oct 23, 2020 09:58:54 The system is started
3001  Ctrl 1          Info     Oct 23, 2020 14:59:28 The system is stopped by
                                                     host sleep
3002  Ctrl 1          Info     Oct 23, 2020 15:06:24 The system is started
3003  Ctrl 1          Info     Oct 23, 2020 15:07:38 The system is stopped by
                                                     host sleep
3004  Ctrl 1          Info     Oct 23, 2020 15:43:00 The system is started
3005  Ctrl 1          Info     Oct 23, 2020 15:44:12 The system is stopped by
                                                     host sleep
3006  Ctrl 1          Info     Oct 23, 2020 16:58:51 The system is started
3007  Ctrl 1          Info     Oct 23, 2020 17:00:08 The system is stopped by
                                                     host sleep
3008  Ctrl 1          Info     Oct 23, 2020 17:14:04 The system is started
3009  Ctrl 1          Info     Oct 23, 2020 17:14:52 The system is stopped by
                                                     host shutdown
3010  Ctrl 1          Info     Oct 23, 2020 18:06:31 The system is started
3011  Ctrl 1          Info     Oct 27, 2020 01:39:29 The system is stopped by
                                                     host sleep
3012  Ctrl 1          Info     Oct 27, 2020 01:47:04 The system is started
3013  Ctrl 1          Info     Oct 27, 2020 01:48:16 The system is stopped by
                                                     host sleep
3014  Ctrl 1          Info     Oct 27, 2020 02:22:33 The system is started
3015  Ctrl 1          Info     Oct 27, 2020 02:23:46 The system is stopped by
                                                     host sleep
3016  Ctrl 1          Info     Oct 27, 2020 02:57:24 The system is started
3017  Ctrl 1          Info     Oct 27, 2020 02:58:40 The system is stopped by
                                                     host sleep
3018  Ctrl 1          Info     Oct 27, 2020 07:54:26 The system is started
3019  Ctrl 1          Info     Oct 27, 2020 07:55:43 The system is stopped by
                                                     host sleep
3020  Ctrl 1          Info     Oct 27, 2020 08:45:05 The system is started
3021  Ctrl 1          Info     Oct 28, 2020 00:00:51 The system is stopped by
                                                     host sleep
3022  Ctrl 1          Info     Oct 28, 2020 00:11:06 The system is started
3023  Ctrl 1          Info     Oct 28, 2020 00:12:18 The system is stopped by
                                                     host sleep
3024  Ctrl 1          Info     Oct 28, 2020 00:45:57 The system is started
3025  Ctrl 1          Info     Oct 28, 2020 00:47:09 The system is stopped by
                                                     host sleep
3026  Ctrl 1          Info     Oct 28, 2020 06:57:33 The system is started
3027  Ctrl 1          Info     Oct 28, 2020 06:58:50 The system is stopped by
                                                     host sleep
3028  Ctrl 1          Info     Oct 28, 2020 09:07:29 The system is started
3029  Ctrl 1          Info     Oct 28, 2020 15:03:49 The system is stopped by
                                                     host sleep
3030  Ctrl 1          Info     Oct 28, 2020 15:14:28 The system is started
3031  Ctrl 1          Info     Oct 28, 2020 15:15:40 The system is stopped by
                                                     host sleep
3032  Ctrl 1          Info     Oct 28, 2020 15:54:31 The system is started
3033  Ctrl 1          Info     Oct 28, 2020 15:55:44 The system is stopped by
                                                     host sleep
3034  Ctrl 1          Info     Oct 28, 2020 15:59:08 The system is started
3035  Ctrl 1          Info     Oct 28, 2020 16:18:30 The system is stopped by
                                                     host sleep
3036  Ctrl 1          Info     Oct 28, 2020 16:24:18 The system is started
3037  Ctrl 1          Info     Oct 28, 2020 16:25:31 The system is stopped by
                                                     host sleep
3038  Ctrl 1          Info     Oct 28, 2020 16:57:58 The system is started
3039  Ctrl 1          Info     Oct 28, 2020 16:59:10 The system is stopped by
                                                     host sleep
3040  Ctrl 1          Info     Oct 28, 2020 18:23:01 The system is started
3041  Ctrl 1          Info     Oct 28, 2020 18:24:18 The system is stopped by
                                                     host sleep
3042  Ctrl 1          Info     Oct 29, 2020 00:02:41 The system is started
3043  Ctrl 1          Info     Oct 29, 2020 00:03:54 The system is stopped by
                                                     host sleep
3044  Ctrl 1          Info     Oct 29, 2020 08:15:05 The system is started
3045  Ctrl 1          Info     Oct 29, 2020 17:31:48 The system is stopped by
                                                     host sleep
3046  Ctrl 1          Info     Oct 29, 2020 18:06:26 The system is started
3047  Ctrl 1          Info     Oct 29, 2020 18:07:38 The system is stopped by
                                                     host sleep
3048  Ctrl 1          Info     Oct 29, 2020 18:41:14 The system is started
3049  Ctrl 1          Info     Oct 29, 2020 18:42:30 The system is stopped by
                                                     host sleep
3050  Ctrl 1          Info     Oct 30, 2020 01:02:39 The system is started
3051  Ctrl 1          Info     Oct 30, 2020 01:03:57 The system is stopped by
                                                     host sleep
3052  Ctrl 1          Info     Oct 30, 2020 08:15:05 The system is started
3053  Ctrl 1          Info     Nov 2, 2020 08:34:34  The system is stopped by
                                                     host unplug
3054  Ctrl 1          Info     Nov 2, 2020 08:34:41  The system is started
3055  Ctrl 1          Info     Nov 2, 2020 08:35:01  The system is stopped by
                                                     host sleep
3056  Ctrl 1          Info     Nov 2, 2020 08:35:08  The system is started
3057  Ctrl 1          Info     Nov 2, 2020 08:50:48  The system is stopped by
                                                     host sleep
3058  Ctrl 1          Info     Nov 2, 2020 08:50:55  The system is started
3059  Ctrl 1          Info     Nov 2, 2020 08:52:15  The system is stopped by
                                                     host sleep
3060  Ctrl 1          Info     Nov 2, 2020 08:52:22  The system is started
3061  Ctrl 1          Info     Nov 2, 2020 08:57:46  The system is stopped by
                                                     host sleep
3062  Ctrl 1          Info     Nov 2, 2020 08:57:53  The system is started
3063  Ctrl 1          Info     Nov 2, 2020 08:58:37  The system is stopped by
                                                     host sleep
3064  Ctrl 1          Info     Nov 2, 2020 08:58:44  The system is started
3065  Ctrl 1          Info     Nov 2, 2020 08:59:52  The system is stopped by
                                                     host sleep
3066  Ctrl 1          Info     Nov 2, 2020 14:01:29  The system is started
3067  Ctrl 1          Info     Nov 2, 2020 14:01:29  The system is stopped by
                                                     host sleep
3068  Ctrl 1          Info     Nov 2, 2020 14:01:29  The system is started
3069  Ctrl 1          Info     Nov 2, 2020 14:02:37  The system is stopped by
                                                     host unplug
3070  Ctrl 1          Info     Nov 2, 2020 14:02:41  The system is started
3071  Ctrl 1          Info     Nov 2, 2020 14:03:29  The system is stopped by
                                                     host unplug
3072  Ctrl 1          Info     Nov 2, 2020 14:05:42  The system is started
3073  Ctrl 1          Info     Nov 2, 2020 14:05:42  The system is stopped by
                                                     host sleep
3074  Ctrl 1          Info     Nov 2, 2020 14:05:42  The system is started
3075  Ctrl 1          Info     Nov 2, 2020 14:05:42  The system is stopped by
                                                     host sleep
3076  Ctrl 1          Info     Nov 2, 2020 14:05:42  The system is started
3077  PD 1            Major    Nov 3, 2020 10:16:39  Physical Disk is marked
                                                     as DEAD due to removal
3078  LD 0            Major    Nov 3, 2020 10:16:39  Logical drive has been
                                                     set to critical
3079  PD 1            Warning  Nov 3, 2020 10:16:40  Physical Disk has been
                                                     removed
3080  Ctrl 1          Info     Nov 3, 2020 11:20:51  The system is stopped by
                                                     host shutdown
3081  Ctrl 1          Info     Nov 4, 2020 12:46:01  The system is started
3082  LD 0            Major    Nov 4, 2020 12:46:01  Logical drive has been
                                                     set to critical
3083  Ctrl 1          Info     Nov 5, 2020 14:32:33  The system is stopped by
                                                     host shutdown
3084  Ctrl 1          Info     Nov 6, 2020 09:06:02  The system is started
3085  LD 0            Major    Nov 6, 2020 09:06:02  Logical drive has been
                                                     set to critical
3086  Ctrl 1          Info     Nov 6, 2020 09:12:24  The system is stopped by
                                                     host restart
3087  Ctrl 1          Info     Nov 6, 2020 09:12:46  The system is started
3088  LD 0            Major    Nov 6, 2020 09:12:46  Logical drive has been
                                                     set to critical
cliib>
Paul Kerry posted this 28 February 2021
I am having the same issue with my Pegasus R4 8TB on my M1 macbook pro
But with PD3 having bad sector issues, But I still should be able to mount the logical drive right? its a raid 5 also if only one drive has failed I shoudl still be able to mount the 6tb and start a data recovery right?
Or is it just an issue with M1 macs? I do have the latest driver for M1 mac from promise it has works great for a few months, I might plug it into an intel mac and see what happens.
I need to recover the data off it before I can replace the drive. Also the Toshiba 2TB DT01ACA200 drives are no longer sold in Australia they are a discontinued product. Are there any other drives I can use? for 2TB HDD's?
