Correct replacement disk for Pegasus 2 R6
  • 515 Views
  • Last Post 22 May 2018
Adam Bridge posted this 22 May 2018
A disk on my RAID array has been taken off-line with a high failure rate. I'm unable to dump the SMART log for that drive because the applicaiton crashes.
I need to replace the disk. Do I have to use the precise same drive? What are the kinds of drives I can use?
Pradeep Chidambaranath posted this 22 May 2018
Hi Adam,
You can use any same size drive from our compatibility list. Kindly go to the link below to download our compatibility list.
https://promise.com/DownloadFile.aspx?DownloadFileUID=4754
If you need any further assistance, kindly go to https://support.promise.com to register the unit and create a support ticket and we will be more than happy to help you.
