Controller Firmware change from 10.x to 3.x?
  • 1.9K Views
  • Last Post 10 June 2017
Stefan Raudonis posted this 30 October 2016
i wand to upgrade my Vtrak E610fS to a dual controler system and got 2 used controllers for it (one for spare). But they have the 10.x Firmware. Is it possible to flash this Controllers with the current 3.x firmware?
Kind regards
Stefan
Venkatachalam Settu posted this 10 June 2017
Hi Macro,
In order to reset the password to factory defaults, you need to flash the confuser image to the controller. Please create a websupport case at support.promise.com and follow the steps below then attach the serial logs to this case, so we can send you the confuser image for the current firmware version of the controller,
-Connect to the unit through the serial console and power on the unit, Here are the settings for the serial port:
Baud Rate: 115200
Data Bits: 8
Stop Bits: 1
Parity: None
Flow Control: None
- Once you logged into the CLI of the Vtrak via the hyper terminal, just re-boot the device and it would display the booting process
- Capture the serial logs generated (copy/paste it to notepad) & reply it to this email and do help us with the call back number and time to assist you with this issue.
We are looking for the below info in the boot sequence which lists the firmware version,
Promise VTrak Command Line Interface (CLI) Utility
Version: 10.xx.2270.xx Build Date: May 20, 2014
Marco Maria Foschi posted this 10 June 2017
I have bought a Promise vtrak e610f via Ebay, no hard disk inside. The seller doesn't have the administrator password. I have connected via serial cable the controller to upload a new firmware to completely reset the vtrak but the terminal window ask me the administrator password: What can I do to reset the controller and use the webPAM to configure it?
TIA, sorry for my english, Marco.
Stefan Raudonis posted this 03 November 2016
nearly all is perfect. The cable is correct, and i was able to flash the correct firmware from the loader prompt via tftp. Now the mac controller is running in active active mode with the non mac controller. ALUA is active and VMware shows 4 active path with io.
The only problem, after replacing the memory module, the controller told me that the cache battery can't hold the cache content for 72 hours. The new battery for the second controller reports the same but is still charging, perhaps i must replace the old one too, but the chassy overview is all green.. Only at the back of the chassy, the battery led is orange.
At one place i can see in WebPAM that this is a mac controller, the Boot loader shows "1.02.2270.04 for Mac" in the controller view and the "SEP Firmware" is different:
Richard, thank you for your help!
Kind regards
Stefan
Stefan Raudonis posted this 01 November 2016
Hi Richard,
thank you, this helps me a lot...
I think next weekend i will test again, i write the results.
Kind regards
Stefan
R P posted this 31 October 2016
Hi Stefan,
I have the pinout, let's see if I have luck inlining an image.
--Rich
Stefan Raudonis posted this 31 October 2016
Hi Richard,
thanks for the informations, i have already the mux adapters and i had two additional controllers so i can put one of the 2GB modules to the existing controller. The only thing i need is a battery unit for the second controller.
I will test it...
On thing, do you have the pin layout of the RJ11 serial port? I think i lost the serial cable...
Kind regards
Stefan
Hi Stefan,
If you are going from single controller to dual controller you may need to do more than just add a second controller. If you have SAS drives you will be OK as they are dual ported. But SATA drives are single ported and cannot be used as-is in a dual controller subsystem. You will need to add an AAMUX adapter to each drive so that both controllers will be able to access them.
http://shop.promise.com/index.php?p=product&id=19
The MAC and Channel controllers are physically the same, but MAC controllers come with 2GB of memory standard and the Channel controller comes with 512MB standard. Both controllers must have the same amount of memory or one will come up in maintenance mode.
Also, if you have a MAC Chassis and boot a Channel controller, the controller will come up in maintanance mode. But you can flash MAC firmware from maintanance mode if this happens. The same solution works if you have a Channel chassis and MAC controllers. You can contact TS if you need help, you will need to download the firmware and use the ptiflash command and set up a tftp server. There are several free tftp servers available, I've had  good luck with tftpd32.
--Rich
Hi Pradeep,
on my Mac Chrome i can't open the page, i can only select reload. On my Windows Chrome it works... The IE don't work... Today i used a older Opera portable version to access the storage.
Shure CLI is a option...
Kind Regards
Stefan
Pradeep Chidambaranath posted this 30 October 2016
Hi Stefan,
It is not possible to replace the SSL certificate for WebPAM. It's a limitation of a very old design. There is no way to update the SSL to a higher level security.  You can use the CLI to manage the unit.
Kindly go to the below link to download the product manual and go to page number 165 to know more about Management with CLI
http://promise.com/DownloadFile.aspx?DownloadFileUID=747
Also, you could try to access the the WebPAM with google chrome to see how it works.
Hi Pradeep,
o.k. one other small question...
Is it possible to replace the certificate from the controller? I disabled alredy SSL but the login page is still SSL and the certificate is very bad. Because this i must use a very old portable browser to manage the storage...
Kind regards
Stefan
Hi Stefan,
We may not be able to flash the Windows firmware on a MAC controller. The VTrak x10 unit's controllers are individually designed for MAC version and for Windows version. The MAC version of the controller can only support 2TB drive and the Windows version of controllers can support up to 4TB drives.
Hi Pradeep,
thanks for the fast answer!
I think the serial of the controller is: M42H09917300199
Why isn't it possible to change the firmware, is the hardware different?
Kind regards
Stefan
Hi Stefan,
The 10.x firmware is for MAC version of VTrak unit and 3.x version is for the windows version of VTrak unit. You cannot use a MAC version controller with a Windows version of controller.
Could you kindly confirm the unit serial number?
