Connecting a Seagate Drive to USB
  • 810 Views
  • Last Post 06 October 2018
Aidan Montague posted this 06 October 2018
 This may be a stupid question. But, can I transfer files from a Seagate Hard Drive (originally attached to a PC as a backup drive) onto my Apollo. I have attached via USB but I get the message 'An external USB storage device is not detected".
Appreciate any thoughts.
Many Thanks
Venkatachalam Settu posted this 06 October 2018
Hi Aidan,
Apollo features a USB 3.0 port that can be used for various functions using a USB storage drive. You can use a USB storage drive to Backup or Restore data from the Apollo. You can also transfer data from a USB drive to the Apollo. Backup and Restore using a USB storage drive are available using the App or the Apollo Utility. For the USB Transfer function (upload from USB drive to Apollo), use the Apollo Utility. The Backup and Restore procedure is the same for the App or the Utility. Note that USB storage drive operations are available only to the Apollo owner.
