Venkatachalam Settu
posted this
06 October 2018
Hi Aidan,
Apollo features a USB 3.0 port that can be used for various functions using a USB storage drive. You can use a USB storage drive to Backup or Restore data from the Apollo. You can also transfer data from a USB drive to the Apollo. Backup and Restore using a USB storage drive are available using the App or the Apollo Utility. For the USB Transfer function (upload from USB drive to Apollo), use the Apollo Utility. The Backup and Restore procedure is the same for the App or the Utility. Note that USB storage drive operations are available only to the Apollo owner.
