I am currently using a Seagate IronWolf 12TB drive (Model: ST12000VN0008) with a Promise A6120 system, running firmware SR1.5.
I would like to report that:
The drive is not being detected properly under CLI command
phydrv -vor during initialization. -
I have confirmed with Seagate that the drive's firmware is up to date, and it uses a standard SATA interface under the IronWolf NAS line.
However, this model is not explicitly listed in the SR1.5 compatibility list.
Given that IronWolf drives are generally supported, and similar models function properly, I would like to know:
Does SR1.5 officially support ST12000VN0008 drives, even if not listed?
Is there any known workaround or patch to allow detection of this drive on the A6120?
Are there future firmware updates planned that will add support for this drive model?
Thank you for your help in resolving this compatibility issue.
