Can't mount Pegasus2 R6 on M4 with OS 15.5 (24F74)
  • 1.3K Views
  • Last Post 11 July 2025
Jan Priess posted this 07 July 2025
Hi Pegasus,
I need urgent help, I cannot mount my Pegasus2 R6 on my new MacBook Pro M4 with Sequia 15.5 (24F74).
I installed the Pegasus DEXT Driver and followed the instruction of the manual, but it does not work.
I use the Apple adapter A1790 for connection.
Please help me, what is the problem?
Jan Priess posted this 10 July 2025
Dear Frank,
THANKS A LOT!
I did all you asked me to - AND - now it is running!
Thank you so much for your support.
Have a great day and good buy.
Kind regards,
Jan
  • Brian Feulner
Frank Bosma posted this 08 July 2025
Hi Jan,
you can check the status of the installed DEXT driver in terminal.
Open a terminal window
Type: systemextensionsctl list | grep promise
Outcome should read [activated enabled]  for driver 21.1.0
If not, check the driver extensions in your Mac's system settings:
General > Login and Extensions > Driver Extensions > click the 'i' symbol on the right.
Here you can enable the Pegasus DEXT driver installer if necessary.
Jan Priess posted this 08 July 2025
Hi Frank,
Thanks for the reply.
However:
1st: I've typed in the terminal: systemextensionsctl list | grep promise
The ourtcome is [activated enabled]  for driver 21.1.0/1
2nd: The Pegasus DEXT Driver Installer is set "on"
Question:
Do I also need to install the PegasusPRo DEXT Driver Installer as shown in your printscreen?
So far the Pegaus2 R6 failed to mount on plugin.
I urge you to help me to get this running, because I need to get back to my data stored on the drive!
Thank you very much for a feedback with a positive support :-)
KR, Jan
Frank Bosma posted this 09 July 2025
Hey Jan,
The PegasusPro driver is not necessary, it is in my screenshot because I have both units in my setup.
Since the driver is installed correctly, please check first if the device is seen in your Mac System Report > hardware > Thunderbolt section.
If not, check the Thunderbolt cable connection, maybe the issue is with the TB2>TB3 adapter you are using or you can try different Thunderbolt ports on your Mac.
Also, if possible, try to connect the device to an older Mac with TB2 ports, see if it starts there and then check the firmware of the unit. Latest version for Pegasus2 is 5.04.0000.64, update if necessary and try again to connect it to your new Mac.
Jan Priess posted this 09 July 2025
Dear Frank,
I've check with the Pegasus2 R6 connected. The Systemreadout (sorry it is in German):
Pegasus2-R:
  Herstellername:    Promise Technology, Inc.
  Gerätename:    Pegasus2-R
  Modus:    Thunderbolt 2
  Geräte-ID:    0x9
  Hersteller-ID:    0x2
  Geräterevision:    0x3
  UID:    0x00020000000F4030
  Routenzeichenfolge:    1
  Firmware-Version:    19.2
  Port (Upstream):
  Status:    Gerät angeschlossen
  Verbindungsstatus:    0x2
  Geschwindigkeit:    20 Gb/s
  Firmware Version des Link-Controller:    0.13.0
  Port:
  Status:    Kein Gerät angeschlossen
  Verbindungsstatus:    0x7
  Geschwindigkeit:    Up to 20 Gb/s
I downloaded the lates firmware for the Pegasus2 R6 from www.promise.com webpage, however, the recent file on your webpage for the latest firmware 5.04.0000.64 is corrpupt (error message stated that it refused to run) and does not work.
-> Would it be possible to upgrade your webpage or send me the firmware by e-mail?
-> Also, the reply from the hardware info on Thunderbolt - is it OK?
Many thanks for not giving up and help me to finally get the Pegasus2 R6 running again on my new Mac.
Kind Regards,
Jan
Frank Bosma posted this 10 July 2025
Hi Jan,
the hardware info is correct, no problem there.
Regarding the firmware, the file is not an executable, so to update the firmware you would need to open the file from within the Promise Utility.
Open the Utility (please make sure the utility is the correct version for Pegasus2, 4.06.0000.01)
https://www.promise.com/DownloadFile.aspx?DownloadFileUID=6740
If the Pegasus device is found by the Mac then a window will open to show the device dashboard.
Unlock the utility by clicking the lock icon in the bottom left corner.
Then, in the main Mac menu, choose Admin > Firmware Update to select the firmware file and start the process.
Kind regards,
Frank
Brian Feulner posted this 10 July 2025
I'm having the same trouble right now, but I followed this thread and it didn't seem to work for me.
Mac Air  M4 Sequioa 15.5
Pegasus 2 R4
Installed the Dex version 21.1.0 and enabled it
Promise firmware is 5.04.0000.62
The promise works on my iMac Pro with 15.5 but not on this Macbook Air. When I plug it in, it turns on but doesn't mount. I'm using the same cable as Jan. Not sure what I'm missing.
Thanks!!
Frank Bosma posted this 11 July 2025
Hi Brian,
Latest version firmware for Pegasus2 is 5.04.0000.64 so definitely try to update the firmware as explained above.
Kind regards,
Frank
Dear Frank,
THANKS A LOT!
Kind regards,
Jan
Thanks for the feedback Jan !
Glad it helped.
