Boot Problem NS4700
  • 838 Views
  • Last Post 13 June 2018
Ioan Barcanescu posted this 02 May 2018
After NS4700 boots up I receive the following errror on the screen:
squashfs errror: zlib_inflate errror
squashfs errror: unable to read page, block d749d7, size b990
Please advice
Ioan
Venkatachalam Settu posted this 09 June 2018
Please answer to the following queries.
-What is light status of the unit and drives?
-Can you epxlain the unit setup?
- Where are you getting these errors? Like on the logs or webpam?
- Are you able to access the Webpam and generate the logs?
Ioan Barcanescu posted this 13 June 2018
- there are no drives installed at this moment
- the system is up and the led screen is fucntioning
- I am able to setup the network setting from the front panel
- the unit is reset to factory settings
- I am not able to acces the unit trough Webpam
- i can see the errors on the monitor attached to the VGA port
