I have a Pegasus 32 which I'd only like to power on manually... often I want to power on my system without the raid powering on.
Any workaround as I can't see anything in the manual.
Cheers.
Cheers.
Hello Alasdair,
The Pegasus is designed in such a way to wake and sleep with the MAC, there is no workaround to disable the auto power on apart from manually powering off the unit.
Hi Alasdair,
If you only use the Pegasus intermittantly, a simple workaround would be to unplug the Thunderbolt cable unless you need to access the storage.
