Auto power on - how to disable?
  • 523 Views
  • Last Post 16 March 2022
Alasdair Gill posted this 14 March 2022
I have a Pegasus 32 which I'd only like to power on manually... often I want to power on my system without the raid powering on.
Any workaround as I can't see anything in the manual.
Cheers.
Gautham Sakthi posted this 16 March 2022
Hello Alasdair,
The Pegasus is designed in such a way to wake and sleep with the MAC, there is no workaround to disable the auto power on apart from manually powering off the unit.
  • Alasdair Gill
R P posted this 16 March 2022
Hi Alasdair,
If you only use the Pegasus intermittantly, a simple workaround would be to unplug the Thunderbolt cable unless you need to access the storage.
  • Alasdair Gill
